D1 to D90 - Page 6 - Defender Source
Old May 18th, 2015, 04:31 PM
Chris B
72 + D1 drivetrain =?
Well the pesky no start scenario that started (!) at WR may well have been due to the remote mounted GM amplifier that simply isn't up the job in the Rover environment. We now have a good consistent start, but it now when warm stalls out at idle after the revs get lower and lower. IAC valve seems ok.
Of course when you get to spend quality time under the hood, you notice other things. Wasn't too happy with the cooling last summer and the noises from the water pump put that on the next order list. Looks like ABP has the the closest thing to genuine possible. So that's up next.
Old June 2nd, 2015, 10:18 PM
Chris B
New Starter check, I'm going to put the rebuilt but whiny alternator into my parts bin.
Decided to rename it. Originally Nigel, it became Nigella and now its just Ella. Has to be a woman, because she only hints at whats wrong, so you fix it and discover that's not really the solution.
Old July 3rd, 2016, 07:37 AM
Chris B
A year or so later and alls well. With one exception. I've been slacking and need to work on the truck. Done a few little jobs like seat box lids, tire carrier, started trunk space bed mat etc.
Last night I tripped over some tie downs I'd bought for my D1 long ago.
Your question to start the day, should I use Aluminum bolts to secure them to the rear tub rather than SS or galvy bolts? Or am I overthinking the dread galvanic corrosion curse?
Old July 3rd, 2016, 07:56 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
The early ROWs I've seen don't seem to have the problems the NAS trucks do. I think if you prep the surfaces the SS will be fine.
Old October 1st, 2016, 02:13 PM
Chris B
A tad inconvenient when you are driving along in the rain and the entire wiper arm flies off. Fortunately, after walking the street and not finding it, (thinking its time to order another from RovahFarm) I spotted it caught between the hood and raised heater intake. Looking at the other one, it's pretty clear I hadn't properly secured with of them on the shaft. A quick tap with a SFH (small frigging hammer) makes this the easiest repair in a while.
Old October 3rd, 2016, 09:35 AM
FlyersFan76
1987 110 Convertible
That happened to me once or twice. Fortunately I had RainX and could still see.
2011 Range Rover Sport
1987 Land Rover 110 Cabriolet
1997 Defender 90- AA Yellow #1701- Wrecked
1997 Defender 90- AA Yellow #?- Sold
2000 AM General Hummer- Sold
Old July 31st, 2017, 08:42 AM
Chris B
Haven't posted in a while. Been running pretty good with the exception over Memorial Day when it started to miss and bog down. I was doing a ton of short distance trips in pretty warm days. It started after I filled up. Stopped after it dawned on me that it might be bad fuel and I refilled with half a tank.
Dynamat is finished on the roof. Definite difference. I need to find the DB I recorded pre dynamat, but now its registering 86-88 while cruising at 50. More if I open the BH flaps. Iphone app.
Old October 2nd, 2017, 11:51 AM
Chris B
Added a safari equip tank for better range. Plus front door stays next up door cards.
Old February 10th, 2018, 11:48 AM
Chris B
The new VDO instruments look incredible. Have to button up the project quick if Winter Romp is going to happen!
90, d90
Multiple D90 Parts discojosh2000 For Sale - Parts 13 November 2nd, 2010 06:35 PM
Wolf wheels, D1, D2, D90 parts (free) Tom B For Sale - Parts 10 August 13th, 2008 12:11 AM
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 09:34 PM
D90 won't start! rover4x4 Defender Technical Discussions 32 June 13th, 2005 07:42 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 08:54 PM
