Ex MOD 2.5NA to Disco 200tdi - Page 6 - Defender Source
Old March 4th, 2016, 08:45 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Originally Posted by belgian View Post
Awesome, great job.
Now all the work is done, it's time for me to stop by. ha
Ha, WTF!
Yeah, you and Rick both vanished when project started.
Always beer in the garage fridge.
~ Semper Fidelis ~
Old March 4th, 2016, 09:54 AM
belgian's Avatar
belgian
Maxim
1995 RRC SWB
Originally Posted by speedpin View Post
Ha, WTF!
Hey... I did offer. Not my fault that you went all German and blitzkrieg on this project!
Great progress,
Let me know if you need an extra pair of hands.
1984 Camel Trophy 110
1995 Range Rover Classic SWB
1992 Range Rover Classic SWB
Old March 4th, 2016, 10:25 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
I know, I know. Figured my garage working hours were not very conducive to others free time.
~ Semper Fidelis ~
Old March 4th, 2016, 05:06 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Found a few drops of fresh engine oil on the ground coming from between flywheel housing and block. Not rear main seal but the paper gasket between housing and engine block. I sandwiched the paper gasket with hylomar. Err. Out she comes . Probably put a few miles on to see if anything else pops up.
Engine out or drop trans/TC .. leaning towards pulling engine but will think more
~ Semper Fidelis ~
Old March 4th, 2016, 05:22 PM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
Bummer.
I didn't read every line of this thread but since you are using a Disco 200tdi, did you put the additional 4 bolts in the flywheel housing? If you don't know what I'm talking about then I think I might know what your problem is.
Old March 4th, 2016, 05:26 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
I did add the 4 bolts to the flywheel housing as well as drill and tap the lower bolt holes for the transmission bolts
------ Follow up post added March 4th, 2016 05:29 PM ------
It's definitely seems to be between the engine block and the paper gasket. NOT between paper gasket and flywheel housing and not coming out wade plug
~ Semper Fidelis ~
Old March 4th, 2016, 06:42 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Drove in about a mile and let it heat up about to temp. If it's a few drips it is what it is fix it when I get annoyed .. if it's a LEAK I'll fix it now.
~ Semper Fidelis ~
Old March 7th, 2016, 07:00 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
At this point it needs to be done right. pulled motor, waiting on a better block to flywheel housing gasket. Also I had more oil in my output pipe to intercooler from turbo then there should have (that was without crankcase hose attached) and was a pretty smokey. Ordered new turbo cartridge as this one has seen better days.
Motor will be back in this weekend
ID:	144497   Click image for larger version
~ Semper Fidelis ~
Old March 7th, 2016, 08:06 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Think I got a pretty good deal. Shipped to my door by wednesday.
http://m.ebay.com/itm/151988132456?e...e4&_mwBanner=1
~ Semper Fidelis ~
Old March 7th, 2016, 08:11 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Think I got a pretty good deal. Shipped to my door by wednesday. http://m.ebay.com/itm/151988132456?e...e4&_mwBanner=1
I did somewhat the same thing through Dingocroft. Tim gave me a great deal. My old unit had some life left but there was no telling how much so I sold it on eBay for parts with the exhaust horns for $300.
Old March 7th, 2016, 08:13 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
cool. turbo ran fine without noise or anything just think the seals are going. Might be worth rebuilding for someone.
~ Semper Fidelis ~
Old March 7th, 2016, 08:19 AM
1of40's Avatar
1of40
1of40
Yup, iirc, the seals are inexpensive and the way to go if the bearings still have life. Kids in YouTube do them in under 15mins.
Old March 7th, 2016, 08:24 AM
fwiw. Many paper gaskets are meant to absorb and swell with oil intrusion and then as they swell they seal.
If you smear them with hylomar etc you block that from happening. I had Detroit's in one of my boats and the manual said "soak gaskets in engine oil for several hours before install". Not saying that was your issue, just that some oil related paper gaskets are meant to swell.
Old March 7th, 2016, 08:36 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Thanks Doug. I thought about that. Could have eventually gotten better but based on the amount leaking and the fact I used the inferior shitpart paper gasket vice the "elring" version. see pics for difference. I wanted to make it right. Took 30 min to pull motor back out.. getting good at it
~ Semper Fidelis ~
Old March 7th, 2016, 12:50 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Ugh...I used said gasket on the left...I used hylomar...I don't want to become "good at it".
I should know in about 10 days.
Old March 7th, 2016, 12:56 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Originally Posted by steinhnj View Post
Ugh...I used said gasket on the left...I used hylomar....
Me too!
Hope you were heavier on the hylomar. I used some (skim coat, not bead) on both mating surfaces and gasket in between. I cleaned both surfaces with blade then acetone. No dice. If you still have trans off I would highly recommend using a better RTV. don't know what I could have done better as far as the install.
~ Semper Fidelis ~
Old March 7th, 2016, 04:26 PM
Not to question things, but does not the manual state to use Silicone instead of the gasket in that location? Hylosil 102 is just silicone. Some Right Stuff would be a good choice. I had thought that the gasket was an early design and they changed to silicone due to high leakage rates....
Old March 7th, 2016, 04:33 PM
This The TDi pages - information on 200 and 300 TDi - by Glencoyne Engineering says it depends on the housing... But, people seem to recommend that sealant is a better idea regardless.
Early 200 flywheel housings had a shallow recess around the back of the seal carrier and were glued to the block with RTV sealant. This was soon replaced with a gasket which is fitted dry. If you have the early type of flywheel housing, Land Rover recommend using a gasket (ERR1440) and filling the recess with RTV sealant. The gasket tends to set hard and is very time consuming to scrape off the back of the block - you need to remove every last bit to ensure the new gasket seats correctly. Good quality gaskets are grey on one side, brick red on the other and have beads of sealant already applied - use one of these, not the cheapo grey plain paper gaskets.
Old March 7th, 2016, 04:43 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Adam, are you going to reuse the rear main seal or did you get a new one of those too?
Old March 7th, 2016, 05:28 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Depends on how easily it slides off I plan on ordering the crank well. I do have a spare if need be
~ Semper Fidelis ~
URGENT wTd 200tdi or 2.5na tv damper BRAB Wanted 1 April 18th, 2015 11:27 AM
True Reliability: 200tdi vs 2.5na spammer Misc. Chit-Chat 10 October 27th, 2014 09:19 PM
1987 Land Rover Ex MOD 2.5NA Landy110 For Sale - Vehicles 7 June 17th, 2014 01:40 PM
2.5NA to 200TDI swap in florida Mes788 Misc. Chit-Chat 1 May 27th, 2014 02:12 PM
Snorkel for a 2.5NA and 200tdi the same? spammer Defender Technical Discussions 11 November 17th, 2013 01:12 AM
