Ex MOD 2.5NA to Disco 200tdi - Page 9 - Defender Source
Old March 15th, 2016, 08:55 AM
Originally Posted by speedpin View Post
I have had the pcv system hooked up on the last few drives. The smoke coming out filler neck I can see and smell when bonnet is closed at a stop light. Enough pressure to be pushing a good amount of oil out valve cover gasket. Definitely combustion gases in my mind.
Out the oil cap? The oil cap should be tightly sealed. Are you sure the PCV system is working? The bores do not look spectacular in the photos, but it may be hard to see. If it was a head gasket, you would hear exhaust noise with the oil cap off.
Have you actually gone and given it a proper drive? EGTs over 1100 F?
While the head is off check the piston protrusion on all 4 just to make sure there rods are all straight.
Old March 15th, 2016, 09:03 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Had it out for about 15 miles. Was able to get egt up to about 850. Yes, even with oil cap secured I get smoke past filler cap and if I disconnect the pcv from air filter I get the same smoke. I do think bores are a little shiny.
~ Semper Fidelis ~
Old March 15th, 2016, 09:06 AM
Well, the PCV system should make a big difference, so it sounds plugged. Check it out. The filler cap should be air tight, so it needs replacing. In a well loved engine, you can still see the honing even at high miles.
850 is not even warm. It is not hot enough to clear up any coke from the rings. Really best to see it over 1100 for a nice period of time.
Old March 15th, 2016, 12:45 PM
If you have valve stem seals pushed up (per pm) it sounds like you need a valve job. I wouldn't suspect the rings first. Having a valve job done is fairly cheap <$200.
That said its a diesel and yours is a drafty military truck, you are always going to be able to smell it.
As John says 850 is low- cruising @ 55mph on level ground kind of temp.
Old March 15th, 2016, 01:51 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Leaning towards getting the head sorted (its needed regardless), then install and see where I am at. If I am still loosing compression it will confirm rings and I will go down that road (later).
~ Semper Fidelis ~
Old March 15th, 2016, 02:14 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Machine shop provided same recommendation as above with taking care of head and see how lower end pans out. Great shop in Stafford va, looks and sound (reviews) to do good work.
Just heads up.. if purchasing a used motor its ideal to be in person when its run, not just a provided you tube video. Could have spotted some of the above warning signs instead of taking someone's word.
This was sold as "No problems with it" but.. I purchased a used motor.. New turbo$$ rebuilt head$$ possible rebore in near future$$
Learning has occurred
~ Semper Fidelis ~
Old March 15th, 2016, 03:52 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Can not possibly agree more.
Folks need to understand that these engines in unknown condition are not worth much.
Old March 15th, 2016, 04:22 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I wouldn't even take "rebuilt" for gospel anymore.
Semper Fi!
Old March 15th, 2016, 07:54 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
I hear ya
~ Semper Fidelis ~
Old March 15th, 2016, 07:58 PM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
I hate to say this but I have a problem with my rebuilt 4.6L for my disco2 from RoverlandParts.com about 5 months ago.
Rebuilt doesn't mean much I have learned, you are still taking another person's claim on it.
Old March 16th, 2016, 01:26 PM
1of40's Avatar
1of40
1of40
Originally Posted by DailyDrivenDefende View Post
I hate to say this but I have a problem with my rebuilt 4.6L for my disco2 from RoverlandParts.com about 5 months ago. Rebuilt doesn't mean much I have learned, you are still taking another person's claim on it.
what has been their demeanor like when you told them their engine is not meeting expectations?
Old March 16th, 2016, 01:43 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
So apparently leaving the top bolt out of TC has the same symptoms as intermediate shafts oring failure.
Started removing drive shafts and shifter linkage to pull transfer case and noticed no bolt in the top hole above intermediate shaft(open to inside of case).
I didn't have any bolts left over but forgot the last transfer case had a stud in this location. So tc leak should be resolved.
Got the injectors tested today. Tested fine. Shop is a bosh and garrett dealer. 40$ and he threw in brass seals for injectors and spill line.
~ Semper Fidelis ~
Old March 23rd, 2016, 11:42 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Machine shop did great work reassembling and going back in this evening. Cost me $225 for the valve job and skim with pressure check.
ID:	145731   Click image for larger version
ID:	145733   Click image for larger version
~ Semper Fidelis ~
Old March 24th, 2016, 09:45 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Head back on. Compression test done cold.
320
310
320
350
Probably improve a little once warmed up
Need a thermostat housing to head gasket then ready for drive.
~ Semper Fidelis ~
Old March 24th, 2016, 10:15 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Disregard
~ Semper Fidelis ~
Old March 24th, 2016, 11:26 PM
DailyDrivenDefende
Michael
320
310
320
350
Nice!!!
I think I am going to get the head done as well. My engine is on the engine stand and I already have the manifolds off.
Now, how do you do a compression test on the diesel engine?
Did they replace the valve seals as well?
Old March 25th, 2016, 07:34 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Go to harbor freight. 25-30$ kit. It has the adapter you screw into the glow plug hole. Disconnect wire from back of IP. Turn engine over about 5 or 6 times to let pressure max out. record, move to next cylinder.
Yes the majority of the seals had lifted, for the price, might as well have the valves done and a skim while head is off.
Read my post further up about the flywheel housing gasket. Use the good one the first time!
~ Semper Fidelis ~
Old March 25th, 2016, 09:52 AM
Told ya.
Your numbers are low but within appx 10% ( ideal is within 10 lbs of one another) which is whats important. I'd suspect the HF gauge is just reading low.
Old March 25th, 2016, 09:55 AM
DailyDrivenDefende
Michael
I know I have a feeling mine may not be even like yours because I tried spinning mine a few times. Maybe 3~5 rev and there is only some high compression/resistant section of those rotations.
Thanks for the heada up on the gasket.
Did you start the engine? Did they check the fuel injs?
Old March 25th, 2016, 10:15 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
I had the injectors tested out of the engine they popped fine and had good spray pattern
~ Semper Fidelis ~
URGENT wTd 200tdi or 2.5na tv damper BRAB Wanted 1 April 18th, 2015 11:27 AM
True Reliability: 200tdi vs 2.5na spammer Misc. Chit-Chat 10 October 27th, 2014 09:19 PM
1987 Land Rover Ex MOD 2.5NA Landy110 For Sale - Vehicles 7 June 17th, 2014 01:40 PM
2.5NA to 200TDI swap in florida Mes788 Misc. Chit-Chat 1 May 27th, 2014 02:12 PM
Snorkel for a 2.5NA and 200tdi the same? spammer Defender Technical Discussions 11 November 17th, 2013 01:12 AM
