Blue Mule - 1986 110 3dr Build - Page 16 - Defender Source
Old August 25th, 2015, 08:11 PM
You and Kang... At least you had a reason to replace your floor! Any reason you didn't rivet the ribs?
Originally Posted by pendy
I'm here for the D's
Old August 25th, 2015, 08:48 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I might do the center rib with rivets. I wanted a smooth floor too but that is a mute point now that it will have some waves from the weld heat.
And on Soronoros' thread it seemed that blind rivets wouldn't hold long term. Also - to be honest I thought this would weld up pretty easily... Live and learn.
Old August 26th, 2015, 04:31 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Don,
How thick is the aluminum sheet? I have a MIG spool gun you can use, you may be better off with that and lots of small tack welds to help curb warping.
Old August 26th, 2015, 06:41 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Dont know if I said it here or not but instead of using the squared ribs under the floor to add stiffness. Why not just get the floor rolled? That way you dont need rivets and you keep the floor smooth.
Old August 27th, 2015, 08:30 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by bossman429 View Post
Don, How thick is the aluminum sheet? I have a MIG spool gun you can use, you may be better off with that and lots of small tack welds to help curb warping.
3/32" - I think I have a decent process now to get a tig bead on it without twisting too much. Problem is the one end I did is pretty bent up. I can clamp it down and get it straight so hopefully when I rivet it into the bed sides it will go where it is supposed to!
------ Follow up post added August 27th, 2015 09:33 AM ------
I was thinking that while looking at my rigging for the 20x last night. I can see why Rover did this type of construction as a monkey could put it together with the correct size spot welder. But there could be a much more elegant/better way to do it.
Old October 6th, 2015, 06:37 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Finished the other side of the front tub that was all corroded. Fingers cross that I will have the tub on the chassis this weekend.
Old October 6th, 2015, 07:58 PM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
Let me know if you need a hand.
Old October 7th, 2015, 06:43 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks Matt - will hit you up if I need another person to lift the tub
Old October 7th, 2015, 08:19 AM
budzny
Real4X4
NAS 97 ST/NAS 93 110/62
Birthday Committee Team
I can help too!
Sal
Old October 7th, 2015, 11:26 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by budzny View Post
I can help too! Sal
Thanks Sal - appreciate the offer will text you if I need an extra hand
Old October 13th, 2015, 01:51 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Tub ready to go on the galvy frame.
Paint came out pretty good for a rattle job. Good coverage and looks way better than what was on there. I really like how the galvy cross pieces on the black tub look.
Old October 13th, 2015, 08:12 PM
Looking good Don!
Old October 13th, 2015, 09:32 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Looking good Don!
Thanks Charles!
Old October 14th, 2015, 01:39 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Sweet!
Old October 14th, 2015, 07:21 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by diesel_jim View Post
Sweet!
thanks Jim!
Old October 15th, 2015, 03:34 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Doing all the little things to get the tub onto the frame.
I bought new rear pieces from YRM as the original material was corroded. I riveted the nut plates to it.
Then used stainless 318 bolts.
Outside view:
Old October 15th, 2015, 03:35 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Inside view:
Old October 15th, 2015, 03:36 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Another inside view. Forgot to mention that I used a bunch of anti-seaze on the threads.
Old October 15th, 2015, 06:53 PM
Looks wicked.
Old October 15th, 2015, 07:33 PM
Looks amazing Don - love following your build!
Red or Blue 5 door 110 1of40 Wanted 0 May 24th, 2013 03:59 PM
1986 Defender 110. 5dr (2.5 diesel) - $8000 CDN90 The Flea Market 3 May 31st, 2010 04:08 PM
1986 Land Rover 110 Soft-Top Tdi Lurker For Sale - Vehicles 3 June 7th, 2006 10:03 AM
1986 110 Sation Wagon thewap For Sale - Vehicles 32 June 1st, 2006 10:05 PM
110 3dr military Land Rover forsale headdamage For Sale - Vehicles 7 February 22nd, 2005 12:47 AM
