Ex MOD 2.5NA to Disco 200tdi - Page 5 - Defender Source
Old February 29th, 2016, 05:18 PM
Originally Posted by speedpin View Post
Working lower radiator mounts. Removing just the risers on the rad frame would not yield enough drop. I left them alone and cut 1 inch off the 110s frame brackets. Will reweld tonight.
Just seeing this now. Yeah to do it my way you need to switch to the proper Tdi style upper brackets. The Tdi never came with the ones you are using.
Project is looking good, have you run the engine yet?
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old March 1st, 2016, 08:19 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Not yet. Finishing power steering line and some other little mods. Then drop in radiator and final tubing, add fluids and start. Will shoot a vid of start up or ... blow up
~ Semper Fidelis ~
Old March 1st, 2016, 09:26 AM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Adam, did you use your 2.5NA flywheel, or did the engine come with one?
I'm trying to figure out if the timing marks on a 2.5NA are different than on a 200Tdi flywheel. My 200Tdi was an auto, so I used the flywheel off my 2.5NA, but the timing mark on the flywheel is not lining up with the timing mark on the crank pulley behind the timing cover.
Old March 1st, 2016, 09:41 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
I used the tdi flywheen that came on the tdi. I HAD first put the 2.5NA fly on the tdi but realized the difference. The 2.5NA only has one timing notch, and the tdi had two notches and a TDC engraved markings.
With the crank key at the 12:00 position, the 2.5 na flywheel notch was at the 7:00 position from what I remember.
You "could" make it work by etching a timing mark on the NA fly but you would not be able to lock it in for setting timing, maybe drill a dimple to hold timing pin... who knows.. or get a tdi fly..
~ Semper Fidelis ~
Old March 1st, 2016, 09:50 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
See two notches here. The 2.5 na has the notch shown at the 9:00. Not the who at the timing pin.
~ Semper Fidelis ~
Old March 1st, 2016, 11:48 AM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
So the bottom line is that if I use the 2.5NA flywheel, the timing mark on the flywheel will not line up with the timing mark on the front of the 200Tdi engine.
Correct?
Old March 1st, 2016, 11:53 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
correct
~ Semper Fidelis ~
Old March 1st, 2016, 11:16 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Plumbing coming along. Decided to tuck filter into LH wing. Need to relocate or find smaller washer fluid reservoir. Turbo output tight. Yes, the only oil resistant hose was red at local napa.
ID:	143964   Click image for larger version
ID:	143966   Click image for larger version
~ Semper Fidelis ~
Old March 2nd, 2016, 02:35 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Nice progress Adam- any chance this truck will be making an appearance at Wintergreen?
I'd like to see it again!
Rent my
Old March 2nd, 2016, 02:39 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
That's the plan. Will be running this weekend. Hopefully driving it to work again next week, pending a few incoming parts. My goal was a month turnaround, so close The R380 shipment set me back a week or so.
~ Semper Fidelis ~
Old March 3rd, 2016, 07:02 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
You'll have to let me know how the clutch bleed goes for you. I've had a hard time getting mine to take.
Old March 3rd, 2016, 07:45 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Gravity bled it last night, I let the SC hang straight down with nipple up and bore side down. filled the reservoir up 3 times. Seems to be consistent firm pressure when depressing clutch.
Filled power steering, oil, gearbox, TC, and finished lower radiator hose, filled coolant, no puddles this morning.
Wiring 12V fuel pump relay this evening.
Connect battery and turn key... we will see
~ Semper Fidelis ~
Old March 3rd, 2016, 08:13 AM
1of40's Avatar
1of40
1of40
Love the SC hack. It sometimes takes a village.
Old March 3rd, 2016, 11:27 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
She's alive, alive!
Shitty video alert! 10:40 pm, just a down pipe, but couldn't wait till tomorrow. Ran 12v pump with spin on bleed screw open, when bubbles stoped, shut bleed screw, bumped key and tap tap tap...
Good times. Thanks all for tips and advice. Still have to rework, tune, adjust a couple things but back together she goes.
https://youtu.be/HB8eH5JQDMU
Thanks Pablo for cutting some decals for the cause. They look great!
~ Semper Fidelis ~
Old March 3rd, 2016, 11:35 PM
Sweet !
Old March 4th, 2016, 07:34 AM
1of40's Avatar
1of40
1of40
Swift job Adam. Can't wait to hear the reaction to the R380 and Power Steering upgrades. That is a bad ass truck.
Old March 4th, 2016, 07:48 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Went forwards and reverse about 20 ft and everything seemed 100% functional. Almost forgot I added power steering until the pump purged the air and started to kick in.. was like WOW that's nice. Was so worried about the engine guess I wasn't paying attention to the PS.
Also, I cant emphasize enough how effective the 12v inline pump was. Literally, I had a dry system from the new sedimenter off the tank, pump, lines, spin on filter and lines into IP. 20 seconds and all the air was purged, I could hear the air hissing out the bleed screw. Relay is high under hood. 4 wires, Ground, 12v switched (existing white wire on bulkhead), constant 12v (Fused off starter), and run one wire back to the + on the pump. Thanks Ron
~ Semper Fidelis ~
Old March 4th, 2016, 07:49 AM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Looking and sounding GREAT Adam! Super job!
Old March 4th, 2016, 08:00 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Thanks Ron
Typo
Thanks Rob .. Ron gets no credit for this
~ Semper Fidelis ~
Old March 4th, 2016, 08:19 AM
belgian's Avatar
belgian
Maxim
1995 RRC SWB
Awesome, great job.
Now all the work is done, it's time for me to stop by. ha
1984 Camel Trophy 110
1995 Range Rover Classic SWB
1992 Range Rover Classic SWB
URGENT wTd 200tdi or 2.5na tv damper BRAB Wanted 1 April 18th, 2015 11:27 AM
True Reliability: 200tdi vs 2.5na spammer Misc. Chit-Chat 10 October 27th, 2014 09:19 PM
1987 Land Rover Ex MOD 2.5NA Landy110 For Sale - Vehicles 7 June 17th, 2014 01:40 PM
2.5NA to 200TDI swap in florida Mes788 Misc. Chit-Chat 1 May 27th, 2014 02:12 PM
Snorkel for a 2.5NA and 200tdi the same? spammer Defender Technical Discussions 11 November 17th, 2013 01:12 AM
