Blue Mule - 1986 110 3dr Build - Page 19 - Defender Source
Old November 17th, 2015, 11:40 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by DannyboyUpstate View Post
Truck looks awesome. That catch can is intense.
Thanks - lots of filler wire in that little thing!
------ Follow up post added November 17th, 2015 12:41 PM ------
Originally Posted by Daddymow View Post
Looks great! How did the motor feel?
Pretty good but haven't given it much testing - my street is pretty short.
I want to button up the catch can (waiting for fittings from Summit) and finish a few other things before taking it for a longer drive.
Old November 17th, 2015, 11:48 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Don, did you happen to catch that one guy's post the other day who routed the lines to his chassis rails as a Rust prevention measure? What a hoot.
Old November 17th, 2015, 12:26 PM
Congrats!
Originally Posted by pendy
I'm here for the D's
Old November 17th, 2015, 02:11 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I haven't but that is a slick idea - if I had an older chassis I would do the same but I want to keep the frame nice and "galvy'd" for a little while.
------ Follow up post added November 17th, 2015 03:12 PM ------
Originally Posted by cgalpin View Post
Congrats!
Thanks - hoping I can get out on the next Rover trip!
Old November 19th, 2015, 08:29 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Pic of the catch can installed. Not the prettiest thing but should do the job.
Old November 19th, 2015, 10:10 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Hey don I'm not sure if you have tested that thermostatic switch but it doesn't close until 205 degrees Fahrenheit. That was a little warm for me - just wanted to let you know.
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old November 19th, 2015, 10:45 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I haven't tested it yet.
I am going to run a Taurus electric fan which may have its own thermostat and those are supposed to keep things more than cool. Cooling system is on the winter project list along with a ton of other small stuff
Old November 19th, 2015, 10:53 PM
ontheway's Avatar
ontheway
Dave
I ended up using a new manufacture Taurus fan as well, which is two speed. There are not many affordable two speed thermo switches out there unfortunately. I still wired two speed with a Volvo two speed fan relay. However, I placed a double throw switch between the closed ground of the switch and the relay. If the fan is on (relay closed) then I can use the in cab switch to either turn it off, to low speed or to high speed if temps are still rising. Works like a charm.
Old November 19th, 2015, 11:03 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Ah - that sounds like a nice way to do it. Red90 had link to someone that sells a thermo switch in one of the Taurus fan threads. I was thinking of using that and see if I can do an in cab switch as well for those days on the trail when things can get warm.
Old November 25th, 2015, 07:10 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Made a bracket to hold the engine fuse box - went with a marine spec one as it was the easiest and most durable option out there.
The bracket was made from some scrap aluminum that I welded together and ties to the upper fender and inner wheel well and uses M5 nutserts for easy install/removal.
Old November 25th, 2015, 07:12 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Pic of the fuse box - had to run a new wire (the only non-Anchor) today for the lights as the old one broke off at the bolt on part.
Old November 25th, 2015, 08:31 PM
koltonstanley's Avatar
koltonstanley
Kolton Stanley
defender 130 hi cap
Nice and clean. Looks great!
Old November 25th, 2015, 10:47 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks Kolton!
Old November 30th, 2015, 08:48 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Sometimes a small fix is very satisfying.
Got the proper fuse box sticker for the 300tdi harness.
Old November 30th, 2015, 08:51 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Working on a little mod to the parking brake. Pulled a RRC brake lever and going to mount it right next to my seat.
I didn't like the looks of the RHD parking lever but did like having the leg room.
I cut off the flat steel on the RRC lever and welder a new one that would work with a Defender backing plate.
Old November 30th, 2015, 08:54 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Close up of the plate I made. Welded an M8 bolt as the bracket came where the hole was. I welded the bracket a little too far forward so the cable will bend a little but should still work fine.
Old November 30th, 2015, 09:03 PM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
Yes, nice when you get to the detail stage.
Old December 1st, 2015, 09:16 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks - good to have little things - but they take a lot of work too!
Old December 1st, 2015, 09:21 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Pic of the new parking brake.
Was hard to get a good picture with the cab being very dark.
Just sitting in the seat I really like how it feels - seems very natural. And it doesn't take up any leg room.
Old December 11th, 2015, 06:27 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Just a pic while moving it around he driveway today.
Lots of little stuff done since last time:
- soft top install (although it shrank)
- doors
- stainless Allen head bolts for the hinges
- outer grille install
- winch install (with new red 1 gauge Ancor cable on the Pos side)
- reman Saab 900/9000 130 amp alternator install with new Ancor 4 gauge going back to the battery
- voltmeter install
- had the local Foreign Car shop adjust the valves and install NOS Merc injector lines that they had on shelf
There is still a bunch of little things to do and fix and then I'll start on the interior.
Red or Blue 5 door 110 1of40 Wanted 0 May 24th, 2013 03:59 PM
1986 Defender 110. 5dr (2.5 diesel) - $8000 CDN90 The Flea Market 3 May 31st, 2010 04:08 PM
1986 Land Rover 110 Soft-Top Tdi Lurker For Sale - Vehicles 3 June 7th, 2006 10:03 AM
1986 110 Sation Wagon thewap For Sale - Vehicles 32 June 1st, 2006 10:05 PM
110 3dr military Land Rover forsale headdamage For Sale - Vehicles 7 February 22nd, 2005 12:47 AM
