D90 Build - Defender Source
Old July 9th, 2013, 12:11 PM
rovermech
Tom Griggs
96 D1
D90 Build
Just thought I would share a few pictures of a D90 build that we just finished for a customer of ours. First off we took it down to the frame which was painted. All new bushings underneath. 1 inch lowered springs were installed. Slotted and drilled DBA rotors were installed. All brake lines were replaced with stainless steel lines. All of the rubber lines were also replaced with braided hoses. Transmission was rebuilt. 3.9 ring and pinions along with Detroit Truetrac's installed in the diff's. A 320hp 5.0 liter engine from ACR was also installed. A radiator and coolant reservoir from Allisport. Along with dual electric fans and a Ron Francis dual fan controller. A custom 2 1/2 inch stainless steel dual exhaust was also built for it using 2010 high flow Camaro cat's. Ceramic coated header's were also installed.
On the body work a puma hood and grill were installed. A custom grill with Black Magic Hella's were also done. Stainless steel side steps were custom built for it as well. A second fuel tank was installed with an electric transfer pump to pump fuel from it to the main tank. A second gas filler was also put in to match the original one. The interior was all sound proofed. A custom front bumper was also built for it. The customer had the wheels also built.
We also installed electric windows and door locks along with seat heaters. The windshield was replaced with a heated windshield. Also we replaced the clearance lamps with clear freelander lamps. The sunroof was also replaced with a metal escape style hatch. I know I have forgotten a couple of things that I will add when I remember them.
ID:	75574   Click image for larger version
ID:	75576   Click image for larger version
ID:	75578   Click image for larger version
ID:	75580   Click image for larger version
Old July 9th, 2013, 12:19 PM
Interior pics?
Old July 9th, 2013, 12:37 PM
rovermech
Tom Griggs
96 D1
Interior was left mainly stock except for raising the passenger seat up to clear the filler neck for the second tank. A mud uk rear door panel and an aftermarket steering wheel.
ID:	75585   Click image for larger version
ID:	75587   Click image for larger version
Shop Manager At GBR.
Old July 9th, 2013, 01:01 PM
rovermech
Tom Griggs
96 D1
Early video of the exhaust after it was finished.
d90
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
95 D90! TwisteD90 For Sale - Vehicles 30 September 14th, 2005 02:54 AM
Advice on buying my first D90 mtbrooks Defender Technical Discussions 7 July 19th, 2005 07:48 PM
