Ex MOD 2.5NA to Disco 200tdi - Page 10 - Defender Source
Old March 25th, 2016, 10:16 AM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
The same company did the job?
Old March 25th, 2016, 10:17 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
No it was a diesel fuel injection company I included the invoice and business information in a previous post
~ Semper Fidelis ~
Old March 25th, 2016, 10:42 AM
DailyDrivenDefende
Michael
Sorry for keep asking all these questions! You are doing exactly what I am about to do. Just want to make sure I am following you. Thank you much for all the help thus far.
Did you use the same thickness headgaskets? Did you reuse the bolts?
Old March 25th, 2016, 10:45 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
You CAN reuse the factory bolts but only a handful of times. You can get new bolts if it makes you get a warm and fuzzy. YES use the same thickness head gasket that came off.
~ Semper Fidelis ~
Old March 25th, 2016, 11:50 AM
Shagey71's Avatar
Shagey71
Sam Hagey
1995 RRC LWB - Alpine White
Great thread. just burned an hour reading the whole deal. Definitely impressed how quickly you buzzed through this one.
Rovers, Guns, and Airplanes... Willing to share my Ramen Noodle Recipes!
'95 RRC CountyLWB - dripping all over central TX
'83 110 HCPU - in piceces, all over central TX
'90 RRC Truggy - loud and proud
'95 RRC CountyLWB Beluga Black - SOLD
'01 P38 - POS Leaked Electricity - SOLD
Old March 25th, 2016, 12:33 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Thanks, hope people can catch any details that will help them out.
Waiting on thermostat lower and upper gasket. Used "Rightstuff" but no love. On a defender 200tdi I have read you need to pull the head back off to get the thermostat housing off the head. But on my disco motor its not the case. Thanks goodness.
~ Semper Fidelis ~
Old March 27th, 2016, 03:35 AM
DailyDrivenDefende
Michael
Quick question can any machine shop replace the valve seals on the 200TDIs? Do they order the parts or do you have to supply them with a set?
So, no more smoke coming through the head?
Old March 29th, 2016, 07:08 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Update. All buttoned up. With rebuilt head and decent even compression across the cylinders the vapor out oil filler cap is much reduced. I added a T into the crank to rocker cover hose and added into intake filter housing. Absolutely no pressure or vapor out oil cap if removed. So far no measurable oil out either PCV hose ,will keep an eye out.
Taking it to work Thursday and friday. 35 mile round trip. Mostly highway, we shall see.
~ Semper Fidelis ~
Old March 29th, 2016, 08:09 PM
DailyDrivenDefende
Michael
Congrats on the fix. I would love to see the T you speak of.
Old March 29th, 2016, 08:25 PM
Congrats Adam!
Old March 29th, 2016, 08:56 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Thanks. Will snap a few pics tomorrow. The T is hasty at the moment. Need smaller hose clamps but ... works.
~ Semper Fidelis ~
Old March 30th, 2016, 01:16 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Couldn't resist, took her to work today. Did great. Cruised at 70mph no effort, very happy. So far so good. Hit about 1k egt up long hill in 4th. Highest it got.
~ Semper Fidelis ~
Old April 8th, 2016, 12:10 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Ran her through diff lock and drove a "nature trail", seems as though linkage is good. Put a few hundred miles on the road over the past few weeks. Probably just shy of a 3 hr road test Friday on the way to Wintergreen!
ID:	146819   Click image for larger version
ID:	146821   Click image for larger version
~ Semper Fidelis ~
Old April 8th, 2016, 12:16 PM
well done!
congrats Adam!
Old April 8th, 2016, 12:19 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
The climb up Wintergreen Drive will be a test of our cooling systems, fer-sur.
Old April 8th, 2016, 12:25 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
~ Semper Fidelis ~
Old April 8th, 2016, 01:34 PM
WBSurfer's Avatar
WBSurfer
1995 RRC
Your truck is looking Awesome!! Enjoy!
Old April 25th, 2016, 03:27 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Okay so after a smoky showing at Wintergreen. I decided to drop sump and pull the head. Pushed pistons out top of head from below. Will take some manipulating to reinstall pistons on crank but much faster then pulling engine.
Found culprits. Top ring on # 1and 2 were broke and lower oil ring on #4.
Bores looked good but a little glazed. Used a cylinder hone to lightly restore cross hatching and have new rings & big end shells on the way.
ID:	148076   Click image for larger version
~ Semper Fidelis ~
Old April 25th, 2016, 03:30 PM
glad to hear it, best course of action.
Old April 25th, 2016, 03:40 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
I didn't even remove the ladder frame above sump pan. If you have a disco motor and add the 4 lower bolts to the flywheel housing you can't remove the ladder frame without separating the engine from gearbox.
I cheated and enlarged the two existing holes under number 1 and number 4 piston in the ladder frame in order to allow me access big end cap bolts and to drop the caps out the holes.
~ Semper Fidelis ~
URGENT wTd 200tdi or 2.5na tv damper BRAB Wanted 1 April 18th, 2015 11:27 AM
True Reliability: 200tdi vs 2.5na spammer Misc. Chit-Chat 10 October 27th, 2014 09:19 PM
1987 Land Rover Ex MOD 2.5NA Landy110 For Sale - Vehicles 7 June 17th, 2014 01:40 PM
2.5NA to 200TDI swap in florida Mes788 Misc. Chit-Chat 1 May 27th, 2014 02:12 PM
Snorkel for a 2.5NA and 200tdi the same? spammer Defender Technical Discussions 11 November 17th, 2013 01:12 AM
