Blue Mule - 1986 110 3dr Build - Page 18 - Defender Source
Old November 2nd, 2015, 05:37 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by don View Post
With the P&P cage there are a couple of pieces that attach to the rear crossmember and then to the upper tub platform. With my 255 on the rear door I noticed all sorts of flex with the latch stop.
I made this little piece that will bolt to the lower cage supports. After install the rear door was a LOT stiffer. I will make a piece that will bolt to the as well as tie into the brackets for the rear most cage hoop.
That support is excellent.
I would galvanize it to prevent the steel aluminum galvanic corrosion.
RDavisinVA
Old November 2nd, 2015, 06:11 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by rdavisinva View Post
That support is excellent. I would galvanize it to prevent the steel aluminum galvanic corrosion.
Thanks Robert - for now it will stay raw as I have some more fab work to do. I want to keep it so it is easily removable and will have items added onto it like speakers for lower seat belt reel mounts.
The tub will eventually be Line-X'd - and with the supports on the inside I will just have them powder coated. FYI - The supports underneath attached to the chassis are galvy'd and heavily smeared with anti-seaze on contact points.
Old November 7th, 2015, 04:31 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Made a couple of plates for the M10 bolts going to the lower cage bracket. The frame cross material is a little thin as many of you know.
Old November 7th, 2015, 04:32 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
View of the P&P rear cage lower brackets where it attaches to the rear cross member.
Galvanized and tons of anti-sieze. Had to make a 1x1 spacer up top.
Old November 7th, 2015, 04:35 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Plate and M10 bolts I got from Fastenal. They are more corrosion resistant than galvanizing and are 10.9 grade. Expensive but worth it for the application.
Old November 7th, 2015, 04:56 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
View of the inside plate and wiring. I will tidy up the wires down the road.
Old November 7th, 2015, 06:45 PM
Nice work!
Originally Posted by pendy
I'm here for the D's
Old November 7th, 2015, 07:15 PM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
Tons of work in this thread. Nice job.
When are you hoping to have it up and running?
Seems to be getting much closer
Old November 7th, 2015, 07:42 PM
As usual Don - giant thumbs up
Old November 14th, 2015, 10:55 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks Galpin, RoverDoc and Lostchord! Getting closer and closer to the stage 1 finish line where I will actually be able to take it for a drive.
This week I messed with making a catch can for the OM617.
I had some scrap stainless around so just threw it together. 3 @ 1/4" NPT bungs were added - one from the valve cover, one from the air intake and one to dump back into the oil pan.
Old November 16th, 2015, 10:33 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Was able to back it out of the garage today.
Lots of little things to do but felt real good to be able to move it and get a test run down the street.
Old November 16th, 2015, 10:40 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Another on the test track
Old November 16th, 2015, 11:04 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Looks great! Must be a good feeling!
Old November 16th, 2015, 11:05 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks!
Have to admit it felt damn good to hop in an give it a drive after all the time spent working on it.
Old November 17th, 2015, 07:45 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
There arent any dirt roads in Rumson, driveways dont count. You on Brown rd across the river?
Old November 17th, 2015, 07:59 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Nope - it's the secondary driveway / pump & mini bike track.
You can't tell from the pic but it's resting on a 2 ft tall roller up front. I have a log from a tree I cut down that I am going to add at some point.
Old November 17th, 2015, 08:06 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Was able to back it out of the garage today. Lots of little things to do but felt real good to be able to move it and get a test run down the street.
That truck looks happy to be out of the kennel. .
Old November 17th, 2015, 11:17 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Haha - kennel indeed!
Old November 17th, 2015, 11:23 AM
DannyboyUpstate's Avatar
DannyboyUpstate
Danny Harrington
1983 110 3-door
Truck looks awesome. That catch can is intense.
Old November 17th, 2015, 11:54 AM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Looks great! How did the motor feel?
Red or Blue 5 door 110 1of40 Wanted 0 May 24th, 2013 04:59 PM
1986 Defender 110. 5dr (2.5 diesel) - $8000 CDN90 The Flea Market 3 May 31st, 2010 05:08 PM
1986 Land Rover 110 Soft-Top Tdi Lurker For Sale - Vehicles 3 June 7th, 2006 11:03 AM
1986 110 Sation Wagon thewap For Sale - Vehicles 32 June 1st, 2006 11:05 PM
110 3dr military Land Rover forsale headdamage For Sale - Vehicles 7 February 22nd, 2005 01:47 AM
