Conversion Project - Page 20 - Defender Source
Old September 2nd, 2013, 08:54 PM
It's the kind of thing you can do in the evening. You just have to check every once in a while. No big deal.
Old September 4th, 2013, 08:51 PM
Progress on the plating. Still about 20-odd more this and thats to go. Mostly nut plates for the door latches and such.
ID:	79075   Click image for larger version
Old September 5th, 2013, 07:35 AM
Bill this truck is going to be incredible. Did you have the interior done by badger like you said in your first post ?
Old September 5th, 2013, 11:03 AM
Not yet, Doug. Concentration is on getting it running and driving. Maybe in the spring. It is in the plan tho.
Here's a pic of the latest and greatest plating set up. Now endless power. The light bulb (tail light bulb from L691 lamp) is my resistor. Keeps the amps down enuf that the stuff doesn't effervesce. Winning!
Old September 5th, 2013, 06:20 PM
Pure gold: 2A dash pull switches.
Old September 5th, 2013, 06:25 PM
Neat. Do you really need 6 of them though?
Originally Posted by pendy
I'm here for the D's
Old September 7th, 2013, 09:17 AM
Forgive me, Lord. I had to.
Old September 7th, 2013, 09:38 AM
why?
Old September 7th, 2013, 11:11 AM
Fuck me. If you needed some aluminum you could have just asked!
Old September 7th, 2013, 01:54 PM
for real, I have a lot, door skins, roof, complete disco. That looks like it was a good inner. What up with that Bill ?
Old September 7th, 2013, 04:29 PM
Relief for shock tower on LH wing. Since I don't have an English wheel and a bunch of other metal forming tools I made a box. Slightly tapered at the top.
Next up: a box for the steering shaft and the brake master cylinder.
ID:	79234   Click image for larger version
ID:	79236   Click image for larger version
Old September 7th, 2013, 04:31 PM
Just for your relief it was not a good wing. It corroded away at all the tabs and it has been hit in the front, and someone already cut it.
Old September 7th, 2013, 04:34 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
That's alright then
Mike Hammond
Old September 7th, 2013, 08:45 PM
I thought I was real slick with the intercooler mount. Well a little fitting and I find it fouls the steering pump (please, what doesn't). So lamenting my fortune I thought I might see what would happen if I flipped it. Bingo!
As you can see I need to do a little work on the bracket to make the corners clear. But heck look at all that room under the headlight bucket. Hey a 1/8 of an inch is as good as a mile sometimes.
Old September 8th, 2013, 08:14 PM
What! Ended up having to hit the light bucket with a heat gun and pushing it in with the silicone elbow. Now it clears dammit.
Old October 8th, 2013, 11:39 AM
More plating
Old October 8th, 2013, 11:43 AM
Originally Posted by o2batsea View Post
More plating
how long do you leave things in the bath for ?
Digging this. Have almost bought Eastwood"s kit a couple of times.
Old October 8th, 2013, 03:12 PM
Doug you can make many gallons of electrolyte for about 25 clams. The only thing you have to send for is the zinc chloride. All else you get at the grocery store. The zincs in the bucket are two halves of a rudder zinc. Power supply as you see is a battery charger. I have a lamp holder in line to the negative side and a 1157 bulb as a resistor. Parts hang from copper wires. I have a long bit of brass rod as hanger/negative bus.
The smalls take about a half to three quarters of an hour. You gotta keep checking and if the parts fizz and bloom you clean them off in clear water and put them back in. Easy as pie.
Don't buy the kit it's super way overpriced.
Old October 8th, 2013, 04:26 PM
Wow- had no idea it happens that fast. I still have a bunch of Camp "merican" made zincs somewhere that I bought for swim platform struts. So does leaving them longer than 45 mins get a thicker coating or does it start to bloom ?
Old October 8th, 2013, 07:39 PM
No harm just thicker coat. In 45 it's as thick as a coat of paint. It's all you need.
It's nice cz it doesn't glop like galvy. It coats every nook so it's good for little brackets and stuff you make. Can paint or leave bright.
An hour reading about home brew plating on the web will get you all you need to know.
The 88 in a Day dude went way overboard with his set up. You don't need to be super precise. If it's fizzing you need to reduce amps, that's the only secret.
conversion
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 11:58 AM
Advice on chassis and engine conversion project Rovermn Defender Technical Discussions 0 August 12th, 2008 09:08 AM
94 Yellow ST Project $12k/offer Colorado dnewman9 For Sale - Vehicles 9 January 20th, 2006 07:34 PM
Disco/Defender Hybrid Project RedRhinoProducts For Sale - Vehicles 3 December 11th, 2005 08:14 PM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 03:01 PM
