Coil Series truck build - Page 3 - Defender Source
Old January 23rd, 2007, 12:17 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Pics
ID:	7979   Click image for larger version
Legend in My Own Mind.
Old January 24th, 2007, 04:45 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Some pics
ID:	7989   Click image for larger version
ID:	7991   Click image for larger version
Old January 24th, 2007, 05:40 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Very neat.....I'm envious...partly over the speed of the build, mine's taking forever.
Are you going to fit some sort of wheel arch extensions or will you get away without?
Mike Hammond
Old January 26th, 2007, 05:22 AM
kevb's Avatar
kevb
Kevin Barrett
2005 90 TD5
Thats coming along nicely Randy. How many man hours do you recon you have in the rebiuld?
Old January 27th, 2007, 12:43 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I can't even imagine the hours.. 100's I would guess
Old January 30th, 2007, 07:49 AM
Coiler
Ernie Novey
1995 D1 and 1991 RRC SWB
Randy,
The truck looks awesome!!!! I have another question for you. What brake setup are you using on the bulkhead? please tell me which booster and pedal mount you are using. Did you have any interference with the booster and series hood using the D90 bulkhead?
Is that an R-380 transmission?
Before I bought my 90, I was building a coiler with a designa/ECR chassis. I sold my project because I thought I was trying to make a series truck a 90. Anyways, I sold the 90 and I am beginning to start tearing down my 88. I am thinking again about going this route.
Old February 1st, 2007, 05:22 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Its a standard late IIa-III booster setup. bolts right to the d-90 bulkhead. No mods. ITs also an LT-77s onto an LT-230 t-case.
Its going to be a great little rig.... I wish tere was more leg room like the 90 though. I am tempted to take out the bulkhead behind the seat since I am running d-90 seats anyway. I hate to do that to the tub but it would make a lot more room. Has anyone ever done that before on a series?
I have driven it around already and it really moves. Does not feel like your standard sluggish series truck for sure..
Old February 2nd, 2007, 08:13 AM
Coiler
Ernie Novey
I am pretty sure that I saw someone use a modified bar from a 109" station wagon and put it in place of the rear bulkhead on a 88".
Old February 3rd, 2007, 06:30 AM
kevb's Avatar
kevb
Kevin Barrett
2005 90 TD5
You could try a bulkhead removal bar and seat rails from Mud UK
http://www.mudstuff.co.uk/Bulkhead_Removal_Bar.html
Old February 3rd, 2007, 05:02 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I would like to see it before I do it. That one will only work on euro d-90s
Old February 4th, 2007, 11:48 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I read back and am a little confused, you useing a series tcase or LT230? Is the rear output moved back a bit with the lt77 in there? Since my OD is toast I am thinking of doing an LT77 but my rear shaft is at max angle now and if the rear output moves back than I am looking at a double double CV shaft to make things work.
Old February 4th, 2007, 01:24 PM
Lucasd2002's Avatar
Lucasd2002
David Lucas
[VACANT]
as long as we're on the subject...
Have you guys seen a coiled 88 with 4.0/LT230/ZF slushbox - i.e. everything out of a later D1? Maybe something Matt B has done? just curious
btw, great lucking truck Randy
Old February 4th, 2007, 02:26 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I know he is going to be working on something like that but with a 300tdi.
Old February 4th, 2007, 03:09 PM
Lucasd2002's Avatar
Lucasd2002
David Lucas
[VACANT]
I was thinking that keeping it all in the D1 family might keep it relatively affordable...
Old February 4th, 2007, 03:42 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
No reason it could not be done.
Old February 5th, 2007, 12:16 PM
aloharover's Avatar
aloharover
Peter
1970 Series IIa 105
I have seen it done a couple different ways.
1. The cleanest was to cut the bulkhead down shorter and remake the galv capping piece.
crappy ASCI art
\__/
So the horizontal bit was maybe 6" above the tub floor. the sides were probably a 60*-70* angle.
2. On my tub I totally removed the bulkhead. I have a full interior cage. The B hoop has tabs that go and bolt to the cappings on the tub sides. No flex or movement when closing the doors. Worked out well.
I have moved my seat back 3-4 inches. made up a new mount for the sliders. The passenger seat was moved back 2. Can't go further due to the fuel neck.
3. Totally removed and then use a 90 type stiffening bar.
4. A 109 3-door tub is deeper behind the seats then an 88. I have seen where someone uses a 109 tub, cut the back end off, and 88 sides.
On my current build I am using the modifed 109 tub, but I am thinking about modifying the tub as in #1
Co Springs, CO Based FFL-07/SOT
Old February 5th, 2007, 12:20 PM
You can also use a 109 bulkhead and cappings on an 88 tub.
I would just pull the bulkhead out of there (if you do it cleanly you could always put it back in). and put in a NAS style bar between the seats.
Old February 5th, 2007, 02:53 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Ron, thats what I did on my 90 Euro rear tub. Just removed it and installed the NAS cage. You cant even tell. I will see how It is driving before I do anything to it though..
Old February 10th, 2007, 07:29 PM
badgerman's Avatar
badgerman
Christopher Laws
1964 Land Badger
Randy,
I removed most of the bulkhead on my tub and don't use any bar. If you look at each end of the bulkhead you will see a lot of bends, and if left on will give plenty of strength. Give me a call and I can go into it at length. I also moved the driver seat 2" in towards the center of the vehicle and then moved the tracks back 2". What a difference. I have Recaro seats in mine and like the snugness the bolsters offer. I will try to take some photos for you. Wasn't there something else that I was suppose to take photos of as well?
Sew on and sew forth...
Old February 23rd, 2007, 02:25 PM
Cirbo's Avatar
Cirbo
Jim C.
I've wheeled with a few of them. One was a direct transplant from a Range Rover Classic, the other was similar, but had a 4.6 replacing the old 3.5.
Both nice trucks though.
jC
coil, series
Series truck under $1000 evilfij Wanted 12 June 23rd, 2009 07:31 PM
1973 Series Hybrid for sale gordo For Sale - Vehicles 17 May 26th, 2009 07:51 PM
For Sale: 1971 Land Rover Series III Truck Cab, $16k, Scottsdale, AZ azarmadillo For Sale - Vehicles 0 February 13th, 2009 10:18 AM
Performance Ignition Coil solihul Defender Technical Discussions 1 May 27th, 2005 04:28 AM
1999 Discovery Series I chrisvonc For Sale - Vehicles 14 April 11th, 2004 02:15 PM
