D90 From "Scratch" - Defender Source
Old February 8th, 2016, 12:03 PM
Boatdreamin
Jason Grigg
2001 Range Rover
D90 From "Scratch"
Hello All,
Greetings from NC in the USA! My name is Jason and I run a rather strange combination of a business that is a diesel repair shop, as well as a paint and body shop. We did a conversion several years ago of a NAS D90 from gas to a 300TDI, and it was a nightmare to say the least. I am a huge LR nut, but my 2001 Rangie is getting some age on her, and the gas mileage is abysmal. I wanted to run by you all my plans for a D90 to see what you all thought. What I'm thinking is to purchase a new frame with the 300TDI setup, and source a 300TDI and R380 transmission from abroad. Work on rebuilding the engine (if needed) and go through the transmission and get the drive line in the frame. I'm under the impression that the axles from a Discovery I will bolt right up. From that point I can work on getting the bits and pieces together for the rolling frame, that way when I can find a good D90 and I can basically take the body apart piece by piece, refurbish, and in the end have a pretty nice truck. I am well aware of the hours this is going to take, and if I didn't have my own shop I wouldn't even attempt it. I just kind of wanted to toss it out there to see if I am thinking down the right path, or if I should go another direction. Thank you all for your help in advance!
Jason
Old February 8th, 2016, 12:30 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Jason, mechanically all that is doable and there's nothing new or different about it. Personally it should be very rewarding. Economically will be a different story so you have to decide what the objective is.
Old February 8th, 2016, 12:35 PM
mmgcny
Michael
Go for it! Would love to see the pictures documenting the build process.
Old February 8th, 2016, 01:00 PM
Actually pretty straightforward, but I would mention that trim and other soft parts can be a huge variable depending on how nice you want the end product to be. Dashes and stuff run into big bucks fast.
Old February 8th, 2016, 01:41 PM
Does NC issue vin numbers or are you going to do a rebuild?
Old February 8th, 2016, 02:27 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
yes, Nc will do State issued vins if parts are properly documented. IE motor/chassis and body.
Old February 9th, 2016, 10:19 AM
35xj
dave rees
63. 88"
Im doing something similar. I used a discovery 1 frame and axles, ordered a 300 etc from the UK, but I'm using a series 2 body
Old February 9th, 2016, 10:26 AM
Sounds like the plan is coming together. I did pretty much the same thing but with alot of professional help.
The biggest issue is the dash. Still running with my temporary set up. Parts availability and their price is the issue. My advice to you would be to use a series III bulkhead which makes the dash easier than Defender while also being compatible with the Defender windshield.
Bodywork: between SafariHP, Rovertrader and Himalaya you'll probably be able to patch together what you need. You will have another big decision on the SW or HT v ST.
Old February 9th, 2016, 11:25 AM
This is a fool's errand. Much better to start with one or two donors to build off of as finding all the little bits and pieces will drive you insane. Even putting together a roller is a challenge. If you start with a disco I as a donor and a new frame, that would be reasonably possible, but what about the fuel tank lines etc etc etc.
Old February 9th, 2016, 12:04 PM
I agree with Ron. I have built Land Rovers form the ground up and done "bits" builds where parts from many became one.
I was about to do the same to create a Tdi 90 when suddenly it became 2009 and the first ones were 25 years old. So I ditched most of the parts and imported a running, driving truck for less than I had into my pile of parts. Sold it all and kept the drivetrain which I put into my 90 and didn't look back.
I have a friend who has a great quote that I am constantly reminded of. "It's a lot easier to fix the broken, than the missing."
YMMV...
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old February 9th, 2016, 12:34 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
To build from Scratch your talking ECR money, the L-R 90 I am running now was a day old MOT failure due to rusted out chassis. The kid had fitted new seats, rebuilt ashcroft gearbox, and a new style diesel engine in it plus all the other little goodies fitted. Shipped it and drove for a year than fitted a new galvenized chassis. I will say the new chassis cost more than the Landy did. Before shipping costs.
Yes Old Red needs a paint job but it's 100% underneath. My budget was 10k to get it as a good runner of which I went over by 1k. Yes I have added some bits not included in the runner budget but I pled the 5th on how much. The wife is a member of this forum
But Good Luck on your quest and welcome to the Defender Source
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old February 9th, 2016, 01:03 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Agreed,
You are much better off purchasing a 'tidy' interior 90/110 and then buying the chassis and drivetrain you want and do it in one go. Having a chassis sitting while you search for parts or try and build one from scratch is going to be painful.
There are all kinds of little things you don't even think about that are NLA or impossible to come by, might as well start with something that may need a bulkhead or a frame and replace as necessary
Old February 9th, 2016, 04:11 PM
Boatdreamin
Jason Grigg
2001 Range Rover
Ok I see what you're saying. I guess I was trying to get everything ahead of time before I actually got the vehicle I was looking for. I wonder, at the least, if it would be worth finding the 300TDI and the R380 Gear box and having that gone through before I find the actual Defender? From what I have seen finding one with a 300 is pretty difficult.
Old February 11th, 2016, 04:29 PM
Boatdreamin
Jason Grigg
2001 Range Rover
Can you all recommend a place to source a 300TDI and gear box? I've been emailing back and forth with a couple of salvage yards in the UK, but nobody really wants to send me a firm quote. I would really like to deal with someone that comes with a good reputation.
Old February 11th, 2016, 05:22 PM
roverman2010
1985 LR 90 200Tdi
You could try Rovers North sometimes they have some stock.
As for the gearbox and transfer case you can get overhauled units from ASHCROFTS in the UK they send to the US all the time.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
90, d90
300 tdi auto scratch build Gren_T Truck Build-up's & Restores 47 April 11th, 2011 06:18 PM
D90 from scratch, need minor parts and a heater rgrrvr Wanted 2 January 9th, 2008 10:12 PM
scratch built roof bike rack mspell Defender Technical Discussions 17 March 23rd, 2005 08:40 PM
Scratch and Dent Trail - Colorado USA chrisvonc Trip & Trail Reports 0 June 19th, 2004 09:39 AM
Scratch and dent bonnet ronward Wanted 2 January 13th, 2004 11:32 PM
