Conversion Project - Page 36 - Defender Source
Closed Thread
Old March 6th, 2017, 07:18 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by o2batsea View Post
Getting the bulkhead back in order. Installing sound deadening material and hardura. The nice thing about having a galvanized bulkhead is that you can solder stuff to it. Soldered on the tabs to hold the MLV and foam.
it's polite to accompany with copious pics of your progress old man
Old March 6th, 2017, 09:55 AM
Rover Lover's Avatar
Rover Lover
Ron Dade
97/D90 Soft Top
Clay, perhaps it helps to say PLEASE in Mandarin!
  #703
Old March 6th, 2017, 10:05 AM
In these pics you can see the soldered-on tab bent up to hold the insulation in place. No glue or anything so it's easy to remove later. TThis is just behind the dash panels where it will not be seen. For the conspicuous places I'll use something less caveman.
I will also use brass flat head machine screws in some places. I can use a nut or a automotive mushroom type headliner fastener like they use on the RRC carpet. Note the addition of another soldered on tab between the das and the door post. This is a finisher for the little bit of hardura and sound soak that goes in that little space. It's just a detail I added.
请和谢谢!
ID:	215113   Click image for larger version
ID:	215129   Click image for larger version
Old March 6th, 2017, 10:13 AM
1of40's Avatar
1of40
1of40
请和谢谢!
Спасибо
  #705
Old March 6th, 2017, 08:12 PM
Wait, no paint?
Sweet! I have been looking to see how that will look with an all metal dash :D
Originally Posted by pendy
I'm here for the D's
  #706
Old March 6th, 2017, 08:32 PM
Decided to skip paint for a number of reasons. First, not painting saves a huge amount of time and money. Second, paint fails and the consequences are massive and expensive. Third, you don't have to be careful around the bare galvy.
  #707
Old March 7th, 2017, 06:51 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I love the bare galvy look so agree with the decision. And those are great reasons too.
The tab with the hardura looks great. I may do that on the lower insides of my bulkhead. Who was your supplier of the material?
  #708
Old March 19th, 2017, 10:01 AM
Factoid's Avatar
Factoid
Mark
Three criminals seeking revenge
Wonderful build, Bill!
Just spent the morning reading the thread when I'm supposed to be in the garage dropping the 300tdi in my Series III. Just need to paint the front prop shaft and replace the front TC seal.
Thank you for the superb motivation!!!
Ready for insertion:
ID:	219865   Click image for larger version
1976 Series III 109 "Montoya" ("You killed my father, prepare to die")
1988 Defender 90 LHD "Vizzini" (speed demon from Sicily)
1987 Defender 90 MOD LHD "fezzik" (giant rock thrower)
2015 MB CLS63
1975 Porsche 911 hot rod
1964 Porsche (Beck) 904
  #709
Old March 21st, 2017, 06:49 AM
Hey this is MY build thread! Hahaha Looks great! Keeping the rod linkage? I did. My biggest problem is air filter box. I am so out of room under the bonnet!
  #710
Old March 21st, 2017, 06:38 PM
Factoid's Avatar
Factoid
Mark
Oops, but I have so little to share!
I'm going to try to keep the mechanical linkage. Were you able to use the original cable and link it to the IP? I did order the heavy duty relay you recommended. Good find, thanks!
2015 MB CLS63
  #711
Old March 22nd, 2017, 09:43 AM
Made a rod to go to the IP. No need for cable
  #712
Old April 6th, 2017, 12:55 PM
Factoid's Avatar
Factoid
Mark
Great, thanks!
Bill, do you have the pin out/wiring diagram for the new glow plug relay/timer?
2015 MB CLS63
  #713
Old April 6th, 2017, 01:47 PM
uh, lemme look around on my computer.
  #714
Old April 29th, 2017, 08:40 AM
Cutest package ever!!! Got this from a seller in Thailand it has a Lucas push start switch in there. Can't bring myself to open it!
  #715
Old May 17th, 2017, 08:04 AM
Updating.
The footwell insulation project took a major technical hit over the weekend. Apparently my aged (free) Singer machine is not up to sewing heavy vinyl Hardura. I kept busting thread and it wouldn't feed thru cz the hairy back would just confound the feeder. Also the vinyl edging I bought would go all cockeyed. So I gave up on sewing. It will have to be glued. I have the HH-66 Vinyl cement that I got from the soundeadenershowdown.com guy. Tested it and this works great at gluing the vinyl edging to the hardura. Unfortunately i hit upon this happy combination far too late in the day on Sunday so I had to put that aspect of the build on hold until next time.
The very expensive A/C compressor that I ordered from LRdirect arrived. Excitement was high as I tried test fitting it to the 300, but was instantly thrown into a fit of depression when I found it didn't fit. Ugh! So I either have to source anew the correct pump with the offset bolt holes, or make a new bracket for this pump so that it'll work. Heavily leaning towards the latter as I don't want to face yet another delay of who knows how long finding the proper part. (Side note: this scenario has played out over and over and over in the course of this build and I am so tired of it)
Cleaned up a ton of smalls, like soldering little discs of galvanized steel over the now-empty holes in the bulkhead where rivnuts used to be. Organized my wiring and staged it for creating the (fourth iteration) main harness.
So the punch list is no shorter after 3 weekends. I accept that this is the nature of things, but boy I am so ready to have this thing back on the road.
  #716
Old May 17th, 2017, 10:59 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Updating. The footwell insulation project took a major technical hit over the weekend. Apparently my aged (free) Singer machine is not up to sewing heavy vinyl Hardura. I kept busting thread and it wouldn't feed thru cz the hairy back would just confound the feeder. Also the vinyl edging I bought would go all cockeyed. So I gave up on sewing. It will have to be glued. I have the HH-66 Vinyl cement that I got from the soundeadenershowdown.com guy. Tested it and this works great at gluing the vinyl edging to the hardura. Unfortunately i hit upon this happy combination far too late in the day on Sunday so I had to put that aspect of the build on hold until next time. The very expensive A/C compressor that I ordered from LRdirect arrived. Excitement was high as I tried test fitting it to the 300, but was instantly thrown into a fit of depression when I found it didn't fit. Ugh! So I either have to source anew the correct pump with the offset bolt holes, or make a new bracket for this pump so that it'll work. Heavily leaning towards the latter as I don't want to face yet another delay of who knows how long finding the proper part. (Side note: this scenario has played out over and over and over in the course of this build and I am so tired of it) Cleaned up a ton of smalls, like soldering little discs of galvanized steel over the now-empty holes in the bulkhead where rivnuts used to be. Organized my wiring and staged it for creating the (fourth iteration) main harness. So the punch list is no shorter after 3 weekends. I accept that this is the nature of things, but boy I am so ready to have this thing back on the road.
This sounds so much like the stage I am at. The 110 is "done" save for the final items but they have been a battle. The 80/20 rule has rung in my head so much the past year.
  #717
Old July 16th, 2017, 05:35 PM
Wiring wiring wiring. Ugh. Here is the slick little seat heater button bracket I made for the rear passengers. One on each side of course...
***Sorry about the dirty floor***
Name:	Seat Switch.jpg
Closed Thread
conversion
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 11:58 AM
Advice on chassis and engine conversion project Rovermn Defender Technical Discussions 0 August 12th, 2008 09:08 AM
94 Yellow ST Project $12k/offer Colorado dnewman9 For Sale - Vehicles 9 January 20th, 2006 07:34 PM
Disco/Defender Hybrid Project RedRhinoProducts For Sale - Vehicles 3 December 11th, 2005 08:14 PM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 03:01 PM
