D1 to D90 - Page 2 - Defender Source
Old January 18th, 2013, 05:20 PM
Your right. It's time! Btw Matt cleared the fenders. So that leaves just the rear body and HT sides to do.
Old January 18th, 2013, 05:21 PM
Fir some reason I took this one today. Perhaps to show off the d90 tow hitch. Pintle not included.
Old January 25th, 2013, 03:29 PM
Installed temporarily the seat box ad front seats. Decided to adjust the steering column to give my 6ft2 Neanderthal frame more comfy driving position. Marked it up and over to my guy to make up the bracket.
Old January 31st, 2013, 04:46 PM
Not much progress in last week. But sometimes thats the way it goes.
ID:	65523   Click image for larger version
Old January 31st, 2013, 09:09 PM
WD90's Avatar
WD90
Dan
1995 NAS Defender 90
Your truck is looking great Rocky!
Old February 6th, 2013, 07:04 PM
Having joined the membership of SCOT* tow hitch is now on correctly. Fuel tank guard notched etc.
time to buy some parts.
* Stupid Current Owner Tricks
Old March 5th, 2013, 04:10 PM
Pulled out the Kodiak heater and parts to figure out how to mount. Thanks to Will T for the Heater fender duct. Should be easy to connect the two. Steering column bracket fabbed up by BDR. Slight customization to allow for large driver.
Old April 2nd, 2013, 08:06 PM
Need to order a radiator, hoses and serpentine belt etc. we need to get this thing ready!
Old April 17th, 2013, 03:04 AM
Just waiting for a collection or rather delivery of parts inc radiator etc. modify the d1 exhaust to fit which will be interesting. Hoping to get this sucker up and running at least around the shop yard.
Rear tub is NAS puzzled by the way lowest hinge for the HT full height door doesn't match with holes on the door. Door is old and limited life span so will probably add a strengthen piece to the door where the hinge wants to line up.
Old April 23rd, 2013, 08:12 PM
Radiator check slam panel check power steering and oil lines check fenders bolted on check pulling ECU radiator fan expansion tank power steering reservoir from parts bin
Figuring out what you still need priceless.
Old May 2nd, 2013, 07:33 PM
Actually its just expensive...
Here is Nigel in good company.
Old May 6th, 2013, 11:14 PM
Adding air intake, kick down cable oil cooler lines, brake pedal box and accelerator in ups truck as are flexible brake lines. Better stick them on.
Old May 7th, 2013, 07:52 AM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Rocky, where are you in Ma? This is a great thread, love the progress. Jealous of the skills you have to put this all together....
Josh in Maine
Old May 7th, 2013, 01:48 PM
Josh in Maine
Josh:
I'm not taking the credit for much of the work here. Its being magiced together by Brian Rossini at BDR Auto in Holliston.
While I started, wrenching once I realized that my skills were minimal v his, it was better to wave the white flag and have him do it right the first time.
Haven't been to Brunswick for a year. Wife is a Bowdoin grad.
Old June 19th, 2013, 10:55 AM
Looking for the right Hand brake assembly for my D1 to Defender project. It's the interior part that had us puzzled.
Like everything seems to be a variety of options. Whose figured this out?
Old June 23rd, 2013, 08:53 PM
A little behind, so a quick clean up and respray of the axles. They look good and its nice to get something done that doesn't take forever.....
Old June 23rd, 2013, 10:54 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Don't you need to just pick up a defender handbrake lever? I took a d1 handbrake and shortened it so it would only an inch or two above the top of the seatbox, bolted right beside the seat. But I never used it. I liked that it wouldn't interfere with leg room, but decided not to use it for originality's sake and that I wouldn't be able to fit a cubby.
I ended up taking a RHD defender hand brake lever and re-fabricated it into a LHD lever.
Old June 29th, 2013, 01:51 AM
Surprising the dents both diffs sustained before I added southdown
Old July 8th, 2013, 04:04 PM
Driveshafts are bolted in. Cross member modified from D1 to 90 spec. Waiting for vendor to send correct mount. D2 doesn't work.
Old July 14th, 2013, 05:10 AM
ZF Filter etc change. Might as well as we're there and it was overdue before it died.
Crossmember modified. The D1 chassis isn't as deep as the Defender chassis so the bottom two mounts are in a different position. Welded tabs extending the mounting to match. Repainted
Two new Transfer/Gearbox mounts fitted and installed.
90, d90
Multiple D90 Parts discojosh2000 For Sale - Parts 13 November 2nd, 2010 06:35 PM
Wolf wheels, D1, D2, D90 parts (free) Tom B For Sale - Parts 10 August 13th, 2008 12:11 AM
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 09:34 PM
D90 won't start! rover4x4 Defender Technical Discussions 32 June 13th, 2005 07:42 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 08:54 PM
