Galvanized frames and bulkheads? - Defender Source
Old April 14th, 2013, 08:04 PM
RoverC
Cliff
1997 D90 ST
What is the consensus on the best frame replacement for a 97 ST?
Richards? any others?
What about Designa chassis? Their site says: "All the Designa Chassis are built and jig assembled in house with 3mm side rails (4 or 5mm also available) using computer designed machined parts."
What are the others and a stock LR frame?
Then of course, where best to get it from?
Then to bulkheads.
Is the RN one the only option or where do they get that from?
What is "galvaneal" anyway?
Can that be galvanized over or not needed?
Ive been building/restoring/modding this truck forever and never want to have to touch it again if possible, so Im thinking of doing this while its apart.
thanks
Old April 14th, 2013, 08:44 PM
Usually your stock bulkhead can be rebuilt and galvanized. That saves a couple grand.
Old April 14th, 2013, 10:30 PM
Abu Buckwheat
Malcolm
2005 Defender 110 TD5 Station
Registered User
I looked into galvanizing my chassis locally and that may be a much better alternative unless the original is just plain shot.
Old April 15th, 2013, 08:56 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Another option for bulkheads is epoxy treatment.
How bad are your current chassis & bulkhead?
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old April 19th, 2013, 04:35 PM
RoverC
Cliff
1997 D90 ST
Not real bad, but would like to do a side by side swap rather than take it all apart etc
So no one can recommend Designa over Richards over Marsland etc?
Who makes RN's?
The ones the Atlanta co sells?
Old April 19th, 2013, 04:38 PM
RoversNorth
RN
2012 Land Rover Defender
We sell Richards and Marsland.
Rovers North
1319 Vt Rt 128, Westford, VT 05494
Please message me with any questions you have.
Old April 19th, 2013, 04:50 PM
Galvanneal is superior to plain hot dip galvanizing. It's hot dip galv that has been annealed to perform diffusion bonding between the zinc and steel. The secret sauce is a composite oxide layer of manganese and phosphate. This creates a stable oxide coating which has superior paint adhesion compared to hot dip galvanizing.
I don't know if galvanneal can be re-dipped.
Old April 19th, 2013, 05:03 PM
61rover's Avatar
61rover
John Crouse
Does anyone sell one that doesn't have that big hole in the back that the NAS trucks didn't have?
Old April 19th, 2013, 05:05 PM
Apparently so.
RN does not list one for the 110, they do for the 90, but I have seen replacement NAS 110 frames with the NAS rear crossmember.
Old April 19th, 2013, 05:07 PM
This one? http://landroverparts.roversnorth.co...VANIZED&key=it
Old April 19th, 2013, 05:22 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
I called to inquire about galvanneal a few weeks ago and was told it is not as rust resistant as galvanizing. They recommended having the lower half of the bulkhead dipped to protect the footwells since I live on the east coast.
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old April 19th, 2013, 05:26 PM
RoverC
Cliff
1997 D90 ST
does that mean galvaneal doesnt need to be etched to paint?
I was thinking of putting Speedliner over the lower portions
------ Follow up post added April 19th, 2013 05:27 PM ------
was that RN that told you that or ?
Old April 19th, 2013, 06:02 PM
lordhelemt's Avatar
lordhelemt
Paul
Yes, RN.
Old April 19th, 2013, 09:33 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
I have a Richards chassis. No hole in the rear crossmember, and the quality of construction is very good.
Old April 24th, 2013, 03:27 PM
RoverC
Cliff
1997 D90 ST
I asked designa chassis if they could make a 5mm frame and even though they mention it on their site:http://www.designa-chassis.co.uk/chassis.asp
Heavy Duty 3mm Rails (4mm or 5mm rails also available)
They replied they could only make it in 3m as the chassis rails are too thick and do not allow for the chassis to flex
So why does it need to flex if the suspension is flexible?
Old April 24th, 2013, 03:31 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Same with mine...
We sell Richards and I've been very happy with the product, the packing, and the service. For bulkheads we sell Ashtree International - refurnished bulkheads. If yours is not totally done for it is better to repair and seal if possible. If not we have bulkheads in stock ready to repair and dip or seal. Sealing (Epoxy) means no warpage potential like a hot dip.
Old April 24th, 2013, 03:32 PM
They are just lazy. The frame has minimal flex.
Old April 24th, 2013, 03:41 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Not so much a driving performance issue (suspension) as a longevity/structural issue IMO. If there is a moderate amount of elasticity in something like a frame, then the energy applied is modulated and dissipated instead of transferred directly to the tension areas. It's a balance between mass, rigidity, and flex to keep the weight bearing areas of the frame from developing stress fractures with use.
Old April 25th, 2013, 05:24 AM
griffman
victor jones
1984 90 V8
Then to bulkheads.
thanks
Get a Richards Chassis - they are made of thicker steel and they are the only supplier who supply the CORRECT rear crossmember for your model year and engine type - this is very important and will be more so in the future when classic car status is confirmed!
Ganvlanising is Zinc electro-plating - the frame will last for ever with this done.
I don't know about in the US but in UK and Europe a car with a galvanised frame is worth 30% more than one without!!!!!!
Galvanized frames rovertrader For Sale - Parts 12 October 11th, 2008 08:32 AM
Front Doors off AA Yellow 95 D-90 Trade or Sell parkcity4x4classic For Sale - Parts 23 December 18th, 2006 05:40 PM
Tell me why I should/should not buy a D90 fustogrande Defender Technical Discussions 44 March 2nd, 2006 11:57 AM
Hi - I'm a Wrangler guy who can't get a Defender out of my mind! Skobie Defender Technical Discussions 43 August 18th, 2005 02:13 AM
