D90 rebuild to 100" wb... plus a few other mods ;) - Page 2 - Defender Source
Old April 4th, 2012, 09:55 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Amazing quality behind your work. This is art.
Old April 4th, 2012, 01:19 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Originally Posted by ipgregory View Post
Following this with interest, keep the pics coming Andy. Especially the rear 4 link.
What are your plans for the front?
Ian
Front already has a Qt 3 link on it.... so for the time being that'll stay. Long term I might make some new tubular shock towers but for the time being now, not really a priority.
------ Follow up post added April 4th, 2012 10:21 AM ------
Thanks.... not too bad for an amature fab & welder
Old April 21st, 2012, 01:26 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Been a while since I got to work on the 90, had to get back to building works on our house now the snow has finally cleared & the outside temps got a bit warmer
The boss is happy(er) so, got the rear links tacked up & the axle trial fitted last night. Very happy with how it's sitting
Next to pull it all back out, finish the welding on the axle casing & links, paint it all & get it rebuilt into a rolling chassis. Going to concentrate on putting the cab back together next then & then work on the MS install.
Would be nice to be able to drive it out the shop for some spring cleaning soon as I want to get the floor re-finished & painted before it get too hot here.
ID:	50603   Click image for larger version
Old May 12th, 2012, 01:55 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Got some time last couple of weeks to get the axle finished up & check out the rear flex. Decided to go with 14" Bilsteins as I got them used at a good price, Set the droop so that the X-Eng 'X' springs are fully extended but still just loaded, then once I knew the approx top damper location checked the up stroke & with it sat on the bump stops. All worked nice & then finished welding up the brackets on the axle.
Now to shoot some paint and get all the fab'd parts and the bodywork colored up ready for bolting back together, the rear bulkhead doesn't look too bad for saying it was well & truly 'squadie' bashed by some brits at CFB Suffield
ID:	51478   Click image for larger version
Old May 12th, 2012, 07:13 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Thats going to be a monster.
Old May 20th, 2012, 11:16 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Finally got time to start rebuilding some of the cab... paint job is adequate for a trail truck, also need to find a replacent loom as the old ex-mil one is starting to show signs of significant deteriation
Old May 25th, 2012, 11:48 AM
Landy_Andy's Avatar
Landy_Andy
Andy
She's on 4 wheels again..... woo hoo
Name:	Rear Links 1.jpg
ID:	52138   Click image for larger version
Name:	Rear Links 2.jpg
Old May 25th, 2012, 06:03 PM
texrover's Avatar
texrover
Jason
Lets talk about that door suspended mid-wall in your garage
2003 RR L322
1971 Series IIA
1983 110 SW (Incoming)
1994 D90 ST (PO)
Old May 25th, 2012, 09:59 PM
Landy_Andy's Avatar
Landy_Andy
Andy
It's for access to a store / HVAC room with the whole house air exchanger in it.... when I have time I've got to make an access ladder...
Old May 30th, 2012, 10:41 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Got a start on the Megasquirt install last night, mounted the ECU into a stronger water resistant box & added some chunky MIL spec connectors
ID:	52361   Click image for larger version
Old June 2nd, 2012, 02:13 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Slow progress... waiting on parts & the replacement loom to arrive from the UK, so made a start on the new brake lines and began to get the dash back together ready for the wiring loom to go back in. More work on the Megasquirt to do next....
ID:	52476   Click image for larger version
Old June 3rd, 2012, 08:51 PM
I like it! I like the original VIN plate on the booster pedal.
Old June 4th, 2012, 12:43 PM
Grover's Avatar
Grover
Look'n good...
What headers are you using? Any modifactions to them for LHD?
Old August 6th, 2012, 02:55 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Originally Posted by Grover View Post
Look'n good...
There 'Double S' stainless steel, used to have a full system until I customised it.... just the headers & Y pipe left now. No issues with the LHD conversion as yet.
Old October 31st, 2012, 10:40 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Finally got some time to work on the D90 again, built a rolling lifting frame & got the front half of the cage sat back on the truck. Re-measured the old cage & new cage mounts then spent a while on Bend-Tech to get the new back cage started. Using the cage clamps to link the 2 sections should be plenty strong, esp with 9 points of connection once done. There is only 5" between the existing cab hoop & the new back one so the link tubes will be very short. Should make for a nice & rigid structure.
Hopefully get some time soon to bend up the new back hoop, can then work on the rest of the cage.
ID:	60036   Click image for larger version
Old October 31st, 2012, 10:48 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Also found some nice 7" wide 'Jeep' flairs that'll cover my tires from the existing body lines. There made out of a plastic that doesn't crack when flexed (well, that's what the sales blurb says but they get good reviews on other forums). Should work well & not look too out of place
ID:	60038   Click image for larger version
Old November 16th, 2012, 01:06 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Got some tube bent & welded up for the new rear cage hoop.... standard full cross with a centre support for a top winch hoop. Kept the new hoop tight to the back of the truck cab so the linking tubes to the origional front exo-cage are as short as possible. Once complete there will be 9 points of connection, so should be plenty strong enough.
Next to work on the rear tub framework to keep it looking like a D90 & not so much a tea tray
ID:	61032   Click image for larger version
Old November 19th, 2012, 02:19 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Rear tub framework started and a full wrap around tree slider tube added giving protection from the front of the doors right to the back of the tub now.
Next to continue on the rear tub framework and think about the front tubular wings.
Old November 21st, 2012, 09:35 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Looks good.
Mike Hammond
Old November 30th, 2012, 11:18 AM
Landy_Andy's Avatar
Landy_Andy
Andy
More of the rear skin framework done, gone for a sort of hi-cap look
The rear frames will have some large truck mud flaps hung off them on demountable brackets.
90, d90, mod, rebuild
Multiple D90 Parts discojosh2000 For Sale - Parts 13 November 2nd, 2010 07:35 PM
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
Latest Mods to the D90 DiscoDino Defender Technical Discussions 10 July 6th, 2005 10:31 AM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
