Conversion Project - Page 25 - Defender Source
Old March 31st, 2014, 07:45 AM
Doncha love how all the paint is coming off the inside of the bulkhead? The guys that painted it left it outdoors and it got white oxide all over the exposed areas. They didn't clean that off just shot it with paint and now....
I will probably just scrape it all off as best I can and put the Hardura over it and say done.
Old March 31st, 2014, 01:21 PM
aka rover's Avatar
aka rover
ed angel
95 D90
That sucks about the paint :-(
But this is one very cool rig you have built !
Keeps my momentum up on my project to look over here at your thread .
85 D110 3.5 3 DR
Old April 14th, 2014, 11:53 AM
Won't win any contests for beautiful welds, but it won't leak and it fits pretty good.
Got the remaining exhaust placed and sorta tightened up. I need to fab some hangers.
The muffler is kinda wonky. The pipes have some rather inexplicable bends. If I hadn't already spent the money, I coulda done as good a job with off the shelf mandrel bends. I think I may delete this muffler as it has to sit up in there pretty weirdly cocked in order for the pipes to line up halfway right.
I woulda tried to get it running but I ran out of time plus I was lacking an oil filter. Next visit, I will certainly have it moving under its own steam.
Old April 14th, 2014, 12:10 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by o2batsea View Post
Won't win any contests for beautiful welds, but it won't leak and it fits pretty good. Got the remaining exhaust placed and sorta tightened up. I need to fab some hangers. The muffler is kinda wonky. The pipes have some rather inexplicable bends. If I hadn't already spent the money, I coulda done as good a job with off the shelf mandrel bends. I think I may delete this muffler as it has to sit up in there pretty weirdly cocked in order for the pipes to line up halfway right. I woulda tried to get it running but I ran out of time plus I was lacking an oil filter. Next visit, I will certainly have it moving under its own steam.
Looks good and straight. How did you leak test it? At some point way down the road I will need to fab up an exhaust for my rig and wondering what ways there are to do it.
Old April 14th, 2014, 12:27 PM
I didn't. I just made sure that there is a solid bead of weld all the way around. It's one of those situations that you have to make a gazillion little tack welds all the way around the pipe. With a wire welder they look a bit snot like. If I were doing it again, I'd redo it from stainless. Maybe in another year or two I'll hit up Charles for the use of the TIG and make a forever exhaust.
Old April 14th, 2014, 04:44 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
My welder/fab buddy says the best way is to air pressure test but it seems like it would take a bunch of work to set up correctly. When I did my Toy axle I did a water method to look for leaks and that wasn't perfect either. It has been holding oil up to the fill hole but I still don't have any miles on it. And I hope my welds are strong enough when it hits something.
Like I said it looks nice and straight and once it is under a Rover and going thru heat cycles it will blend in. Almost a shame to put nice shiny stuff on the bottom of these trucks especially in many east coast climates.
Old April 25th, 2014, 07:31 AM
Final assembly of lower dash.
Solved the starter circuit issue by reinstalling the cole-hersee push button start switch (2A diesel has no switched power on START position, so no open fuel solenoid on diesel pump!) I also put the starter circuit power on white wire switched power so you have to key it to run the starter.
The lower dash took a long part of the day due to the awkward positions you must contort yourself in order to get the fittings in.
Got the panel cut and the second Auber gauge for boost installed. The programming is a little time consuming. Have to rework the hose for the boost pressure supply a little, the sensor is mounted to the bulkhead.
Old April 25th, 2014, 09:10 PM
Auber sensor attached to boost pressure line. I made it from 1/4 brake line. Don't worry I'll get all that wiring tidied up momentarily.
That's 500 degree flouro-elastomer hose. Good for 150 psi. There will be virtually no extra room in the engine bay. It's gonna be packed full.
Old April 26th, 2014, 08:30 PM
Wahooowa! Fired engine. Runs great. Had a few loose fittings to tighten up ( got a nice puddle of diesel on the floor ) and the water pump pulley was loose. Nipped all that up, purring happily no smoke.
Here's some bulkhead porn, enjoy.
ID:	93705   Click image for larger version
Old April 26th, 2014, 08:40 PM
cbfritz_03
Carmen
none
It looks lovely Bill. Wish I were there to have the sounds and smells ...thanks for the porn!
Old April 26th, 2014, 09:01 PM
Congratulations Bill. Its been a long time since you picked that engine up here.....
Old April 26th, 2014, 09:25 PM
Congrats. The mechanical linkage is a nice touch.
Old April 27th, 2014, 06:14 AM
Thanks. Ya Ron the hand throttle works!
Old April 27th, 2014, 07:25 AM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Congrats Bill! It was awesome to hear it fire up over the phone. Can't wait to see her all out together. I remember when........all those rivets......
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old April 27th, 2014, 09:02 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Great workmanship, Bill. Keep the photos coming. Congrats in the start.
Old April 28th, 2014, 11:14 AM
Bill, it looks great. Glad the lump is happy!
Old April 28th, 2014, 10:00 PM
Congrats! Will she make an appearance at the next HH?
Originally Posted by pendy
I'm here for the D's
Old April 29th, 2014, 07:22 AM
Needs seats and floors. Seat kits just arrived at RN last Friday, so still has to get here. Front floors and tunnel adapter need to be fitted. cubby box, CB, Headliner. Seat belts too. Needs a shakedown. Then HH.
I can always use an extra set of hands!
Old April 29th, 2014, 12:33 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Nice work ! Really looking good .
85 D110 3.5 3 DR
Old April 29th, 2014, 12:59 PM
Thanks Ed
conversion
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 11:58 AM
Advice on chassis and engine conversion project Rovermn Defender Technical Discussions 0 August 12th, 2008 09:08 AM
94 Yellow ST Project $12k/offer Colorado dnewman9 For Sale - Vehicles 9 January 20th, 2006 07:34 PM
Disco/Defender Hybrid Project RedRhinoProducts For Sale - Vehicles 3 December 11th, 2005 08:14 PM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 03:01 PM
