Blue Mule - 1986 110 3dr Build - Page 22 - Defender Source
Old April 6th, 2016, 07:05 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Got this coming soon.
Old April 7th, 2016, 02:52 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Dieselmeken work on that?
Old April 7th, 2016, 07:29 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
Injection pump?
Old April 7th, 2016, 12:50 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Dieselmeken hardware and Barrote from STD out of Portugal on the install. Kind of a leap of faith using Barrote but his correspondence has been excellent.
------ Follow up post added April 7th, 2016 12:52 PM ------
Originally Posted by flananuts View Post
Injection pump? Sent from my iPhone using Tapatalk
Yup - M Pump with 7,5mm elements. Word is it is good for 200+ HP. Going to try it with a Holset Hx30 turbo.
Old April 7th, 2016, 01:42 PM
Hell yeah !
Old April 7th, 2016, 07:02 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Hell yeah !
Hoping to keep up with you tuned 200/300tdi guys, haha!
Old April 8th, 2016, 09:22 PM
Kelbo's Avatar
Kelbo
Kelly
'86 110
Very nice work, Don.
Kelbo
'86 110
Former Rigs:
'94 D 90 ST
'84 D 130 Hi-Cap
Old April 8th, 2016, 10:52 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks!
Old April 13th, 2016, 11:57 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Swapped the 1.4 for 1.2 out of a D2.
Old April 13th, 2016, 12:01 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Installed the TerraFirma bulkhead removal bar. What a pain in the ass! With the P&P cage it needed some cutting and grinding to fit just right. Still need to weld a plate on the cage bottoms to cover the cuts. But I do like the extra room and openness.
Old April 13th, 2016, 12:07 PM
Attachment 147178
Geez looks like a pain in the butt for a piece they should rename the "bulkhead still half there bar" but it definitely does open it up a bit.
Old April 13th, 2016, 12:18 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I went back and forth a lot - to do this or the NAS style bar. When I had my NAS I felt the hardware on the floor just collected dirt/food/etc. I also liked having my Hi-Lift right there too. And while I had to mod the TF bar to fit my setup (stock would have been much easier) the NAS style bar would have been much more work.
I was actually surprised how much more open it feels with this setup and I think it looks cleaner.
Old April 27th, 2016, 09:45 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I had to make some fixes to my exhaust. I thought it had enough clearance but it must have been hitting the T Case when warm/under load and had me thinking the LT230 had a bad bearing and I was on a chase for a few days last week.
I lengthened the crossover pipe and redid the Mercedes DP that I had modified to work (but I was never all that happy with it).
Pic of new DP with flex, turbo flange and V band from the old DP:
Old August 23rd, 2016, 02:41 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I haven't updated this in a while but I have been picking away at little things.
I am starting the interior lighting. One thing that I thought was very weak on my NAS ST was the lack of lighting. For this build I wanted lots of lights. A trip to PepBoys and I got a bunch of various LED setups in plain white.
For the rear I wanted something that was pretty hidden. I bought some small pods that fit pretty closely in the rectangular holes in the galvanized strip.
I made some adapter plates out of stainless I had and welding some 6-32 nuts and screws. Then made a wiring harness tying each pod to a 18 gauge wire. I have to do the other side but I took pics of the one side.
The LED pods with adapter plate:
Old August 23rd, 2016, 03:04 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
More pics
Bolted into galvy piece:
Installed:
LED pods:
Old August 23rd, 2016, 03:17 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Those lights look nice, Don.
I need to do that for my ST.
I'd also like a couple kick panel lights for driver/front passenger.
Maybe even a "puddle" lamp ala RRC style.
Have you wired them up yet? I want to see a night shot!
Rent my
Old August 23rd, 2016, 03:21 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Those lights look nice, Don. I need to do that for my ST. I'd also like a couple kick panel lights for driver/front passenger. Maybe even a "puddle" lamp ala RRC style. Have you wired them up yet? I want to see a night shot! .
Thanks!
The LED stuff even from PepBoys is slick. The only tricky part is the wire is so thin!
I will throw a power source on them tonight and take a pic. I'm anxious to see what they look like myself!
I am also going to run lighting in the kick panels, on the bottom of the door frames (like my wife's RR) and behind the seats. It might be overkill but I hate using my phone to look for anything in my 110 at night.
Old August 23rd, 2016, 03:28 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Exactly!
Not overkill at all.
You won't draw much juice with those LEDs.
I'd want a dedicated on/off for interior lights...maybe the door switch option.
Maybe a separate door light circuit/lights.
Are all your lights going to be tub level or lower?
I'd like the option of some higher but no way I'm messing with a NAS ST cage.
Rent my
Old August 23rd, 2016, 09:25 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Exactly! Not overkill at all. You won't draw much juice with those LEDs. I'd want a dedicated on/off for interior lights...maybe the door switch option. Maybe a separate door light circuit/lights. Are all your lights going to be tub level or lower? I'd like the option of some higher but no way I'm messing with a NAS ST cage. .
I may do something on top of the wind shield frame (I don't have the stock light or anything there yet). I am going to have theses light go on from the front 2 door switches as well as a switch in the middle of the wind shield.
Here is a quick pic of the lights:
Old August 23rd, 2016, 10:07 PM
I may do something on top of the wind shield frame (I don't have the stock light or anything there yet). I am going to have theses light go on from the front 2 door switches as well as a switch in the middle of the wind shield. Here is a quick pic of the lights:
Sweet.
Red or Blue 5 door 110 1of40 Wanted 0 May 24th, 2013 04:59 PM
1986 Defender 110. 5dr (2.5 diesel) - $8000 CDN90 The Flea Market 3 May 31st, 2010 05:08 PM
1986 Land Rover 110 Soft-Top Tdi Lurker For Sale - Vehicles 3 June 7th, 2006 11:03 AM
1986 110 Sation Wagon thewap For Sale - Vehicles 32 June 1st, 2006 11:05 PM
110 3dr military Land Rover forsale headdamage For Sale - Vehicles 7 February 22nd, 2005 01:47 AM
