D90 rebuild to 100" wb... plus a few other mods ;) - Page 6 - Defender Source
Old December 16th, 2013, 12:16 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Update on my custom dash thread here :
http://www.defendersource.com/forum/...t=42326&page=2
Old December 21st, 2013, 12:36 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Made a start on some brackets, here is the one to mount the Megasquirt ECU on the seatbox top between the seats behind the auto shifter. Will make a full centre console after the dash is finished to hold the locker, winch & other switches.
The brackets very basic for seasoned Solidworks users but using the sheet metal options makes things so much quicker & easier than using 2D ACad
Old January 6th, 2014, 05:37 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Custom dash thread updated.....
Old August 31st, 2014, 11:43 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Few bits done to the cage, added light bar tabs & a protection bar to the top of the cage.
More light bar & limb riser tabs to front of the tube fenders.
Old September 1st, 2014, 02:54 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Looking nice.
Old December 13th, 2014, 06:45 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Been a while since last posting here as been working on the GM Gen III install.
http://www.defendersource.com/forum/...ad.php?t=52933
Picked up a pair of Rugged Ridge seats to replace the Qt Services F/G comp seat I had and give the passenger some where to sit :
Decided to reuse the Qt removable seat base from the F/G bucket seat to make the new ones easily removable for servicing :
Drew up some adaptors with spacers to mount the seat to the removable base :
Should make for a neat install. The seats are a great fit for the truck cab as their bases aren't too thick (sprung too) and they are covered in a heavy duty textured vinyl for long life
Old January 27th, 2015, 02:23 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Decided to do away with the Qt parts of the seat mount & have drawn up some lower brackets & spacers to reuse the parts I'd already got cut. It lowers the seat by about an inch & still leaves them easily removable for cleaning. Top half locates in the key slots with a locking bar through the front holes.
Simple & effective
Old January 31st, 2015, 03:44 PM
Alaskantinbender's Avatar
Alaskantinbender
jim
63 series 2A 109 3 door
Terrific build, great fab skills.
1995 D90 SW 338/500
1963 S2A 109 3 door
Old February 5th, 2015, 04:34 PM
Landy_Andy's Avatar
Landy_Andy
Andy
A few updates for my Gen 3 install here :
http://www.defendersource.com/forum/...ighlight=gen+3
Old February 21st, 2015, 05:36 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Did a few changes to the seat mounts & got them finished off :
Very happy with the result, easy to remove and feel solid when locked into place.
Old April 26th, 2015, 02:33 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Update on the Vortec install in the Gen III thread here http://www.defendersource.com/forum/...i-52933-6.html
Old April 26th, 2015, 09:36 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by Landy_Andy View Post
Did a few changes to the seat mounts & got them finished off : Very happy with the result, easy to remove and feel solid when locked into place.
Those seat bases quick release design is slick! Once I get my truck done I am going to redo mine more like this. Thanks for the idea!
Old May 8th, 2015, 02:30 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Major milestone reached.....
Good clearance to the front x-member too, so that won't need to be reworked.
Well pleased
Old May 28th, 2015, 01:22 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Waiting on parts again.... so, I drew up the ECU/fusebox mount that'll sit on the bulkhead where the RHD heater was.
Old September 7th, 2015, 02:36 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Fitted the hydro-assist pipework, bit close to the crank pulley but should be ok, a different 'T' would make it better but that one came with the kit.
Old September 7th, 2015, 02:44 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
I see what you mean by the T fitting. For the time being could you ziptie to the other hose? Would thing when the truck is moving the engine would just enough to rub the line or the line bounce around to touch the pulley wheel?
Old September 7th, 2015, 03:23 PM
When I did the hydro assist on my RRC I just removed that round plate off of the front of the box and put the pipe fitting there. That way I was able to drill and tap it without getting any metal into the box.
Old September 8th, 2015, 02:05 AM
Landy_Andy's Avatar
Landy_Andy
Andy
I think swapping the tee to one of these will work fine, just need to confirm the threads as they measure out at 1/4" JIC.
Old September 19th, 2015, 05:14 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Go the new 'tee' fitting for the hydro-assist & finally got it connected up :
Old November 4th, 2015, 11:39 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Bit more done, been supper busy in my new job but gett'in there
Seat box been media blasted & given a coat of rattle can bed liner
Centre cage powder coated
Rear cage finish welded & ready for powder coating
Seat box installed, cab all squared up & decent door gaps... for a Landy
Fuel & battery/charging cables routed onto the motor
Rear cage at the powder coaters now, due back in a week or two.... then it's time to start the new custom wiring loom....
90, d90, mod, rebuild
Multiple D90 Parts discojosh2000 For Sale - Parts 13 November 2nd, 2010 07:35 PM
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
Latest Mods to the D90 DiscoDino Defender Technical Discussions 10 July 6th, 2005 10:31 AM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
» Defender Registry
NAS 110
Pugsly
Murphy
NealK
Add your Defender
