fender liners - Defender Source
Old January 14th, 2015, 04:54 PM
defender1844
Amit Likhyani
fender liners
tearing my truck apart to repaint. Looking at my fender liners and they are a bit ratty. Has anyone powder coated theirs flat black? Or galvanized or otherwise refinished theirs?
Mit
Old January 14th, 2015, 05:57 PM
skygrip's Avatar
skygrip
Claude
110 CSW 1991
The one on my truck are Galvanised and there spray with Line-x inside outside. sound improvement...
Old January 14th, 2015, 06:24 PM
They should be either galvanized steel or plastic from the factory.
Old January 14th, 2015, 06:36 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I was thinking of powder coating over the Galvy on mine when I do my rebuild. Right now they are looking a little shabby and have rust in some areas. Or is it possible to have them regalvanized?
Old January 14th, 2015, 06:58 PM
If it were me, I get them galvanized again. I would be very suspect of powder coating lasting and not causing more rust than less.
Old January 14th, 2015, 08:03 PM
i regalvanized mine and they turned put great. very slight warping but easily fixed with tools.
Old January 14th, 2015, 09:09 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Regalvanized mine as well. They look new
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old January 14th, 2015, 09:58 PM
Exactly my thoughts unless you are building up a mall cruiser that you won't drive in the rain. If you don't want them galvanized silver hit them afterwards with paint or undercoating. That way they are touch-up-able unlike powder coating.
Old January 14th, 2015, 10:41 PM
Galvanizers can now colorize the finish.
Old January 14th, 2015, 11:06 PM
defender1844
Amit Likhyani
guys, thanks for all of the responses. Next question: how about the bracket that holds the overflow bottle? Mine definitely has surface rust. Should I galvanize that as well? That bracket has some flex to it so I'm wondering if there are any concerns with dipping it.
Old January 14th, 2015, 11:30 PM
Stuff in the engine bay will be fine properly painted, but galv is always better. Usually the small parts are fine.
You can also electroplate with zinc at home easily for next to no cost.
Old January 15th, 2015, 12:01 AM
defender1844
Amit Likhyani
JSBriggs you are correct. It's basically $109 for up to 50 lbs. If I'm dropping off the fender liners, I can get every bracket in the engine bay too. Already have a galvanized frame, bulkhead and cappings. Plan to drop off the boxes under the seats too. Someone on this list suggested Southwestern Galvanizing in San Antonio. Forgot who it was but thank you.
Front wheelarch liners tim Defender Technical Discussions 1 January 11th, 2015 05:13 PM
Defender 90/110 Rear Wheel Liners Raven81 Defender Technical Discussions 20 August 20th, 2014 09:33 AM
Wanted Pair of front fender liners Uncle Douglas Wanted 5 March 2nd, 2014 09:24 AM
D90 Passenger side front fender flare... dmarchand Wanted 7 February 17th, 2004 02:07 PM
Looking for stock fender flare vnrover Wanted 5 December 7th, 2003 02:58 PM
