D1 to D90 - Page 3 - Defender Source
Old August 19th, 2013, 07:48 PM
Chris B
72 + D1 drivetrain =?
Cats from the D1 fit very nicely.
Old August 27th, 2013, 06:42 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
How much more is left? Estimated finish time? Looks good so far.
Old August 28th, 2013, 05:01 PM
Chris B
Fuel lines brake lines all electrical. Exhaust system finish Seat box repair and refinish.install seats door seals
Right now want to get it mobile under own power so we can move it off the hoist. It's been taking second place to other work.
Want it registered and street legal ASAP.
Old August 31st, 2013, 04:33 PM
Chris B
Access can be tricky
Old September 22nd, 2013, 08:35 AM
Chris B
Ok model T gone. Brake bits and a few other items ordered from RovahFarm. Brake lines fuel lines plus exhaust by end of next week may be possible.
Hoping to start on electrical soon. Other bits from RovahFarm include the combo switches etc.
Old September 24th, 2013, 06:22 AM
Chris B
Got distracted. Added an aftermarket cooler. Exhaust and fuel lines while waiting for parts from Rovahfarm. Hurry up UPS.....please!
Old October 3rd, 2013, 05:40 PM
Chris B
Why does one top radiator bracket cost $9, and the other one over $60. Thats nutz. Stole brackets off D1 to modify. YRM had galvy ones but none in stock. Working front to back. So ordered hood prop and cable plus accelerator bracket etc. Decided on placement for ECU and how to do metal dash.
Old October 28th, 2013, 11:18 AM
Chris B
Rear Door mounted after drilling new holes in it rather than the bed. Locks fitted so doors latch. Had to open up the key hole on one door that had been drilled wrong by a few mm. Grr.
Old October 28th, 2013, 01:28 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Are you doing a full custom dash ? Still throwing ideas around for my D100 build.... interested to see what you come up with.
Old October 29th, 2013, 04:21 AM
Chris B
My one mistake or biggest one to date is not getting a series BH. So what we are doing is locating the Ecu high up on the BH in front of the passenger shielded from water ingress. Instruments will be centrally located together with switches and power outlets. These will be on a platform with two fuse boxes located behind. One fusebox powered the other switched.
So it end up pretty series like. Roverx used a series dash on his truck and it looks great.
Old October 29th, 2013, 09:32 AM
Landy_Andy's Avatar
Landy_Andy
Andy
OK.... I've got a Vintage Air A/C unit that I'm going to install in place of the std. fan, so will be doing a full dash to hide it. Will also be mounting the Megasquirt in front of the passenger too once I have the dash vents secured closed.
Old October 29th, 2013, 08:19 PM
Chris B
Contact roverx he pulled his heater and dropped in an AC when he moved to TN. Bought his kodiak off him.
Old November 15th, 2013, 01:14 PM
Chris B
Trucks moved back inside the shop and can be worked on.
Brake lines plumbed in.
Tunnel fabbed up and is in the current rough form, needing some fettling for final fitting. Once that's final its on to the floor sections and then some seat box repair.
Seat box is from an early Defender or 90/110 and needed trimming to accommodate the LT230/Auto combination.
Once those steps are done, then the box, tunnel and floor will be removed, sanded and prepped for primer and paint.
Name:	Tunnel of Love.jpg
Old November 25th, 2013, 06:13 PM
Chris B
Got rear badge for the truck for when its ready, registered and on the road again. Frankly its dang nice,
http://www.falon-nameplates.co.uk/lr...niumplate9.jpg
Old November 25th, 2013, 06:35 PM
BlackField's Avatar
BlackField
Oscar
D110
I just emailed rovers north about that same badge!
What's this pay by check craziness?
Old November 25th, 2013, 07:31 PM
why not just use the regular V8/300tdi style tunnel cover??
That little side box on the tunnel of love looks like quite a sharp corner? Is there any room to round that off? Maybe with a stamped aluminum bread pan or some such?
-Jeff
Old November 25th, 2013, 09:27 PM
Chris B
I picked up an early defender seat box for short money and modified it to clear the box combo.
Have to take another look to see how much clearance we have under that squared off section.
Current plans call for painting that section and tunnel. But I also expect some dynamat or similar plus probably some bed carpet/mat over the soundproofing.
But soundproofing can wait. Finishing truck matters more.
Old December 24th, 2013, 06:40 PM
Chris B
Well gettng to WR 2014 isn't happening. Got bumped out from the shop to get a FC101 converted to Isuzu Turbo diesel/R380/LT230. Debugging that is in progress.
Old January 16th, 2014, 06:31 PM
Chris B
Ordered up a set of instruments today and a new ignition amplifier from Ericxtn231.
Anyone in the area girly a serpentine bent trey replaced handy? Want something for shop use and checking alignment of all the bits. It's been a while since the engine ran....
Old January 25th, 2014, 06:04 PM
Chris B
Correction: Instruments were not ordered from Ericatn231. Ordered a set of Autometer from Summit.
90, d90
Multiple D90 Parts discojosh2000 For Sale - Parts 13 November 2nd, 2010 06:35 PM
Wolf wheels, D1, D2, D90 parts (free) Tom B For Sale - Parts 10 August 13th, 2008 12:11 AM
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 09:34 PM
D90 won't start! rover4x4 Defender Technical Discussions 32 June 13th, 2005 07:42 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 08:54 PM
