Ex MOD 2.5NA to Disco 200tdi - Page 7 - Defender Source
Old March 7th, 2016, 06:59 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
I will use good gasket and right stuff
~ Semper Fidelis ~
Old March 7th, 2016, 07:22 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Looks good Adam.
Check out:
Intercooler Pipe Fabrication
The hose and pipe they sell is excellent.
RDavisinVA
Old March 7th, 2016, 10:00 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Thanks Rob.
Here is the failure point. The paper gasket and insufficient rtv.
Parts coming this week.
ID:	144541   Click image for larger version
~ Semper Fidelis ~
Old March 8th, 2016, 06:37 AM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Verdict on the rear main seal? Reuse or another $60?
Where did you get the gasket from?
------ Follow up post added March 8th, 2016 06:38 AM ------
Verdict on their rear main seal?
Old March 8th, 2016, 07:24 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Trevor at Rovahfarm. had to order it through allmakes. About 3 day delivery. 43$
Rear main is absolutely fine. Oil up the crank and pull housing off evenly, slides right off. but inspect for any nicks, and reuse the installation sleeve. if you tossed it I can mail you mine.
~ Semper Fidelis ~
Old March 8th, 2016, 08:29 AM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
What a great community where you can email a guy and say, "Hey, can I get that thing that you got for that guy?"
Thanks Trevor!
And Thanks Adam!
Old March 8th, 2016, 10:19 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
No worries. Hey Neil. Think you got the same radiator I did. Both my oil cooler hookups were leaking at the brass base nuts touching radiator. Quite a bit, Filled rad frame with oil. I pulled the brass adapter and the second nut off. Rightstuff under bottom washer, and permatex thread sealer on the adapter threads. Should be tight now.
~ Semper Fidelis ~
Old March 9th, 2016, 06:12 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
X2. At first I only had an oil leak at the top hook up. Fixed it with thread tape. Now the bottom is dripping. It's not fun, especially the bottom one, so right stuff/permatex is prob the better way to do it
Old March 9th, 2016, 06:39 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
And much easier fix without oil running out of it. I used a 1 1/16 socket for both adapter and nut.
~ Semper Fidelis ~
Old March 9th, 2016, 07:39 AM
1of40's Avatar
1of40
1of40
Ha! These eff'n trucks.
Old March 9th, 2016, 04:10 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Well had a few things show up today was able to fix the seal replacement turbo and got her back in. We'll get everything buttoned up tonight tomorrow afternoon.
ID:	144660   Click image for larger version
ID:	144662   Click image for larger version
ID:	144664   Click image for larger version
~ Semper Fidelis ~
Old March 9th, 2016, 05:10 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
how much of the cavity on the back of the engine did you fill with RTV?
Old March 9th, 2016, 05:12 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
You can see the Beads of rightstuff that I used.l pretty much used the gasket as a template and trace it with right stuff on both sides
~ Semper Fidelis ~
Old March 10th, 2016, 07:37 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Truck is up and running again. Put in about a mile around the neighborhood last night. No leaks..good, no more oil pooling in turbo output pipe.. good, But I do have some vapor/"smoke" coming out oil cap (when off) when running, seems to be more apparent with throttle. It has faint pressure. I am going to get the truck on the road and get it up to operating temp and put some miles of regular driving. Will get a better idea of what it could be if anything. From what I have read it could be worn rings/ head gasket, etc. But who knows.
~ Semper Fidelis ~
Old March 10th, 2016, 08:23 AM
1of40's Avatar
1of40
1of40
Did you happen to check the pressure from the dip stick? I recall folks mentioning that as a check for bottom end happiness.
Maybe pop the cover off and see if it is coming from more than one valve as well.
Old March 10th, 2016, 08:29 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
dipstick pressure is minimal but has visual vapor/smoke. Going to run it and see if anything changes, at best the motor just needs to warm up to get things freed up (been sitting for a few months). Worst case rings, maybe a head gasket but no biggie, learning a lot.
~ Semper Fidelis ~
Old March 10th, 2016, 08:32 AM
1of40's Avatar
1of40
1of40
Zero doubt. That's why we're in this abusement park, right? Get in, hang on and keep arms and feet inside the ride at all times.
Old March 10th, 2016, 08:50 AM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
Agree. You may have some stuck rings. Diesel oil has powerful detergents and if that's the issue they should free up in a few thousand miles.
Old March 10th, 2016, 08:58 AM
Thinking the same thing.
Let's get some miles under the tires and see how it is. Vehicles do best if used!
Old March 10th, 2016, 09:21 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Great to hear! Anxious to see how the driveline as a whole (200 tdi R380 with higher 5th gear, and 1.4 TC) compares to the (2.5NA, MOD LT77, and 1.6 TC). Trying not to let the small things overshadow the overall improvements.
~ Semper Fidelis ~
URGENT wTd 200tdi or 2.5na tv damper BRAB Wanted 1 April 18th, 2015 11:27 AM
True Reliability: 200tdi vs 2.5na spammer Misc. Chit-Chat 10 October 27th, 2014 09:19 PM
1987 Land Rover Ex MOD 2.5NA Landy110 For Sale - Vehicles 7 June 17th, 2014 01:40 PM
2.5NA to 200TDI swap in florida Mes788 Misc. Chit-Chat 1 May 27th, 2014 02:12 PM
Snorkel for a 2.5NA and 200tdi the same? spammer Defender Technical Discussions 11 November 17th, 2013 01:12 AM
