Conversion Project - Page 10 - Defender Source
Join the Defender Source Community Today
Old September 22nd, 2012, 08:43 PM
Ah the old double post trick.
Old September 23rd, 2012, 05:59 AM
Thanks Jeff. Yes dual wipers.
Old September 23rd, 2012, 03:48 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Nice to see it rolling! Are you running dual wiper motors?
-Jeff
The Series II individual motors?
Always feels like a major step forward when it's a rolling chassis.
Mike Hammond
Old September 23rd, 2012, 06:21 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by o2batsea View Post
Maybe I've been working alone too long, but this looks like a face
Wilson
Old September 28th, 2012, 07:10 AM
RRCbass's Avatar
RRCbass
Rob Bass
1990 Range Rover Classic
What was the heated glass element you used? Was it just a pre-gridded pane or something you put on it?
Old September 28th, 2012, 08:03 AM
Heated glass from Ricky Evans Motorsports. £69.90 per side plus shipping. Set with 3M Windoweld. Dual Single Lucas wipers with uprated marine stainless arms, Pangolin 4x4 gaskets. Frame stripped and regalvanized.
Old September 28th, 2012, 08:11 AM
The Dro
Dro
1988 Ninety
Looking good my friend... looking good.
Old September 28th, 2012, 09:56 AM
Just got a huge order from Craddock's. Got my giant steering rods. Next time i will be doing a lot of assembly. Gonna put the engine in, steering gear, and drive shafts. Shocks, calipers. Maybe the Goodridge brake lines. Mount the Kevlars on the wheels.
Gotta call the paint place and see what their timing is.
Old September 28th, 2012, 01:36 PM
mikeslandrover
Mike Hammond
Great find, the 90/110 version is just what I need to replace my cracked and chipped front screen
Build's looking good, keep the pics coming.
Mike Hammond
Old October 7th, 2012, 03:32 PM
Engine in. Rolled into barn. Cleaned up barn (whew!) installed shocks.
ID:	58646   Click image for larger version
Old October 15th, 2012, 10:06 AM
Found a crack in one of my heated windows. Can't imagine how it happened as all I did was set them in the mastic and walk away. Wrote to Ricky Evans and hope they will do something for me.
Old October 15th, 2012, 10:12 AM
Crack
ID:	59080   Click image for larger version
Old October 15th, 2012, 01:53 PM
mikeslandrover
Mike Hammond
Thats not so good.
Mike Hammond
Old October 15th, 2012, 11:01 PM
kullberg's Avatar
kullberg
Keven
1961
Looking real good Bill
Old October 16th, 2012, 06:57 AM
Thanks. I'm at one of those points where lots of little stuff is getting attention, and the chassis sorta sits. Next time I go over there I hope to be picking up body tins.
Old October 19th, 2012, 06:32 AM
More Britpart fun...
The reconditioned door latches I bought are OK except for the Driver's door with the built in lock. Ignoring the fact that this one won't fit the door, the lock is set up so that when you turn the key to the "locked" position, you cannot remove the key from the lock cylinder. With the lock unlocked the key goes in and out smoothly.
Old October 19th, 2012, 07:05 AM
87 D110 (Ruby)
Bill - I have a LHD lock set with a key...works fine.
Also a spare lock for any side.
You could probably take it to a locksmith....
Old October 19th, 2012, 09:51 AM
it might be worth taking that glass to one of the glass repair places to see if they can stop it running. that might be more economical than shipping another piece over.
as for the door locks, it depends which type you have as there are several. Some of them you turn the key to lock, then turn it back to remove the key but it stays locked until you turn it again.
Crack
Old October 19th, 2012, 11:58 AM
Rick Evans seems willing to send me a new glass. I did put some water thin epoxy in the crack which did get in there to stop the crack getting worse but it's a goner in any event.
I think I still have the old latches, which I need to pilfer for the push and turn locks. As for the BritPart one, it is pretty stupid. Key turns barrel, which rotates foot shaped thing into place, wedging handle (locked). Key stuck. Turn key to unlocked, key comes out. That's it, doesn't do any other way.
Craig kindly offered me one, which is fine, and I'll use it if worst comes to worst. Thing is, I want to keep the 2A one that doesn't require cutting the door frame. If I had planned this better I would have done that before getting them dipped.
The OE one has a little thing that catches a pin.
Old October 22nd, 2012, 06:14 AM
With the Bilsteins, it seems that the shocks are just about at the limit of travel. Granted there's no body on the chassis at the moment, but even with it on I can't see much more than another maybe 1/2 to 3/4 inch deflection. What's the next step up in length if these don't work out?
conversion
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 11:58 AM
Advice on chassis and engine conversion project Rovermn Defender Technical Discussions 0 August 12th, 2008 09:08 AM
94 Yellow ST Project $12k/offer Colorado dnewman9 For Sale - Vehicles 9 January 20th, 2006 07:34 PM
Disco/Defender Hybrid Project RedRhinoProducts For Sale - Vehicles 3 December 11th, 2005 08:14 PM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 03:01 PM
