Blue Mule - 1986 110 3dr Build - Page 7 - Defender Source
Old February 15th, 2015, 01:41 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Originally Posted by don View Post
Installed the JSQ hitch that was on my NAS90. I dig how the black looks with the Galvy frame. The underneath frame nuts are m12 on this vs m10 on the NAS and the '86. I used allen head 12.9s as I couldn't get a socket on a normal bolt.
Don, that is the size of those 4 bolts on the cross member? Do you know size and pitch?
Legend in My Own Mind.
Old February 15th, 2015, 02:23 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I ended up using M12x1.75 - Grade 10.9 - 100mm in length.
I had bigger bolts (m14) but was really tight and I figured 4 m12 bolts (and the 2 underneath) would be plenty strong.
Old February 16th, 2015, 07:23 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Underneath - allen head m12
First off. Troll alert. I'm still lurking here time to time
Secondly. Make sure you paint those bolt heads and anti seize the threads. Those hardened steel Alllen bolts rust real fast when exposed to elements. They don't have any protective coating.
Old February 16th, 2015, 08:15 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Good to hear you a still popping in. It's been a while and with the snow/weather we've been hunkered down. Hope things are well.
Agree on the painting of those allen bolts. Do you just use a paint pen? Or maybe I'll just pull them and hit them with some engine or caliper paint I have sitting around.
Old February 16th, 2015, 08:27 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Just a quick shot out of a spray can should do.
I just remember using them on my drive flange and they were brown within a Week, and it hadn't even rained I don't think
I eventually replaced with zinc plated hex bolts and they didn't rust at all.
Old February 16th, 2015, 08:42 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
That is the crappy thing about them. I'll pull and shoot with some paint I have laying around. I do love how the allen heads look wish there was a plated 12.9 version of them.
Old March 3rd, 2015, 08:03 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Started work on the heater box. With the price of LHD boxes I am using MikeCT's build and convert a RHD box. Got a new blower with LHD inlet from Rovers North and getting a ProLine heater core from them as well.
Pics:
Old March 3rd, 2015, 08:05 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Stitched up one side - I am not going to convert this back to RHD so just going to weld where I see can help.
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Moved one of the tabs for the flap control
Old March 3rd, 2015, 08:07 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Inlet that was taken out, flattened and reversed then popped rivet and welded back on.
Sorry for the one pic post my app keeps crashing when I try to do more than one per post.
Old March 3rd, 2015, 08:34 PM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
Looking good Don
Old March 3rd, 2015, 08:44 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by flananuts View Post
Looking good Don
Thanks Matt!
Old March 9th, 2015, 02:22 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Just about done with the heater box RHD - LHD conversion. Pretty much had to take every panel apart and "flip" it over. Going to drop off the pieces to powder tomorrow.
Old March 9th, 2015, 02:23 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
This panel was a bear to swap over. Had to get the folds to line up right - used the c-clamps to hold to check fit.
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Another one.
Old March 9th, 2015, 06:36 PM
That looks like a lot of work, but it looks like great progress.
Originally Posted by pendy
I'm here for the D's
Old March 9th, 2015, 08:31 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I got a little carried away with TIG welding the seams up and that took a while otherwise it wasn't too crazy work wise. If I had access to a good sheet metal break it would have been a bunch easier.
Once done I will be $400 in parts (new heater core & blower motor). I am guessing powder to be $75-100 for all the pieces. A new LHD one seems to retail at close to $900 and will have the Rover build and paint quality.
Old March 15th, 2015, 12:41 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
So I ordered that leather cover from the guy on Ebay UK that Uncle Doug told about in the bulkhead thread. The first cover was just a RHD cover "flipped". The second cover was a RHD normal cover. But I had the original so had a local auto upholstery guy cut out a patch and swap the panel where it was cut out for the RHD steering wheel. He then installed the cover.
It came out pretty good - actually considering it was a rat bastard of a RHD lower dash I am more than happy with it. Lots of fabrication, and about $300 for the powder, cover, and upholstery install but looks good.
Old March 15th, 2015, 12:45 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Lav's gauge holder looks trick as hell with the leather.
Old March 15th, 2015, 12:46 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Another angle
Red or Blue 5 door 110 1of40 Wanted 0 May 24th, 2013 03:59 PM
1986 Defender 110. 5dr (2.5 diesel) - $8000 CDN90 The Flea Market 3 May 31st, 2010 04:08 PM
1986 Land Rover 110 Soft-Top Tdi Lurker For Sale - Vehicles 3 June 7th, 2006 10:03 AM
1986 110 Sation Wagon thewap For Sale - Vehicles 32 June 1st, 2006 10:05 PM
110 3dr military Land Rover forsale headdamage For Sale - Vehicles 7 February 22nd, 2005 12:47 AM
