Conversion Project - Page 21 - Defender Source
Old October 9th, 2013, 12:55 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Originally Posted by o2batsea View Post
I found a pretty good home brew zinc plating electrolyte recipe here.
I'm gonna giv it a swing.
Thanks for sharing that link! So..... chromate conversion coating is the new galvy? [reference: http://en.wikipedia.org/wiki/Chromat...ersion_coating "The chromate coating acts like a paint, protecting the zinc from white corrosion, this can make the part several times more durable depending on chromate layer thickness."]
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 9th, 2013, 01:09 PM
Well I didn't chromate my parts.
Old October 9th, 2013, 01:24 PM
Bling! Lucas SFT 576s and SFT 700s. Some slight pitting on the 700s. 700s are spot beam and the 576s are driving/fog beam.
All from ebay uk
Shipping about doubled the prices so this is about 250-275 ish total in dollars. Only one is non op as it has no bulb.
ID:	81802   Click image for larger version
Old October 9th, 2013, 11:12 PM
So to update:
Weather too rainy to paint so doing other stuff.
Brakes bled, pedal good and solid.
Installed lowered shock mounts (Equipe front TF rear) much better.
Ground off all the door edge parts that still needed it and installed Defender style weatherstripping seals. The worst area is the lower middle door where the "dogleg" piece is. Three thickness together there and the seal is hard to push on.
All doors needed readjusting so that took some time.
Installed original latches in the doors. Installed original strikers. They don't fit the Defender T pieces, so the old nut plate didn't work. Bottom bolt had to have a fat washer with a half moon slice taken off due to a weird bit of bent metal inside the post right where the striker has to go. sheesh. Middle doors close and latch so good-o. Fronts tomorrow along with seat box.
Worked on the turbo manifold. Unstuck and un rusted all that was rusty and stuck. Found a stud in my stash to fill in the missing exhaust stud. Manifold ready to go on.
Old October 10th, 2013, 09:47 AM
Bill try and throw some blue painters tape on the dogleg part of the seal to help keep it in place.
Old October 10th, 2013, 10:14 AM
Good to hear you taking advantage of the forced vacation. We need more pictures though!
Originally Posted by pendy
I'm here for the D's
Old October 10th, 2013, 12:11 PM
Body shots
ID:	81898   Click image for larger version
Old October 10th, 2013, 12:14 PM
Looks great. So are you close to firing it up ?
Old October 10th, 2013, 03:02 PM
Drivers latch repair. Fatigue crack of upper mounting hole. Latch plate soaked in muriatic acid to strip it. Blob welded, ground and filed. Plated.
PS:
Crap! All the step by step pics are lost. Oh well trust me it was a good save.
Old October 10th, 2013, 03:04 PM
This rain has redirected my efforts. Getting the body done for now. Trevor is sending me a down pipe.
Old October 14th, 2013, 09:29 PM
Chromologistic ! And door tops all new! And paint!
ID:	82109   Click image for larger version
Old October 14th, 2013, 09:45 PM
Ata boy!
Old October 15th, 2013, 09:03 PM
Door tops done.
Seat box in.
Left inner wing painted.
Wiper cover panels painted
Old October 15th, 2013, 11:26 PM
Oh yeah I'll add that to the list!
Old October 16th, 2013, 09:41 AM
Test fitting some interior items. Seat height is about 42".
Old November 2nd, 2013, 02:09 PM
Getting the dash and wiring together.
Fabbed up a panel for the Auber boost and egt gauge. It'll have the high beam switch and the windshield wash fluid pump( the manual one) on it too.
Rolled the edges with a plastic hammer and the aluminum clamped in angle iron. Made the corners with a socket clamped in with a big c clamp. Trimmed it all up with air shears. Made hole with dremel wheel.
ID:	83344   Click image for larger version
Old November 2nd, 2013, 03:02 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Nice job
Mike Hammond
Old November 2nd, 2013, 05:16 PM
Phenomenal!
Old November 3rd, 2013, 07:42 PM
It's all in the details. Stuff like using the right crimp tool and terminals. Using the old switches. Replating the light. Finding the Lucas spot lights.
Exhausting.
ID:	83432   Click image for larger version
Old November 3rd, 2013, 08:11 PM
See that fitting on the license plate light? It's actaully a rivet that I drilled and tapped for the little stud on the lamp bracket, then I cut a slot for a screwdriver. That took a half hour or so.
conversion
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
Advice on chassis and engine conversion project Rovermn Defender Technical Discussions 0 August 12th, 2008 10:08 AM
94 Yellow ST Project $12k/offer Colorado dnewman9 For Sale - Vehicles 9 January 20th, 2006 08:34 PM
Disco/Defender Hybrid Project RedRhinoProducts For Sale - Vehicles 3 December 11th, 2005 09:14 PM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 04:01 PM
