Conversion Project - Page 9 - Defender Source
Old August 26th, 2012, 09:48 AM
Originally Posted by Ren Ching View Post
Cool when he gets to the window tracks you should see if you can get some of that lovely Yorkshire moss to grow in the VA countryside. Could be a new source of revenue for Dividing Creek Worldwide Industries™
Bleached that on arrival. May change out the roof sides. I have several sets but thats up to Trey.
------ Follow up post added August 26th, 2012 10:48 AM ------
Originally Posted by evilfij View Post
Let's see pics of trey's 110.
He says not yet. He seems torn on keeping it all original 83 or modernizing it, besides this is Bill's thread.
Old August 26th, 2012, 08:53 PM
Oh yeah. I checked the flipped turbo thing and I believe it will work out wonderfully. The plumbing needs some modification. The exhaust down pipe will also need a custom solution but neither of those is too bothersome.
Old August 29th, 2012, 05:55 PM
How do you eat an elephant? One bite at a time
Before:
During:
ID:	56738Click image for larger version
After:
Originally Posted by pendy
I'm here for the D's
Old August 30th, 2012, 11:38 AM
grnrvrs's Avatar
grnrvrs
Paul
88
Do you have window shades, baseboard trim and contrasting wall/ceiling paint in your garage, or do you usually load trailers in the living room?
1970 SIIA 88, Sold
Old August 30th, 2012, 06:06 PM
Garage. The labor was cheap and usually if I bother doing something I try do it right.
Old September 16th, 2012, 07:36 PM
Anti Roll (sway) bars yes or no?
While I still have the chassis upside down, I was wondering if it would be worth while to install mounts for anti roll bars. Would it benefit other than making it corner on the road a little flatter? Assuming I drive knowing that it might wallow a bit, any reason to go to the trouble or should I just go ahead and flip the chassis? Yes it could be done later on, but right now it's so good to work on it.
BTW 6 bald eagles spotted today. Two in my yard yesterday morning, one this morning.
Old September 16th, 2012, 09:29 PM
cant hurt to weld mounts on.
Old September 17th, 2012, 09:24 AM
Next question. It looks like I will be fabbing a new tank from glass/epoxy. The old tank is slightly offset to the right I suppose to account for either the PTO shaft or maybe the exhaust pipe. I think I'll add a little more width/capacity to the tank. Has anyone ever made a tank in a similar manner?
Old September 17th, 2012, 11:14 AM
The tank is narrow for the exhaust. I have only seen custom SS tanks. Given the shape of the tank, I would think it would be easist to make out of metal, but what do I know. The other issue is what do you do with the filler pipe.
Old September 17th, 2012, 02:23 PM
Agreed on the mounts, and second a SS tank
Old September 17th, 2012, 03:49 PM
Well, I have scads of cloth and resin and zero steel. I'm going to replicate it but pooch it just a bit. I can get FRP angle for the supports.
Old September 17th, 2012, 07:21 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Two things. I have seen factory rear tanks that were sectioned to allow for a pto. and a guy on on G&R is looking to have a shop make up some saddle tanks and I think rear tanks out of aluminum. The more that sign up the less it will be. Saddle tanks will have a slightly different shape to ease production and also looking to produce long range saddle tanks.
Current thread:
http://siteground237.com/~gunsandr/s...num-Fuel-Tanks
Previous thread:
http://siteground237.com/~gunsandr/s...eat-Fuel-Tanks
Old September 17th, 2012, 07:48 PM
Full up it will weigh about 150Lbs, so not super heavy. Pretty sure the 'glass tank will be just fine. I might even put in a baffle inside.
I think I will build it by first laying up two or three layers of cloth in sheet form, and cutting out the shapes from this thin stuff. Then to build the shape I start tabbing it together, fillet the inside joints, glass the fillets, and then just go at it layering it up. It's a box fer crissakes.
The fill tube I can make from FRP tube. 'Bout 12 bux for a 4 foot piece.
Old September 20th, 2012, 05:59 PM
Picked up the primer'd door skins and frames from the paint shop. Got them skinned and rivetted.
Will drop them back at paint in the morning, then move on to the other bazillion things to do...
Old September 21st, 2012, 01:35 PM
Maybe I've been working alone too long, but this looks like a face
Old September 21st, 2012, 01:48 PM
I thought you were going to the Conclave?
Old September 21st, 2012, 02:39 PM
Just not that into the conclave at present
Old September 22nd, 2012, 10:59 AM
Set heated glass
Old September 22nd, 2012, 06:12 PM
Got the axles under the frame.
Old September 22nd, 2012, 06:47 PM
Got the axles under it
conversion
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 11:58 AM
Advice on chassis and engine conversion project Rovermn Defender Technical Discussions 0 August 12th, 2008 09:08 AM
94 Yellow ST Project $12k/offer Colorado dnewman9 For Sale - Vehicles 9 January 20th, 2006 07:34 PM
Disco/Defender Hybrid Project RedRhinoProducts For Sale - Vehicles 3 December 11th, 2005 08:14 PM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 03:01 PM
