frankenstein 109 - Page 2 - Defender Source
Old October 1st, 2012, 07:51 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
Originally Posted by JohnsD90 View Post
I could buy it for the panels lol
buy it than!
Old October 1st, 2012, 08:16 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
I don't use paper on those. Id use Permatex gasket maker item #51813 http://www.amazon.com/Permatex-51813.../dp/B0002UEONM
Also, if you plan on wheeling it S3 (with the pressed in larger studs and lugnuts) are a good upgrade.
-Jeff
thanks, do i just need to buy the studs and lugs?
Old October 1st, 2012, 09:00 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
Thats the hard way. Just keep an eye open for extra hubs. Usually some one is parting a series truck, or is upgrading to discs etc. The S2 thread in studs can be temperamental if the lug sticks on the stud and it unthreads from the hub. The quickest check is that S2 hubs use a 15/16 lugnut, the S3 use 1-11/16 (27mm) same as a coiler.
Be advised there is a bigger lugnut for the smaller stud, but they are awfully expensive and arent often fount in nature.
-Jeff
i will look into that tomorrow thanks! if i am not mistaken the complete axle that had the warn locking hubs on it. is a series III front axle. i'll look into it.
Old October 1st, 2012, 09:07 PM
Congrats! I'm glad you found a truck and it looks like a beauty. Where is this guy located?
Originally Posted by pendy
I'm here for the D's
Old October 1st, 2012, 09:09 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
thank you! he lives in central PA about 6 hours from me
does anyone know what kind of springs i should run in this? i want something that i know i can haul pretty much anything i toss into it but i also want decent articulation when wheeling. i have see rocky mountain makes heavy duty parabolic's for 109's anyone every use them?
Old October 1st, 2012, 10:08 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
I had the Rocky Mountain parabolics on my 109 Station Wagon. Got the 4 leafers but they didn't articulate well at all with out a significant load in the back. Pulled one leaf out and it worked much better for me, even with a load.
Old October 2nd, 2012, 07:52 AM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
so i'll probably pick up the 3 leaf 109 parabolic from RM. thanks!
Old October 3rd, 2012, 09:40 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
so the guy i bought the truck from made his own wiring harness, but there is no wiring besides the engine bay and gauges. Now i am not sure if i want to continue his work as it doesnt look bad. so does anyone if someone makes a COMPLETE wiring harness?
Old October 4th, 2012, 12:29 AM
aka rover's Avatar
aka rover
ed angel
95 D90
A friend of mine has the 3 leaf on his 65 109 SW with safari top and it looks like it has a load of lead in the back! He is quit dissapointed in them and is switching to the 4 leaf.
The front seam pretty good and sit about a 1/2 to 1" higher than stock and about 2" higher than the rear.
These are the latter packs not the ones with the 3rd leaf that acts like a overload.
Nice project!
85 D110 3.5 3 DR
Old October 4th, 2012, 07:36 AM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
uh oh! than i dont know what to get! thanks for the input and the link to the wiring harness!
Old October 4th, 2012, 11:00 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
From what I have read from around the other forums. There seems to have been a bad run of the steel that is used to make leaf springs for some of the companies that sell leaf springs. I think that this has been taken care of. Anyone else know anything about this?
Old October 5th, 2012, 09:31 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
another little update. drained and dropped the fuel Tank to find tons of crap in it. but really not rust at all. cleaned it all out. also tried fitting the warn locking hubs, to find out the outter flange on the warns need to be trimmed down around 10 thousandths or so. and i got a little bored today so i went ahead and threw the top and windshield on quickly. i can't wait til this thing really starts moving forward! theres a picture of my best friend there too!
ID:	58573   Click image for larger version
ID:	58575   Click image for larger version
Old October 5th, 2012, 09:37 PM
achampagne's Avatar
achampagne
Adrian Champagne
06 LR3 HSE
Looking good Dylan! I forgot you even had a dog!
Old October 5th, 2012, 11:10 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
yea. i have only had her about a year. but i love her. her name is Kuna.
Old October 5th, 2012, 11:24 PM
I trimmed the axle ends, not the hubs, when I fitted them to the rear of my series.
Old October 5th, 2012, 11:52 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Was this for towing purposes? Or is there other advantages to manual hubs on the back?
Old October 5th, 2012, 11:53 PM
So I could flat tow it without pulling a driveshaft. Stole the idea from Tom Bache.
Old October 5th, 2012, 11:55 PM
JohnsD90's Avatar
JohnsD90
Thats what i figured.
Old October 6th, 2012, 01:54 AM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
x2 on grinding down the end of the axle to fit the warn hub. Pretty common to have to do this. Your rig looks like it came with lots of nice goodies. Kodiak, hand throttle, adjustable seat bottoms, stylin' seats, warn hubs. Score! Do you have the corner glass for the truck cab too?
Daniel
Old October 6th, 2012, 02:44 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Looks good
Mike Hammond
1968 109 IIa neo812 For Sale - Vehicles 0 March 23rd, 2005 01:41 PM
109 rolling chassis, drivetrain bulkhead $500 evilfij For Sale - Vehicles 1 June 20th, 2004 07:50 PM
Spotted a 109 waveridin1959 Misc. Chit-Chat 5 May 18th, 2004 01:03 PM
1968 109 SW with Chevy engine kellymoe For Sale - Vehicles 0 January 27th, 2004 01:09 AM
1968 109 SW for sale in So Cal kellymoe For Sale - Vehicles 1 October 3rd, 2003 01:41 AM
