Ex MOD 2.5NA to Disco 200tdi - Page 3 - Defender Source
Old February 10th, 2016, 06:12 PM
M16 x 1.0, I believe. You should be able to measure and verify.
The Defender 200TDI is 5/8" UNF.
Old February 10th, 2016, 06:15 PM
Yes, M16x1.0.... Which does not exist. Most drill and tap the old sensor.
http://www.defendersource.com/forum/...e-s-18831.html
Old February 10th, 2016, 06:23 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Adam,
The EGT probe I got for the auber instrument was 1/8 NPT thread, so I ordered a tap and drill off of Amazon for it. Already having the tap and drill on hand, I gutted the sender that was in the engine and made it into an adapter for the VDO sender 323-095 to go with the VDO temp gage 310-105.
Old February 10th, 2016, 06:49 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Thanks all. I will be running a vdo gauge. I will look into the mentioned options. Thought I ordered the m16x1.0
------ Follow up post added February 10th, 2016 06:54 PM ------
Damn...ordered M16x1.5 .. oversight.
~ Semper Fidelis ~
Old February 10th, 2016, 07:10 PM
Originally Posted by speedpin View Post
Thanks all. I will be running a vdo gauge. I will look into the mentioned options. Thought I ordered the m16x1.0 ------ Follow up post added February 10th, 2016 06:54 PM ------ Damn...ordered M16x1.5 .. oversight.
M16x1.0 does not exist. Can't even see adapters anywhere.
Old February 10th, 2016, 07:13 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Will send it back and go the route Neil and others have.. drill and tap current sender. Thanks
~ Semper Fidelis ~
Old February 11th, 2016, 09:11 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Anyone ever drill and tap the flat "egr" spot on a disco 200tdi exhaust manifold. Thinking of putting my egt sensor there. Just not sure if it's too thick.
~ Semper Fidelis ~
Old February 11th, 2016, 09:29 PM
You get the best reading where all the pipes join, just above the flange. You should be able to drill and tap anywhere if it is 1/8" NPT.
Old February 12th, 2016, 07:57 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Copy. Thanks John.
~ Semper Fidelis ~
Old February 15th, 2016, 12:25 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Coolant temp and egt senders installed.
ID:	142441   Click image for larger version
~ Semper Fidelis ~
Old February 15th, 2016, 09:16 PM
JoeP
Joe Piojda
You want your pyro as close to the mix of all cylinders as you can get and in front of the exhaust wheel.
I dunno about the 200 but the 6bts I used to tune ran cold on 1 and 2 due to intake differences. What you are reading there is #1 only.
I'd look at the area just ahead of the flange, if there is no divider within 1" or so, that's your spot.
Old February 16th, 2016, 12:04 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Joe, thanks for heads up. The probe is pretty long, about at the seam. Figure an inch or two from the mix. I can always plug and retap if I seem to be cool for normal egts.
~ Semper Fidelis ~
Old February 16th, 2016, 12:11 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
New timing kit and crank seal fitted and buttoned up. New intake/exhaust gasket. Wiring harness on. Down pipe seems to fit geat.
Moving on to power steering conversion and fitting radiator/intercooler panel. Have a reseal kit for lt230 but waiting on new cross drilled input gears along with R380.
ID:	142507   Click image for larger version
ID:	142509   Click image for larger version
~ Semper Fidelis ~
Old February 16th, 2016, 11:00 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
After sorting pumps, reservoirs, hoses, bolts..looks like I have everything to run the 3 bolt for now. So. It's installed.
ID:	142559   Click image for larger version
ID:	142561   Click image for larger version
~ Semper Fidelis ~
Old February 17th, 2016, 07:23 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Adam, did you sort out your PAS mount issue? If not here is a pic or two of my backyard workaround. The mount I believe is a common Disco mount that came with the res I bought off of Don B. The galvy strap is Home Depot.
ID:	142565   Click image for larger version
Old February 17th, 2016, 07:37 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Clay, I did. Ordered a mini cooper mount for 14$. should be able to make it work. I have the lines and threaded nuts for box, I can cut and re flare as needed for length.
~ Semper Fidelis ~
Old February 18th, 2016, 07:22 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
3 bolt box was drop in. Had to get standard 7/16 x14 bolts for mounting. 4 inch.
~ Semper Fidelis ~
Old February 18th, 2016, 07:25 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Bolts
~ Semper Fidelis ~
Old February 18th, 2016, 07:34 AM
1of40's Avatar
1of40
1of40
Adam, again, impressed with how you have attacked this project. Calm and collected. I can't wait to see this puppy at WIntergreen.
Old February 18th, 2016, 07:39 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Thanks Clay. Still waiting on a blind punch but so far so good. Wintergreen will be first trail shake down. Looking forward to it.
~ Semper Fidelis ~
URGENT wTd 200tdi or 2.5na tv damper BRAB Wanted 1 April 18th, 2015 11:27 AM
True Reliability: 200tdi vs 2.5na spammer Misc. Chit-Chat 10 October 27th, 2014 09:19 PM
1987 Land Rover Ex MOD 2.5NA Landy110 For Sale - Vehicles 7 June 17th, 2014 01:40 PM
2.5NA to 200TDI swap in florida Mes788 Misc. Chit-Chat 1 May 27th, 2014 02:12 PM
Snorkel for a 2.5NA and 200tdi the same? spammer Defender Technical Discussions 11 November 17th, 2013 01:12 AM
