defender 110 SIDEFRAME repair - Defender Source
Old April 27th, 2015, 11:53 AM
Biggs!
Nathaniel Biggs
2006/LR3
Im looking at a Defender 110 right now that will need to have the side frames of the body repaired has anyone done this? I have assess to some friends would are expert welder but I can seem to find any info on the repair.
Nate
Old April 27th, 2015, 12:21 PM
YRM sells some repair parts, but new ones are available (usually) and not crazy money.
Mike at ECR will tell me it is impossible , but you can swap in a new pair easily in a day.
BTW usually they are referred to as T-pieces so that might help with searching.
Old April 27th, 2015, 12:41 PM
Best to buy the whole part and swap than to repair. Trust me.
Old April 27th, 2015, 12:52 PM
Biggs!
Nathaniel Biggs
2006/LR3
Thanks the truck has a little Bulkhead repairs needed too so I would do them at the same time. Can the T-pieces be replaced with the body still on the truck or would I need to brake the whole body down to do it?
Old April 27th, 2015, 01:09 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
110&130 frame assembly-body side
Part#s AMC710020 RH & AMC710030 1k ea side from dealer
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old April 27th, 2015, 01:41 PM
You can get them in with the body still on. Make sure to order the brackets with the two bolts that holds it to the bulkhead foot. I have only gotten one of those out in one piece.
------ Follow up post added April 27th, 2015 01:43 PM ------
$1000 each at the dealer? They are $300 each in the UK. I am sure someone can supply them for less than $1000 each.
Old April 27th, 2015, 01:47 PM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
I would agree, but if you go through the trouble of replacing I would certainly have them galvanised. Do it right the first time. I don't think I have seen many of these fixed correctly and nicely when repaired in situ. Looking good on the surface means nothing, kinda like a bulkhead.
Patches are for Pirates and pants, not a bulkhead and chassis!
Old April 28th, 2015, 05:33 PM
Biggs!
Nathaniel Biggs
2006/LR3
Just to be clear, this install would involve Bolts in the front and then drilling out the welds in the rear? If I buy this truck this would be my first big job on it and I just would want to know what I would be getting into. The bulkhead and rear doors will need a little love to.
Old April 28th, 2015, 06:22 PM
It's not as easy as you think. To do it right you'll want to raise the roof...Also remove the front wheel arch "dogleg", unbolt the middle doors and the seat box/middle bulkhead.
The T-piece is one big weldment and is bolted and riveted in place. Bolts up front, in the middle and at the rear. Rivets thru the tub sides.
Undo all the bolts and rivets. push the front downward. This will kick the back up and forward so you'll need to pull the tub outward to free the rear end. It'll makesense when you get to it.
110, defender, defender 110
Land Rover Defender 110 & Series LWB B Post Repair Section jjstahl3 For Sale - Parts 4 May 11th, 2012 10:09 AM
Land Rover Defender 90 & 110 NA Repair CD jhobbs For Sale - Parts 3 December 1st, 2011 01:23 PM
Repair: 110 Back seat release pulls RoverDude Defender Technical Discussions 1 May 3rd, 2011 10:59 PM
WTB : Rover Defender 90 Repair manual - Haynes d90frank Wanted 1 January 11th, 2009 08:53 PM
Series and Defender Seat Box Repair Panels SafariHP The Vendors Loft 0 April 29th, 2008 12:50 PM
