Blue Mule - 1986 110 3dr Build - Page 4 - Defender Source
Old November 20th, 2013, 09:30 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Few more pics of the tailgate. I should add to that bonehead move thread. I painted the inside and used too much of the paint and the outside I got 90% done.
Old November 21st, 2013, 07:30 AM
It looks great. Well done!
Originally Posted by pendy
I'm here for the D's
Old November 21st, 2013, 12:42 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
I wont tell anyone, I swear. lol
Old December 20th, 2013, 12:41 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Slow going but I have most of the rear axle installed. I still need to order some Fox Emulsions and clean the LH hub, brake rotor, and install the longer wheel studs.
Pics:
Details:
- Disco axle with Rovingtracks sewer cap - POR-15 and chassis black
- Toyota E-locker 3rd Member - 4.10 gears
- Rovingtracks HD Toy axles
- Rovingtracks HD trailing arms
- Polybush extended bump stops with stainless bolts
- Land Rover HD 110 springs
- RTE Fab upper shock mounts - Eastwood Rust Encapped with Chassis Coat Extreme on top.
- RTE Fab lower shocks mounts
- upper links painted with Eastwood Chassis Coat Extreme and new bushings installed
- new ball joint installed and painted with Eastwood Chassis Coat Extreme
- RH side hub, rotor, were repacked with grease and prepped and painted with brake caliper paint. Installed longer wheel studs so I can run 1/2" spacers.
- McMaster Carr 10.9 hardened bolts were used throughout and coated with anti-seize.
Old December 21st, 2013, 07:42 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
Don looks great! At least I'll know someone local who can help me order the bits i'll need if/when i ever do a chassis replacement on the 110 DC in the future. Can't wait to see this
Old December 21st, 2013, 11:19 AM
Great to see you moving forward with this! Looks great.
Old December 21st, 2013, 11:35 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks Matt and Charles - feels good to work at the chassis level. Kind of like a massive Lego set. Matt - will love to help if you do a chassis swap on the DC. You are more than welcome to swing by anytime.
Old January 31st, 2014, 09:04 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Finally got the front axle in and all the internals installed. Unlike the rear axle this was on the shelf although I had all the parts for the Toyota Diff conversion
Specs:
- Disco 1 housing with sewer cap - POR15 then Chassis Black top coat
- Roving Tracks Toy Kit - 30 spline HD axle shafts and CVs, 12.9 grade socket head bolts on flanges
- Toyota hi-pinion Diff - 4.1 gearing - open
- Teflon coated swivel balls - Disco 1 style for the Railco bearing on top
- Swivel housings that both have 2 tabs so the axle can be used RHD or LHD
- all new bearings and seals
- 50/50 mix of LR one shot swivel grease and 70-90 Mobil 1 gear oil
- hubs were painted using caliper paint (which is becoming my new favorite paint for chassis stuff)
- new brake calipers from AB
- EBC Vented Defender rotors
- EBC Green Pads
- Roving Tracks - HD Tie Rod, steering rod, and Pan Hard rod - all stripped and finished with Eastwood etching primer and Chassis Coat
- LR genuine HD front springs
- Disco 2 rubber isolators with stainless nuts and washers
- TF Defender 90 rear spring retainers with grade 10.9 hardware
- RTE Fab lower shock mounts - freshly painted with Eastwood products
- RTE Fab upper shock mounts - freshly painted with Eastwood products
- Fox Emulsion 2.0 shocks
- Poly Bush extended bump stops with stainless hardware
- stock radius arms painted with Eastwood products, Poly Bush slotted front bushings, LR genuine on the upper ends
- 1" spacers
Old January 31st, 2014, 09:41 PM
so clean! love the build...
Old January 31st, 2014, 10:08 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks!
Old January 31st, 2014, 10:37 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Great build! I'm subscribed!!
Old February 1st, 2014, 08:04 AM
NADA
NICE work Don!
Old February 1st, 2014, 09:54 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Cool - thanks and if you have any ideas or tips/pointers please feel free. I am learning as I go along.
so, what are you plans for that bulkhead ? Anything custom?
-Jeff
I know we talked about a interior cage. Not sure if I might just repair the NAS110 I have and then do the cage somewhere down the line. If you have any other custom ideas before I start fab work please feel free to post up.
NICE work Don!
Thanks Jonesy! I got the wheels on last night and to have a "roller" feels pretty freaking awesome. I still have a long way to go but step by step.
Old February 1st, 2014, 12:07 PM
flananuts
Matthew
I've seen this in person and it looks just about amaze-balls
Old February 1st, 2014, 05:28 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I got the wheels on and outside so I could flip it around front facing forward. I need to finish up a few items on the axles but should be able to get to the motor soon.
Old February 1st, 2014, 06:36 PM
I love it! How are you liking the clean work? I can't wait for this stage of my build.
Old February 1st, 2014, 07:37 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks Charles! I really like having a slot in the garage and just popping pieces on. Working with a galvy frame is sooooo nice.
The only problem is, I am stressing on every part I put on it. If it doesn't look clean or has some rust I refinish it and even the bolts. But it is a good thing as I am mostly satisfied when it is all put together.
Old February 1st, 2014, 09:28 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Very detailed, love it! What rate did you have the shocks set to?
Oh, and what size tires are those MTRs? You have about 2" of lift from those coils?
Old February 1st, 2014, 10:05 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by SMac View Post
Very detailed, love it! What rate did you have the shocks set to? Oh, and what size tires are those MTRs? You have about 2" of lift from those coils?
I am not sure he rate on the shocks - I got them from Justin at Lucky 8 and he said he knew a nice rate for Defenders. I will be getting a matching set for the rear when I get some spare funds.
The Goodyears are 315-75-16. They run a true 35" mounted (but not on the car).
I am guessing the springs will yield 2". I have LR HDs on the rear and OME front (very close specs to the LR HD) on the truck now and it looks about 2". The stance is just right IMO.
Old February 1st, 2014, 10:26 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Originally Posted by don View Post
I am not sure he rate on the shocks - I got them from Justin at Lucky 8 and he said he knew a nice rate for Defenders. I will be getting a matching set for the rear when I get some spare funds. The Goodyears are 315-75-16. They run a true 35" mounted (but not on the car). I am guessing the springs will yield 2". I have LR HDs on the rear and OME front (very close specs to the LR HD) on the truck now and it looks about 2". The stance is just right IMO.
I overvalved mine from Justin and now need to get them much softer. I should have went with his advice I guess. .
So you are fitting 35s with 2" loft and 1" spacers. Planning on any fender trimming or do you think you'll be fine? I ask because Im about to install 4.10s and I think the 285s look a bit lost with 2" lift.
Thanks!
Red or Blue 5 door 110 1of40 Wanted 0 May 24th, 2013 03:59 PM
1986 Defender 110. 5dr (2.5 diesel) - $8000 CDN90 The Flea Market 3 May 31st, 2010 04:08 PM
1986 Land Rover 110 Soft-Top Tdi Lurker For Sale - Vehicles 3 June 7th, 2006 10:03 AM
1986 110 Sation Wagon thewap For Sale - Vehicles 32 June 1st, 2006 10:05 PM
110 3dr military Land Rover forsale headdamage For Sale - Vehicles 7 February 22nd, 2005 12:47 AM
