Ex MOD 2.5NA to Disco 200tdi - Page 8 - Defender Source
Old March 11th, 2016, 10:51 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Added electric fan. Will be using a temp activated switch in the end but used a manual switch for now.
Put in about 10 miles yesterday. Runs well, about 185 f and about 5000 egt averageish. Had bonnet off during drive. I can see smoke/vapor escaping out oil filler cap under load. Doing compression test this weekend to see what's going on inside.
~ Semper Fidelis ~
Old March 11th, 2016, 11:24 AM
Originally Posted by 1of40 View Post
X2. At first I only had an oil leak at the top hook up. Fixed it with thread tape. Now the bottom is dripping.
It is? Damn.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old March 11th, 2016, 11:35 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by Ren Ching View Post
It is? Damn.
Ha! This swap has been like fighting Ronda Rousey.
Old March 11th, 2016, 01:37 PM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
5000? Or 500? 5000 is impossible and 500 is very low if you are working it.
Old March 11th, 2016, 01:42 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You can drill and tap the coolant outlet to use a thermo-switch.
RDavisinVA
Old March 11th, 2016, 01:50 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
5000 would be a problem
500, went up over 600 a few times but wasn't pushing it too much
~ Semper Fidelis ~
Old March 11th, 2016, 02:41 PM
500 F ???? That is way low. Really, all that matters is the temperature with full throttle for extended periods. The temperature means nothing at part throttle.
Old March 11th, 2016, 02:47 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Once I get the bonnet/bumper/tunnel boot on I will have less distractions and will take better note of the EGTs on hills/load. I just glanced down a few times. Was looking in rear mirror for oil slicks most the time.
~ Semper Fidelis ~
Old March 11th, 2016, 03:42 PM
400 is what it cools down to @ idle so 500 going down the road is ice cube cold. 800 would be a normal going down the road temp. If you cant get over 900 then the engine isn't getting sufficient fuel.
Old March 13th, 2016, 08:07 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Haven't been out again but sorted a few things. Front end back together. New to me rockware.
ID:	144840   Click image for larger version
~ Semper Fidelis ~
Old March 13th, 2016, 09:05 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Adam:
That rig looks "Uwharrie Ready" !!!
I can't wait!
Hereis an image from the parts list showing the thermo-switch.
RDavisinVA
Old March 13th, 2016, 09:10 AM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Sharp looking Exmod!
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old March 13th, 2016, 11:34 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Originally Posted by rdavisinva View Post
Adam:
I can't wait!
Wow.. think I spotted you front row center stage.
~ Semper Fidelis ~
Old March 13th, 2016, 06:18 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Out and about for a bit. Leak in tc Intermediate shaft front o ring..joy
ID:	144867   Click image for larger version
~ Semper Fidelis ~
Old March 14th, 2016, 11:41 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Ok. Some help
Pulled head due to smoke out oil filler and some white/grey smoke out tail pipe. Getting some pressure into rocker cover pushing oil out cover seal.
Here are some pics. Bores look a little shiny, head surface looks good, used feeler and straight edge, not watped. No visible cracks.
But I did notice 5 out of the 8 valve seals were lose and towards the top of the spring. Not sure if they were blown up from pressure or what? Could this be causing my smoke issues? But probably not the pressure though.
Head gasket didn't look horrible and didn't have noticeable faults.
Headed to machine shop tomorrow to have pressure tested.
I know the block would beifit from rings and some deglazing based on shiny bores, but totally dismantling the block isn't in the cards right now.
ID:	144967   Click image for larger version
ID:	144969   Click image for larger version
~ Semper Fidelis ~
Old March 15th, 2016, 12:07 AM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
Maybe valve seals are worn? Well the machine shop can take care of all that and reseat the valves.
Old March 15th, 2016, 12:34 AM
I think you are jumping the gun... Smoke in a diesel is almost always just from the injection system. White smoke is unburnt fuel, from being sprayed in a bit late due to timing or spray pattern. Any crankcase oil that gets into the cylinders will burn cleanly and not form any smoke.
Some vapour in the crankcase is normal. I assume you have not had the PCV system hooked up?
Old March 15th, 2016, 02:57 AM
DailyDrivenDefende
Michael
Question:
Is the TDIs valve space supposed to have positive or negative pressure? Or neutral?
If the PCV is working it should be slight negative right? No?
Just trying to learn what is normal.
Old March 15th, 2016, 07:07 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
I have had the pcv system hooked up on the last few drives. The smoke coming out filler neck I can see and smell when bonnet is closed at a stop light. Enough pressure to be pushing a good amount of oil out valve cover gasket. Definitely combustion gases in my mind.
Wanted to check things out under/in head for peace of mind before hitting the road for a few hours to wintergreen (goal).
Also if I look inside head from exhaust ports, the exhaust cavities "valve stem" visable are oily (wet) more so on front chamber.
~ Semper Fidelis ~
Old March 15th, 2016, 08:51 AM
Originally Posted by DailyDrivenDefende View Post
Question:
If you put you hand over the filler at idle, there should be some suction. As you rev up it might go neutral, but should not push gas past your hand.
All if the PCV system is working.
URGENT wTd 200tdi or 2.5na tv damper BRAB Wanted 1 April 18th, 2015 11:27 AM
True Reliability: 200tdi vs 2.5na spammer Misc. Chit-Chat 10 October 27th, 2014 09:19 PM
1987 Land Rover Ex MOD 2.5NA Landy110 For Sale - Vehicles 7 June 17th, 2014 01:40 PM
2.5NA to 200TDI swap in florida Mes788 Misc. Chit-Chat 1 May 27th, 2014 02:12 PM
Snorkel for a 2.5NA and 200tdi the same? spammer Defender Technical Discussions 11 November 17th, 2013 01:12 AM
