D90 rebuild to 100" wb... plus a few other mods ;) - Page 7 - Defender Source
Old November 4th, 2015, 11:29 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
That cage work is insane!
Very nice - it's going to be a great rig.
Old December 4th, 2015, 08:22 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Rear roll cage installed
Centre (cab) cage installed and all bolted up
Old December 11th, 2015, 11:25 PM
skitzy's Avatar
skitzy
Nick
91 D90 2.5NA doing LS Gen IV Thing
Nice truck. Nice cage work. Keep up the great work and thanks for sharing the progress.
Old March 20th, 2016, 08:19 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Started the new wiring loom with the instrument panel, VDO gauges & TD5 warning lights
Old March 25th, 2016, 10:40 AM
You should get the multi plug connectors for the gauges.
Old March 25th, 2016, 11:17 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Bit late now, didn't think of it at the time
Old March 25th, 2016, 11:27 AM
Can always add them later. Speedo and normal gauges. Nothing available for the tach.
240-024: 8 pole Connector for Vision, Cockpit and Series 1 Speedometers and Tachometers with LCD , by VDO - eBuggies.com
240-026: Push-on Connector: with crimp terminals , by VDO - eBuggies.com
Old March 25th, 2016, 11:34 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Not really worth doing it over now, good info for for anyone wanting to do the same
Old March 25th, 2016, 11:53 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Dash top pod & the locker switches wired, run out of 6 way housings but have enough info now to start the main bulkhead loom whilst I wait for more parts to arrive.
The 'main/sub tank' switch swaps the fuel gauge senders from the main running tank with the HP LS pump to the aux tank with just a transfer pump. The 'fuel pump' switch is to transfer fuel from aux to main.
Time to make a pegboard
Old March 30th, 2016, 07:13 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Beginnings of the bulkhead loom, still lots to do but you get the idea. Twist ties from the local super market work great for holding the bundles of wires together
Ran out of seals for the connectors so going to be a few days before I can fully finish it off.
Old March 30th, 2016, 07:18 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2516
I'm sure it's your plan, but before final installation, be sure to replace those twist ties (if they are metal wire cores) with e-tape, or the like, as the material degrades leaving just the metal to rust and eat/rub away the wire loom sheathing.
"Barry is correct!"
Old March 30th, 2016, 09:20 PM
Landy_Andy's Avatar
Landy_Andy
Andy
They'll be gone, just there to make it quick & easy to add wires into the loom bundles without wasting tape or zip ties... and there free too
Old March 30th, 2016, 09:30 PM
D90Overkill
David Frank
1995 ST #2516
I gotcha! Organizational purposes only. Insanely awesome and thorough job you're doing. Fun to follow along.
"Barry is correct!"
Old March 30th, 2016, 09:37 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Thanks... Glad your enjoying it. I find the wiring rather relaxing.... after a busy day running avalanche road closures on the highway
Old March 30th, 2016, 09:45 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
X2 However, the one problem I do have with it is the fact that I will probably never get the chance to see it on the trails.
Old April 7th, 2016, 12:10 AM
Landy_Andy's Avatar
Landy_Andy
Andy
More wires added to the bulkhead loom & the fuse/relay panel's getting quite populated.
Old May 9th, 2016, 10:53 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Wife got back from visiting her family in the UK and brought me a present.... My Rakeway Engineering drive shaft steady bearing.
Next to get quotes on the short (10") intermediate drive shaft and the front & rear ones.
What an excellent piece of kit... well chuffed.... and a wonderful wife
Old May 10th, 2016, 01:33 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Nice. Is this needed because the engine/box is mounted quite far back? or so you can angle the prop over the crossmember?
Old May 10th, 2016, 01:04 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Both really, t'case is ~9" rearwards than stock due to the crawler box between the NV4500 & nicks adaptor and I need to get over the front 3 link cross member. So, it moves the front top drive shaft joint to about where the t'case output would have been.
The intermediate drive shaft will be just 'U' joints on each end, the front & rear drive shafts will be double cardon at the upper ends. All drive shafts will be Spicer with 1310 H/D (solid) 'U' joints.
Old May 10th, 2016, 03:01 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Sweet. RakeWay do some nice shiny stuff don't they?
90, d90, mod, rebuild
Multiple D90 Parts discojosh2000 For Sale - Parts 13 November 2nd, 2010 06:35 PM
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 09:34 PM
Latest Mods to the D90 DiscoDino Defender Technical Discussions 10 July 6th, 2005 09:31 AM
D90 won't start! rover4x4 Defender Technical Discussions 32 June 13th, 2005 07:42 AM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 10:05 AM
