Blue Mule - 1986 110 3dr Build - Page 9 - Defender Source
Join the Defender Source Community Today
Old April 9th, 2015, 09:13 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Got the heater box pieces back from powder last week and finally sat down to put it together today with a LHD blower motor and core from Rovers North.
Kind of a lot of work but was good to reuse a piece and I'm really happy how it came out. GSD did a really nice job on the powder.
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Angle shot
Old April 9th, 2015, 09:14 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Another angle
Much easier to install on an open bulkhead
Old April 9th, 2015, 09:25 PM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
Looks really good Don.
Old April 10th, 2015, 12:16 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks! Swing by and take a look when you are in the area.
Old April 10th, 2015, 07:00 AM
flananuts
Matthew
Would love to. I'll text you
Old April 19th, 2015, 06:17 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Got the freshly galvanized inner fenders in this week. Hoping the out fenders can get on this coming week. Lots of wires all over the place but getting close.
Old April 19th, 2015, 06:19 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
A little bling added today on the left side today. Rovers North sliders with tree guards. I still need a couple bolts added but will do the final when the body is on.
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Another angle of the RN sliders. Thanks Zack!
Old April 20th, 2015, 09:53 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Making the 2.5NA chassis harness work with the 300tdi main harness.
Old April 22nd, 2015, 03:59 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
After pics of chassis harness connectors
Old April 22nd, 2015, 04:18 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Attachment 118993
Nicely converted to the newer type harness.
There is a LR retrofit engine harness available as well that adapts to the older rubber plug type harnesses.
Old April 22nd, 2015, 04:29 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Another with them all together
All I have left for the wiring is:
- Order and install connectors for the rear lights
- wire up speed sender, diff lock, reverse switch, and parking brake switch
- figure out how to get the Merc glow plug relay to talk to the 300tdi harness and wire
- find a distribution block for 60A (thinking something from Blue Sea) for the main brown wires
- wire starter and alternator
- wire last connector that goes to main harness
And once the wiring is dialed I can start swapping body pieces \../
Old April 22nd, 2015, 07:29 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Got the brake booster installed. Just had to weld some M8 nuts and give it a quick squirt of paint and it's good to go.
Just need to name the line that goes out to the rear axle.
Old April 22nd, 2015, 07:32 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
What it looks like from the inside. Used button head stainless bolts as I don't want to bother with covers but want it to have a good look.
Old April 22nd, 2015, 07:39 PM
It looks great. The more pictures I see of your bulkhead, the more I think mine isn't going to look as good. It got a bit beat up at galvy and will need to give it some love. I've decided to paint mine so I guess no big deal.
Originally Posted by pendy
I'm here for the D's
Old April 22nd, 2015, 07:44 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks! But it must be the light - mine is decent but nothing fancy.
But I want a straight forward/no frills/industrial look with this so I am satisfied with how the galvy looks. I am glad I TIG'd the panels - I feel like things would have moved more if it was just spot welded.
Old April 22nd, 2015, 08:07 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS Rebuild Project
Looking great Don. Where did you get the chassis harness connectors?
Old April 22nd, 2015, 09:39 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks - I feel like I am starting to see some progress!
Eastern Beaver for the dash/interior ones and 3waycomponents.co.uk for the engine/bulkhead/chassis ones
Old April 26th, 2015, 09:40 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Got a fender on last night. Actually on then off 3x before I feel like it is close enough - little bit of a gap up on the top - I think the bulkhead moved a bit at some point.
Red or Blue 5 door 110 1of40 Wanted 0 May 24th, 2013 04:59 PM
1986 Defender 110. 5dr (2.5 diesel) - $8000 CDN90 The Flea Market 3 May 31st, 2010 05:08 PM
1986 Land Rover 110 Soft-Top Tdi Lurker For Sale - Vehicles 3 June 7th, 2006 11:03 AM
1986 110 Sation Wagon thewap For Sale - Vehicles 32 June 1st, 2006 11:05 PM
110 3dr military Land Rover forsale headdamage For Sale - Vehicles 7 February 22nd, 2005 01:47 AM
