Conversion Project - Page 34 - Defender Source
Old August 13th, 2016, 09:50 AM
What crossmember ? There isn't any under the trans
Old August 13th, 2016, 12:29 PM
was wondering why you put the trans in separately ?
Old August 13th, 2016, 05:16 PM
Trans locates the engine. Welding in new motor mounts. Had to fit engine to get location of where to weld.
Old August 15th, 2016, 07:10 AM
Engine mounts in!
Old August 15th, 2016, 08:28 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Originally Posted by o2batsea View Post
Engine mounts in!
No gussets? Or are they just hidden underneath?
Old August 15th, 2016, 09:17 PM
Adrian those mounts I got from Mark Garrenton. I have no idea where they came from but they have plenty of weld surface.
Thing is that now the engine install will be slightly more difficult in that there won't be room to drop the engine in v the bulkhead. I'll prolly have to unbolt the mounts from the engine, place the engine on the trans, then bolt the mounts on the block.
Old August 15th, 2016, 09:34 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Adrian those mounts I got from Mark Garrenton. I have no idea where they came from but they have plenty of weld surface. Thing is that now the engine install will be slightly more difficult in that there won't be room to drop the engine in v the bulkhead. I'll prolly have to unbolt the mounts from the engine, place the engine on the trans, then bolt the mounts on the block.
Shouldn't be that bad. Just jack up the front of the tranny until you get it mates with the engine then drop the whole thing down on the mounts. When I swapped a 2.5td for a 200 on my old 90 I remember being surprised how easy it was to get it all lined up and in. Maybe I just got lucky though
Old August 15th, 2016, 09:47 PM
Yeh the 300 mounts are much further back.
Old August 15th, 2016, 10:54 PM
carlosz's Avatar
carlosz
Carlos
Bill may be too late for my suggestion or you may have looked into it and found it would not work on your project, the santana 12j to 300 tdi conversion I was working on, we kept the lt77.
the vehicle's owner located a 12-19j to 300 conversion kit which, included relocation plates for the engine mounts, exhaust, oil switch, bell housing drill pattern and spare studs and instructions.
it worked like a charm, clean straight bolt on kit. came out of the uk.
the truck ran like a "raped ape"
A fussy warm weather creature...
Old August 16th, 2016, 06:55 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Carlos... Was this the kit... https://www.steveparkers.com/convers...s-land-rovers/
Old August 16th, 2016, 07:36 AM
Carlos, I have no idea what you're talking about. That's a Ashcroft Stumpy R380, not LT77.
The mounts are in, engine ready to drop. Going to put it all back together and get on the road
Old August 22nd, 2016, 10:50 AM
Rover Lover's Avatar
Rover Lover
Ron Dade
97/D90 Soft Top
Bill, I guess the silver lining to needing to pull the bulkhead is that the engine/tranny install just became a cakewalk!
Old September 6th, 2016, 09:06 PM
Ok here I am backwards now about three years in time. Bulkhead going to blasting tmr. Galvy run maybe later this week. Then reconstruction. This sucks but it must be done. Click image for larger version
Old September 6th, 2016, 09:10 PM
Damn, that's pretty extreme! Where are you going for the galvy run? I have a few tiny pieces I need to get done.
Originally Posted by pendy
I'm here for the D's
Old September 7th, 2016, 08:25 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
You'll be happy you did it. Youre officially Galvy Bill.
Old September 7th, 2016, 11:00 AM
Bulkhead dropped. Pick up tmr. Meanwhile doing a few odds and ends ( like completely redoing wiring ) and making kayak ramp
Old September 7th, 2016, 11:10 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Ouch. What happened to the wire harnesses you just built? The fire was on the RRC.
Old September 7th, 2016, 11:15 AM
Contractor's Avatar
Contractor
Will
1969 IIA
Dang, maybe I missed it but why are you pulling the BH to galvanize it at this point?
Old September 14th, 2016, 01:59 PM
Rover Lover
Ron Dade
97/D90 Soft Top
Bill, perfect time to deal with what you found on the BH. After all, the engine was out and the bonnet and wings not in the way. Hope this attempt goes better. Such a shame the previous did not hold up better. I know it's frustrating.
Old October 24th, 2016, 08:07 AM
Fitting up vent thing to find where to poke the big hole
Literally like butt welding a beer can
Fitting plenum to BH
The hole!!!
Making the sides
And done-ish
So the vent thing will fit to the bulkhead and the heat/AC box goes on the outside of the BH with a huuuge Jabsco 4 inch blower mounted somewhere.
The vent box will get a couple coats of satin black and a pad made from Hardura mat. Controls mount ? Dunno quite yet.
------ Follow up post added October 24th, 2016 08:12 AM ------
Oh yeh you can't see it but the vent opening is indeed closed in all the way around.
------ Follow up post added October 24th, 2016 08:13 AM ------
All going to galvy tmr
conversion
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
Advice on chassis and engine conversion project Rovermn Defender Technical Discussions 0 August 12th, 2008 10:08 AM
94 Yellow ST Project $12k/offer Colorado dnewman9 For Sale - Vehicles 9 January 20th, 2006 08:34 PM
Disco/Defender Hybrid Project RedRhinoProducts For Sale - Vehicles 3 December 11th, 2005 09:14 PM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 04:01 PM
