D90 rebuild to 100" wb... plus a few other mods ;) - Page 4 - Defender Source
Old March 18th, 2013, 02:32 PM
mightymg's Avatar
mightymg
Lane Farka
97 D90, 05 LR3, 95 RRC LWB
Originally Posted by Landy_Andy View Post
Thx... is not just if it can turn them, the ram helps share the load so the PAS box doesn't carry it all. Prob overkill for what I'll be doing with the truck but better than walking out the bush in bear season
Agreed, I have seen a few rover boxes go, mine is probably a ticking time bomb. Love the build!
project whore!
95 RRC LWB-- DD
97 D90 37 " krawlers, coilovers, beadlocks, stretched
05 LR3 - Mamas/ tow rig
- Moab rally vids 2010
Old March 23rd, 2013, 10:26 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Made up the new rear bump stop mounts today and it allowed another couple of inches of drop when flexing the axle
At ride height I have about 4.5" of up travel but could get that to 6" if I swap out the 2" lift springs & 2" spacers for 4" lift springs... maybe later once it's back on the road.
With the design of the top plate I can swap out to air bumps any time with out having to remove the springs
Old April 1st, 2013, 10:48 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Decided to do a bit of rework on the 3 link front shock mounts, was never really happy with the single shear lower mountings so drew up some new plates & tacked it all together with a Ruffstuff shock mount on top.
Flexes out the 14" shocks nice & still clears the panard on full stuff.... just !
Will also make up some new bump stops using the X-spring cans like the rear for better shock protection at full stuff.
Old April 2nd, 2013, 12:11 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Outstanding
Mike Hammond
Old April 7th, 2013, 12:21 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Another piece of the Megasquirt puzzle arrived last week, air temp sensor adaptor for the old AFM from Nige at http://www.megasquirt-v8.co.uk/index.php
Old May 5th, 2013, 08:53 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Finished off the front suspension today, modified my old lower spring cones to mount a bump stop on the top of them and will get a top made similar to the rears. Gives me ~5" of up travel to full bump.
At full flex the cone mounted bump misses the target so I added a second to the top of the front radius arm. With 14" stroke shocks I get almost an inch of travel left at full bump and full flex. This should be sufficient for heavy landings to prevent damage to the shocks.
Front axle at full flex, this is the limit of the bolt on 3 link I have and without starting again from scratch will suffice. On full stuff the tire will just clear the rock slider when I shorten it by 1.5" and only just clears the bulkhead footwell....
Also rechecked the rear with the bump stops fitted, again I get ~5" of up travel to full bump. So, front & rear are quite well balanced.
Next to make the front shock top mounts & finish off all the small brackets on the front wing frames. Rear cage needs to come off for final welding & centre cage needs additional tubes & bracing added for some roof lights & stuff.
Old May 9th, 2013, 10:26 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Front shock mounts made, this is the drivers side... it's kinked to clear the alternator
Passenger side mounted up
Tops will be tied into the wing tubing with bolted tabs for extra bracing & easy wing removal
Old May 9th, 2013, 10:40 AM
Nice.
Originally Posted by pendy
I'm here for the D's
Old May 9th, 2013, 10:56 AM
mikeslandrover
Mike Hammond
Nice fabricating
Mike Hammond
Old May 24th, 2013, 08:34 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Finished off a few bits, made a spare tire strap & fitted the rear bump stop mounts up.... fronts ready to go on too... steady progress
Old May 25th, 2013, 02:59 AM
mikeslandrover
Mike Hammond
What are the parts in the final picture?
Splendid build
Mike Hammond
Old May 25th, 2013, 03:06 AM
mikeslandrover
Mike Hammond
Yes, I can see it now you've said that.
Thanks.
Mike Hammond
Old May 25th, 2013, 12:51 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Those look like the upper spring retainer/bump stop holder.
-Jeff
Yup, for the front.... look a few pic's back & you'll see where I mocked it up using one of the rear bump stop mounts. With the bump stop mounted onto the top of the spring relocation cone it just sat on the edge of the bump mount at full stuff. So, for the front ones I added a slightly larger & thicker plate for full contact.
------ Follow up post added May 25th, 2013 09:54 AM ------
You'll also notice on the pic of the back spring, the 'X' spring is holding the main one up..... think I need to add a bit more weight to her.... so much for all the comments off the wife about it'll be too heavy.... hop in dear
Old May 27th, 2013, 01:59 AM
Landy_Andy's Avatar
Landy_Andy
Andy
A bit of a side project here, assembling the Staz Works double bead lockers is a right royal PITA, so.... I made a stand to pull the two rim pieces together & then it's just a case of putting the bolts in around the edge & torqueing them up. So much easier when you can sit & work at a reasonable height with both hands free.
Old May 27th, 2013, 10:24 AM
I love all the custom fab in your build!
Old May 27th, 2013, 03:08 PM
mikeslandrover
Mike Hammond
X 2.
Mike Hammond
Old June 16th, 2013, 02:25 PM
Landy_Andy's Avatar
Landy_Andy
Andy
A few more little details worked out... headlight mountings, rear quick release mudflaps & hi-lift jack secured. All these little bits take the longest
Old June 18th, 2013, 10:26 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Rear mudflaps finished
Old June 18th, 2013, 05:09 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Starting to think about the custom dash build now.... sort of like this Tomcat F/G one & was thinking of making similar (LHD) to accommodate the Vintage Air A/C unit I have.... thoughts ?
Old June 19th, 2013, 10:23 AM
I have not tried to price stuff out but I am guessing you are better off just going with a stock setup and add a mud console or something.
90, d90, mod, rebuild
Multiple D90 Parts discojosh2000 For Sale - Parts 13 November 2nd, 2010 07:35 PM
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
Latest Mods to the D90 DiscoDino Defender Technical Discussions 10 July 6th, 2005 10:31 AM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
