Coil Series truck build - Page 2 - Defender Source
Old October 17th, 2006, 02:51 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Buildup Update... Here are some pics. I just got the rear tub painted too but no pics yet.
ID:	7089   Click image for larger version
ID:	7091   Click image for larger version
ID:	7093   Click image for larger version
ID:	7095   Click image for larger version
Legend in My Own Mind.
Old December 3rd, 2006, 06:28 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Some new pics
ID:	7561   Click image for larger version
Old December 4th, 2006, 12:54 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
that looks amazing! coming together. i like the Trek in the background too!
Old December 4th, 2006, 04:41 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
VERY special
Mike Hammond
Old December 4th, 2006, 06:15 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Thanks.. there are about thousands of man hours in that thing.... IT will be on the road in a few months
Old December 5th, 2006, 04:18 PM
mikeslandrover
Mike Hammond
That will be one tasty truck when it's done. Mine isn't going to be half as tidy as that, I just don't have the time, galv chassis & bulkhead and well used cleaned up bits is the sort of finish I'll end up with.
But yours....better than new
Mike Hammond
Old December 5th, 2006, 04:42 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Who did your galvanizing? Do you have contact info you could share?
Eric
Old December 5th, 2006, 06:55 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Its a place in Perth Amboy NJ
Old December 8th, 2006, 10:16 PM
aloharover's Avatar
aloharover
Peter
1970 Series IIa 105
Looking good. Why did you decide to use one piece doors?
Old December 9th, 2006, 09:27 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Thanks, I used those doors because they have been lying around my shop for 4 years now and I galv. the frames and re skined them. It was cheaper then buying entire new doors and tops. I can tell you that they are a really nice fit and much more solid then the half doors on my d-90. Plus I will be putting a Safari Roof on the truck so the rool down door will be nice. The window is quite big.
Old December 9th, 2006, 03:43 PM
mikeslandrover
Mike Hammond
Yep with the glass rolled down it's almost the same as taking the door top off
Mike Hammond
Old January 9th, 2007, 10:23 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I just got my coiler back from Matt at Overland Enginnering with my power steering conversion and Delco alternator. PS is sweet when you've gone without it. dual ARBs and Longtracks axles/CVs up front are next. I'll edit in some pics later.
Some pics in process.
ID:	7842   Click image for larger version
Old January 10th, 2007, 08:27 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Kwvin, did they have to move the x-member up or something? Lets see more pics. I will post some more of the series build later today also.
Old January 10th, 2007, 04:57 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Yep, crossmember was cut out and a new one was made and welded in forward.
ID:	7847   Click image for larger version
Old January 11th, 2007, 02:43 AM
kevb's Avatar
kevb
Kevin Barrett
2005 90 TD5
Hi Randy, I am really impressed by the quality of your rebuilds, nice job! On the coil series conversion have you hade to fabricate or buy loads of custom parts? I am planning a rebuild of a series 2a later in the year, always fancied a designachassis rebuild but thinking of keeping it simple for this one.
Name:	series2a series3 270605 012 (600 x 450).jpg
Old January 15th, 2007, 08:12 PM
aloharover's Avatar
aloharover
Peter
1970 Series IIa 105
What box is that Kevin?
I am still getting incrediably lucky with the Scout boxes. Just picked up another one for 75$ for my project.
If you are going to put coils under a Series frame, a whole lot of fabbing.
If you are going to convert a RRC or D1 frame to fit the Series body, its not as bad. Specially if you have a series frame you can first tkae lots of measurements and photos from. And then cut off the outriggers and rear xmmember from.
If you plan on keeping the 88 tub I would cut 10" out of the coiler frame and make it a true 90. This will center up the axle in the wheel wells.
Old January 15th, 2007, 10:58 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
It is a designa chassis. All rover parts, D90 column and a disco box. Did a GM alternator conversion at the same time.
Old January 17th, 2007, 09:22 AM
Coiler
Ernie Novey
1995 D1 and 1991 RRC SWB
Randy,
When you painted the bulkhead, what kind of primer did you use since the bulkhead had been galvanized? What kind of prep did you have to do to the galvanizing before you could use the primer?
Old January 18th, 2007, 08:19 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Kevin, if you do the Desiga chassis, its just a bolt on set up with very minor mods. Thats a killer D-90 you got there too...
Ernie, after galv, sand and scuff the entire thing and get rid of any galv runs or bumpy spots with a sander then you have to metal wash and prep it with special 3M products.. then hit it with the primer.
Old January 23rd, 2007, 09:03 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I will get some more pics today... I actually took it around the block the other day.. All is good.
coil, series
Series truck under $1000 evilfij Wanted 12 June 23rd, 2009 07:31 PM
1973 Series Hybrid for sale gordo For Sale - Vehicles 17 May 26th, 2009 07:51 PM
For Sale: 1971 Land Rover Series III Truck Cab, $16k, Scottsdale, AZ azarmadillo For Sale - Vehicles 0 February 13th, 2009 10:18 AM
Performance Ignition Coil solihul Defender Technical Discussions 1 May 27th, 2005 04:28 AM
1999 Discovery Series I chrisvonc For Sale - Vehicles 14 April 11th, 2004 02:15 PM
