Ex MOD 2.5NA to Disco 200tdi - Page 4 - Defender Source
Old February 18th, 2016, 07:44 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Ha! Those tight-ass trails! Make sure you have brakes in order. I was using all 5 last year getting off these Boggs-Sleds.
Old February 18th, 2016, 07:48 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Yeah, I remember the Tithonus that was behind me last year, I remember being glad I was in a D2. Ironic
~ Semper Fidelis ~
Old February 21st, 2016, 07:53 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Working lower radiator mounts. Removing just the risers on the rad frame would not yield enough drop. I left them alone and cut 1 inch off the 110s frame brackets. Will reweld tonight.
R380 from ashcroft cleared customs yesterday and just finished sorting at NYC airpot. Should be here in a few days. About ready for it.
ID:	143050   Click image for larger version
ID:	143052   Click image for larger version
~ Semper Fidelis ~
Old February 21st, 2016, 10:01 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Welded and a test fit.
ID:	143061   Click image for larger version
ID:	143069   Click image for larger version
~ Semper Fidelis ~
Old February 23rd, 2016, 09:34 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Added male fitting on back of intake manifold for boost gauge. Will read actual manifold pressure and be a cleaner route to gauge.
ID:	143284   Click image for larger version
~ Semper Fidelis ~
Old February 24th, 2016, 04:10 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Wired gauges. Egt and coolant temp. Installed heavy duty steering links. Shipped out a few lt77s so more room to work.
ID:	143320   Click image for larger version
~ Semper Fidelis ~
Old February 24th, 2016, 04:13 PM
I wonder how long you will be able to last until you replace the other two gauges.
First time out after dark and you will not be able to resist.
Old February 24th, 2016, 04:18 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
I was thinking the same thing. Got to resist mission creep.
~ Semper Fidelis ~
Old February 24th, 2016, 04:22 PM
Yes. There has been zero creep.....
Old February 24th, 2016, 04:33 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
yup
~ Semper Fidelis ~
Old February 24th, 2016, 05:36 PM
1of40's Avatar
1of40
1of40
Great work/progress Adam. Dude you're making it look easy. Well played.
Old February 26th, 2016, 05:59 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Parts are in. Work do be done!
ID:	143609   Click image for larger version
ID:	143611   Click image for larger version
~ Semper Fidelis ~
Old February 27th, 2016, 07:13 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Gearbox mated, linkage on. New bearings, races, cross drilled input gears, output bearing, seals in transfer case. Should have all mated tonight. Then it gets threaded into place as one.
ID:	143656   Click image for larger version
ID:	143658   Click image for larger version
~ Semper Fidelis ~
Old February 27th, 2016, 10:57 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Almost ready. Some linkage adjustment and vent tubes then slide her in.
~ Semper Fidelis ~
Old February 28th, 2016, 04:50 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
It's in. Phase three. Plumbing and elec.
ID:	143714   Click image for larger version
~ Semper Fidelis ~
Old February 28th, 2016, 06:44 PM
1of40's Avatar
1of40
1of40
Originally Posted by Red90 View Post
Can't hurt other than your pocketbock. Make sure to get an Elring head gasket and replace the bolts. Check the piston protrusion on all cylinders while it is off and the tappets. Good time to drill and tap for an EGT thermocouple while the manifolds are off.
I want to underscore what Red90 mentioned above re head gasket.
I think I made the mistake of using a genuine gasket. At the time I thought I had done my due diligence and went with genuine. I can't remember exactly why at this point.
To be honest there are a good number of different choices and decisions to make in this process and if you're new to this level of backyard mechanics it gets a bit sideways at times.
Anyway, the genuine looks like it is a bust as it looks like I'm leaking oil at the right front corner. After a simple Google search of 200tdi head gasket oil leak, there's plenty of discussion re this issue.
Hopefully the next guy doesn't make the same mistake.
Old February 28th, 2016, 07:41 PM
87 D110 (Ruby)
looking good mate...you are going to be happy with the stumpy. Man - I should have spoken to Dave and got referral $$$ from him! Between you, Rdavis, me and Sword there are a lot of Stumpy's and 200tdi's running around VA
------ Follow up post added February 28th, 2016 07:43 PM ------
you mean Doug - who I had to pull up a shale hill on my winch, while on a shale hill....I know Eric and you remember that hill - that was a bitch of a hike!
Old February 28th, 2016, 08:22 PM
... there are a lot of Stumpy's and 200tdi's running around VA ...
a few of us down here in the crazy state as well //grin
------ Follow up post added February 28th, 2016 08:23 PM ------
great progress Adam!
Old February 29th, 2016, 09:21 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
That's the hill I was talking about
For those doing this swap and dropping the drivetrain in as one. Definitely remove the RHD engine and frame transfer case mount. This allowed much smaller the new room. And at least a two person job. Would have been easier without the gear selector turrets installed. But I didn't remove any flooring so wanted Linkage right before dropping in.
~ Semper Fidelis ~
Old February 29th, 2016, 03:35 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
So close I can smell the diesel fumes. If you see something not right let me know I was doing some stuff from memory like fuel line. Will double check.
ID:	143826   Click image for larger version
ID:	143828   Click image for larger version
~ Semper Fidelis ~
URGENT wTd 200tdi or 2.5na tv damper BRAB Wanted 1 April 18th, 2015 11:27 AM
True Reliability: 200tdi vs 2.5na spammer Misc. Chit-Chat 10 October 27th, 2014 09:19 PM
1987 Land Rover Ex MOD 2.5NA Landy110 For Sale - Vehicles 7 June 17th, 2014 01:40 PM
2.5NA to 200TDI swap in florida Mes788 Misc. Chit-Chat 1 May 27th, 2014 02:12 PM
Snorkel for a 2.5NA and 200tdi the same? spammer Defender Technical Discussions 11 November 17th, 2013 01:12 AM
» Defender Registry
Runt
speedpin
Slowgo
Danimal
Add your Defender
