D90 rebuild to 100" wb... plus a few other mods ;) - Page 9 - Defender Source
Old October 26th, 2016, 09:41 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Started to finish the winch wiring, the Giggle Pin extended motor mounting bolts make for a neat contactor install.
Old December 18th, 2016, 02:09 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Here are a couple of progress pic's I posted in the GenIII LS thread of the completed engine & radiator install.
And I just completed the new chassis loom, ready to be installed. Just have the top cage loom to finish now for the light bars etc.
Old December 18th, 2016, 02:41 PM
Wow... That is fantastic
Old December 18th, 2016, 05:29 PM
GREENI's Avatar
GREENI
Greeni
4.6 GEMS '85 90.
Nice build!!!
Old December 18th, 2016, 07:07 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Originally Posted by Landy_Andy View Post
It's alive.... alive, I say !
http://www.dailymotion.com/video/x22...-science_music
Now when I look back through your build, I keep imagining this playing in your garage! ;-)
Great work by the way.
"Barry is correct!"
Old March 18th, 2017, 09:35 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Got the hood closing nice now the plenum's all trimmed up
Made a start on getting the brake lines replaced, half the back axle done today.
And the music in the shop generally consists of....
https://youtu.be/86URGgqONvA
Old March 19th, 2017, 03:21 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Looking good!
Old November 12th, 2017, 08:47 PM
Landy_Andy's Avatar
Landy_Andy
Andy
After a respite from working on the truck for family reasons, got back to it this last couple of weeks. Made a start on the exhaust system using 2.25" stainless steel tube for the Y pipe into a 3" Magnaflow silencer.
Fun part is going to be routing the 3" tail pipe round, up, under or through the rear 4 links.
Am going to have to cut & shut the passenger side manifold to lift the output pipe about 1.5" higher as it now looks too low to clear the drive shaft on full bump... darn !
Old November 12th, 2017, 11:10 PM
Factoid's Avatar
Factoid
Mark
Three criminals seeking revenge
Looking good!
You could drive a truck through that gap above the axle on the left side! The biggest challenge is thinking in three dimensions and then being able to execute the plan in your head. You are making great progress!
1976 Series III 109 "Montoya" ("You killed my father, prepare to die")
1988 Defender 90 LHD "Vizzini" (speed demon from Sicily)
1987 Defender 90 MOD LHD "fezzik" (giant rock thrower)
1975 Porsche 911 hot rod
1964 Porsche (Beck) 904
Old November 13th, 2017, 12:34 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Originally Posted by Factoid View Post
Looking good!
Just not sure if I want a single 3" tail pipe or just bite the bullet, run the 3" up to the middle between the front of the of the top links and do dual 2.5's out the back just inside the edge of the chassis rails with the pipes passing up and over the top links. Need to do a bit of measuring to make sure it'll all clear at full bump and flexed.
These oval tips would look rather smart out the back....
Old November 13th, 2017, 02:12 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Couple of other pic's I didn't post up, rebuilt 3rd for the rear axle with a Detroit locker. This will be an interim solution until I can build a heavier duty 609 axle to give me 30 or maybe 35 spline half shafts.
I also finished the brake pipes on the rear axle. There all bled now so it should stop
Old November 13th, 2017, 02:23 PM
There is no point to going 30 spline as it is only 15% stronger than 24. When you do you to 9” you need to use 35 spline or there is no point.
Old November 13th, 2017, 02:45 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Thanks, I guess I'll just have to save up some more $ then.
Old November 20th, 2017, 03:00 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Finished up the passenger side of the Y pipe, ended up shortening the vertical section of the manifold by 1.5" for more diff clearance.
The cross pipe also got lifted a bit to help with clearances around & over the 3 link x-member and front drive shaft center bearing. Will be making a new x-member at some point that'll incorporate the steady bearing mount and can then make a bit extra clearance.
Next to get the drivers side finished off, then the rear tailpipe section soon as some more bends arrive.
Starting to get close to ordering the drive shafts
Old November 20th, 2017, 03:06 PM
Factoid's Avatar
Factoid
Mark
Looks great, Andy, nicely done!
90, d90, mod, rebuild
Multiple D90 Parts discojosh2000 For Sale - Parts 13 November 2nd, 2010 07:35 PM
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
Latest Mods to the D90 DiscoDino Defender Technical Discussions 10 July 6th, 2005 10:31 AM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
