Conversion Project - Page 16 - Defender Source
Old March 26th, 2013, 09:26 PM
Thanks. This'll get "rover chrome"
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
That IC is worth that in scrap. Nice score. Plan next big step for May sometime. I have some time coming.
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old March 26th, 2013, 09:36 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Nicely done Bill!
MUDSUX
Old April 9th, 2013, 10:00 PM
Among a thousand little odd things such as making foam gaskets for my L691/2 lenses and bolting down the roof I did manage to get the doors hung. Gaps acceptable and the sight lines look pretty good. Those ball and socket hinges are a pain in the neck. I used stacked wood tongue depressors to get the doors sitting on the sill.
Come along used to get the bulkhead positioned.
Snake basking next to the RRC.
ID:	69890   Click image for larger version
ID:	69892   Click image for larger version
ID:	69894   Click image for larger version
Old April 10th, 2013, 03:19 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Looks good Bill, nice inte-cooler work.
Mike Hammond
Old April 23rd, 2013, 09:38 PM
Two days and it looks like I did nothing. However lots of progress nonetheless.
First some small items:
Got a set of L691 lenses from the UK and put them on, lookin fresh. Installed the anti burst catch on the tailgate so it closes properly. Installed the steering damper. Had to make a bracket for the steering rod and rivnut the RRC bracket to the chassis.
Then I set about the radiator support. This ate up 1.5 days. Why so much time? Well let's say that it took three tries to get it right. First time I used way too wiggly steel. Second time used stronger steel but it ended up looking like poop. Final one looks like something Ma Rover would have made. That's the whole philosophy on this build, so it is often hard to get it right on the first go.
ID:	70617   Click image for larger version
ID:	70619   Click image for larger version
ID:	70621   Click image for larger version
ID:	70623   Click image for larger version
ID:	70625   Click image for larger version
Old April 23rd, 2013, 09:41 PM
Oh yeah. Had to take the front cover off the engine to get the drill in where I needed. Went and did timing belt, tensioner and crank seal.
ID:	70627   Click image for larger version
Old April 23rd, 2013, 09:44 PM
Nicely done Bill!
Originally Posted by pendy
I'm here for the D's
Old April 23rd, 2013, 10:05 PM
Looks great! Here I thought it was getting a stage 1 front. What did you use for rubber bushings to mount the rad?
Old April 23rd, 2013, 10:21 PM
Using the round rubber things that the prongs on the bottom of the rad go into. Radiator frame uses similar rubber fitting that go in (yet to be drilled) holes on the fabricated mounts.
Old April 24th, 2013, 08:30 AM
Go to post #321 to see how I am mounting the IC in the breakfast. This means that the radiator has to live in the same cross plane as the steering box. If I had used a RH steer or even a P38 steering box I probably could have avoided all this. Those would live on the outside of the frame rail (this of course implies other problems like steering rod length). I used the Range Rover Classic steering box cz I already have three of them laying around.
Dunno. I am going with this.
Old April 24th, 2013, 09:25 AM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Hey Bill
It's looking fantastic! Great job so far! I need to get off my butt and get to work on mine again. Thanks for the motivation!
Daniel
Old April 24th, 2013, 09:38 AM
The Dro
Dro
1988 Ninety
Great job dood.
Old April 25th, 2013, 09:40 AM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Looking good Bill! You said "wiggly steel".............
Rick
95 P38 "Gus" RIP
03 D2 SE "Fred"
Old April 25th, 2013, 12:30 PM
Thank heavens I found the glass from the middle door. I was pulling my hair out trying to find it. It was where I had looked twice, but failed to see.
Old May 10th, 2013, 02:21 PM
Found my spot lights
These were cheap to buy but spendy to ship. Hope to see them soon. From Ebay.uk
Lucas 576, and SFT700's.
Name:	Lucas spots Front.JPG
ID:	72063   Click image for larger version
Name:	Lucas Spots rear.JPG
Name:	Lucas Spot close.JPG
Old May 10th, 2013, 02:25 PM
I call BS - the pictures are too nice for a UK seller. Make sure you haven't been scammed. ROFL
Old May 10th, 2013, 02:26 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Maybe an ExPat? lol
Old May 10th, 2013, 03:10 PM
mikeslandrover
Mike Hammond
I object to that.
I take good pictures for Ebay.
100% +ve feedback
Mike Hammond
Old May 20th, 2013, 07:18 AM
Lesson learned:
Bend up cheap aluminum clothesline as template before doing it in expensive cupronickel.
conversion
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
Advice on chassis and engine conversion project Rovermn Defender Technical Discussions 0 August 12th, 2008 10:08 AM
94 Yellow ST Project $12k/offer Colorado dnewman9 For Sale - Vehicles 9 January 20th, 2006 08:34 PM
Disco/Defender Hybrid Project RedRhinoProducts For Sale - Vehicles 3 December 11th, 2005 09:14 PM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 04:01 PM
