Central Tire Inflation System - Defender Source
Old May 31st, 2013, 08:58 AM
defender130
Joe
1985 Defender 130
Hi
Can anyone recommend a good CTIS that I can have installed?
Thank you
Joe
Old May 31st, 2013, 09:03 AM
Sorry can't help, but 130 in NYC? We need to see pics. Is it down in TriBeCa? That's the only place I've seen a 130 in NYC before. Welcome. Here is our local NYC happy hour thread. Subscribe to the thread (using the thread tools) and you'll get an e-mail whenever we plan the next get together.
http://www.defendersource.com/forum/...ad.php?t=24509
Old May 31st, 2013, 10:15 AM
Landy_Andy's Avatar
Landy_Andy
Andy
The only CTIS I've seen fitted to a LR recently are on 'Oilworkers' portal converted 130. His came from Tibus off-road in Germany.... http://www.killeraxles.com/html/bolt_on_portale.html
Old May 31st, 2013, 10:21 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Oilworker's build thread is most certainly worth a read.
http://www.expeditionportal.com/foru...uck-on-portals
Old May 31st, 2013, 11:03 AM
defender130
Joe
1985 Defender 130
Thank you for your info. I will post photos soon. I am in the west village. I will for sure attend one of your NYC gatherings. Best!
Old May 31st, 2013, 12:44 PM
Nice. Me too...and at least a few others who are on this board also live in the West Village.
Old May 31st, 2013, 12:47 PM
So that makes you "village people" right?
Mark Kellgren
KM4BOR
Old May 31st, 2013, 01:00 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
im not even half way through that thread. Woah, nice build
Old May 31st, 2013, 02:17 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I'm shocked. How does a previously unknown 130 get into the backyard of the HSOC undetected? Where's your force protection?
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old May 31st, 2013, 02:19 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Especially what appears to be an extensive galvy chassis build up with 23" or so sized wheels.
Old May 31st, 2013, 02:40 PM
defender130
Joe
1985 Defender 130
Hi guys
I took down the photos because of the assumptions being made which are incorrect.
Joe
Old May 31st, 2013, 04:02 PM
BEIS's Avatar
BEIS
RYAN BEIS
D110 Soft Top with full rollcage
For CTIS, ARB makes an on-board high output 12V compressor that satisfies. You could fit Hummer H1 CTIS lines, gauges, and switches on the dash and be good to go. Just an idea.
-Ryan
Old May 31st, 2013, 04:23 PM
It would be a lot more complicated than that.....
Old May 31st, 2013, 05:13 PM
BEIS's Avatar
BEIS
RYAN BEIS
Sure. But, you could do it.... I have CTIS on my H1; it's a complicated animal, but not impossible.
-Ryan
Old May 31st, 2013, 05:41 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Just check your tires every so often, how hard can it be?
Old May 31st, 2013, 06:48 PM
I will explain the way the system works and why it is not simple nor practical in a Land Rover axle. It is important to understand how these are designed.
Air needs to get from the non-rotating axle components to the rotating ones to feed air to the wheels. The only reasonable way on a vehicle to be used off road is through the spindle and into the stub shafts. This requires cross drilled and bored stub shaft with high integrity sealing to the spindles. When you are designed a new axle with this in mind, it is not a big deal to make the space and ensure the items are strong enough.
In a stock Rover axle, the is not any excess strength in the stub shafts to accept cross drilling and boring and there is not any spare axial space on the spindle for the sealing and piping. You would need custom spindles, stub shafts, CVs, hub modifications and so on. The cost would exceed new custom axles so is not really practical.
Old May 31st, 2013, 07:52 PM
Perhaps a compromise would be to install tire pressure sensors inside the tires. There are quite a few aftermarket choices for this, some with stand alone monitors that you can goober to the dash with duct tape and clear silicone.
tire
Tire Inflation Systems - use my current scuba tanks?? advnirvana Defender Technical Discussions 2 September 10th, 2009 03:51 PM
Tire options after OME lift... Rover- Girl Misc. Chit-Chat 23 February 12th, 2008 05:06 PM
12.5" tire on a 7" rim? souza Defender Technical Discussions 16 August 19th, 2005 04:04 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
