Dual Rims - Defender Source
Old August 20th, 2015, 04:01 PM
wolley
Andre
TD5 2004 Puma 2013
Dual Rims
I am wondering if dual rims on my 130 will solve (if possible) my load carry need. Anyone. Attempted this ever?
Old August 20th, 2015, 04:15 PM
Are you carrying bricks of lead? I haven't figured out how to load the tiny bed on my 130 with 1200 kilos worth of stuff...
Old August 20th, 2015, 04:39 PM
BlackField's Avatar
BlackField
Oscar
D110
I don't think dual wheels will help you carry more. I think you could get a single tire rated for way more than a Defender will likely haul. Unless you are wanting to drive this load across a field of daisies, then maybe the duals will help you tread lightly'er.
Old August 20th, 2015, 07:23 PM
Mine carries just fine with single rims . Do you need more than 5 kegs?
Old August 20th, 2015, 07:26 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Come on Lav, you still covet the days this bad boy setup was being pushed.
Old August 20th, 2015, 07:44 PM
Is that Pedro's new "Defender"?
Old August 20th, 2015, 07:46 PM
Better idea
http://m.ebay.com/itm/191663853570?_mwBanner=1
Old August 20th, 2015, 08:03 PM
87 D110 (Ruby)
Holden Statesman - with WA plates ....onya Russell!
Old August 20th, 2015, 11:19 PM
wolley
Andre
TD5 2004 Puma 2013
Dual Rims
It is about stability indeed, and a few additional values
* I can use less expensive tires
* I can inflate them less
* I will have a better loose sand-driving ability
The 130 has an alu-cab fitted; I recently noted cracks in my Coopers AT3 165 tires that has a load carry capacity of 1,550 kgs. I took it to a weigh bridge and have 2,200 kgs on the rear axle, that could go to 2,500 kgs. So while I an technically "within spec", I still need to inflate to 4 bar for good stability, and question the ability of my tires to do the work I need them to do
My options are Coopers ST Max 285, that will give me a 1,770 kg carry capacity, but these are expensive. Or dual rims with less expensive tires
Your thoughts?
Old August 20th, 2015, 11:48 PM
Landy_Andy's Avatar
Landy_Andy
Andy
I've never seen dually rims in 5 on 6.5"..... or even a red neck setup. Just buy the correct tires for your needs or get a real 1 ton truck.... Just my 2c
Old August 21st, 2015, 08:01 AM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
^ this. Would be a shame to put a '14 Puma in the "defenders that suck" section.......
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old August 21st, 2015, 11:13 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
It might have been the latest "Rovers" mag from RN that had a pic of a dually series concept in it.
Old August 21st, 2015, 12:13 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
* I will have a better loose sand-driving ability.
A. Even if you go with a super stupid cheap Chinese tire you still won't save money because you will have four rims and four crappy tires where two quality tires should be. Having owned a dually F350 the rear tires wear poorly.
B. A cheap under inflated tire is not safe even with dual tires.
C. Dual tires are not good in lose sand, mud or anywhere else off road due mainly to the added weight. Back in the eighties the US military began ditching the dual tires in favor of super singles and the 5 ton trucks preformed much better off road.
rims
FS: 4 w/ Spare 235/85R16 Federal Couragia w/ Black D1 Rims & Second 4 Set ATs w/Rims monktonrover For Sale - Parts 0 July 28th, 2014 10:20 PM
dual flexalite dual electric fan setup (2500cfm) crown14 For Sale - Parts 5 May 5th, 2009 10:33 PM
Dual Exhaust Zimbo76 Defender Technical Discussions 16 May 18th, 2004 10:36 PM
dual position tailgate on a SW artm Defender Technical Discussions 5 April 24th, 2004 12:03 AM
Simple Dual Battery Isolator? OCD90 Defender Technical Discussions 1 April 9th, 2004 11:23 PM
