Blue Mule - 1986 110 3dr Build - Page 14 - Defender Source
Old July 31st, 2015, 01:01 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Welded all the way around the V Clamps. My welding buddy gave me a few pointers on how to set the backpurge up. There was a ring of penetration and mostly clean on the insides. Outside had some decent beads but I still need to do better. HAZ was pretty tight and consistent.
Old July 31st, 2015, 02:30 PM
Looking good!
Originally Posted by pendy
I'm here for the D's
Old July 31st, 2015, 02:35 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by cgalpin View Post
Looking good!
Thanks Charles - I might do a 3" exhaust down the road and will fix all my mistakes.
Here is the section that will go over the axle - tacked for now - hoping to final burn it later today.
Have to figure out how to get it to exit out of the inside frame.
Old July 31st, 2015, 09:54 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Nice don! All the details are gonna be worth it in the end!
Old August 1st, 2015, 12:21 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks - but the end always seems to take longer and longer to get to!
Old August 7th, 2015, 11:10 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Added a little Rover chrome back to the tub. The smaller pieces I had media blasted and re-galvanized. The 2 big top rail pieces I had the pant stripped and cleaned them up.
Old August 8th, 2015, 12:26 AM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
Love it. nice work.
Old August 8th, 2015, 09:06 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by Roverdoc View Post
Love it. nice work.
Thanks!
Old August 8th, 2015, 11:11 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Just saw a clip from that 4x4 offroad fab show on spike. When he was welding tubes he taped the ends and had an inert gas being pumped into the tube so that when he was welding there would be less(?) to no containment in the weld of the interior. Was the latest episode on the website.
Old August 8th, 2015, 11:36 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
My welder buddy has been giving me tips on how to back purge to prevent sugar on the inside. I think my second regulator isn't working right as I thought the setup was correct but wasn't getting enough argon flowed thru. Down the road I will redo this exhaust in 3" and try and correct all my mistakes.
Old August 8th, 2015, 11:40 AM
LULZ - you are awesome! I wouldn't be able to see your mistakes even if you were pointing at them for me
Truck is coming along so nicely - one of my favorite threads/builds.
Old August 8th, 2015, 04:32 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by LostChord View Post
LULZ - you are awesome! I wouldn't be able to see your mistakes even if you were pointing at them for me Truck is coming along so nicely - one of my favorite threads/builds.
You are too kind! Really appreciate the kind words.
Old August 8th, 2015, 04:44 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Finally got the exhaust done. Well still need to clean the end and attached one more exhaust hanger.
The tailpipe was a bugger - 8 pieces and lots of bends. Had to cut welds and refit some pieces a few times.
Old August 8th, 2015, 04:51 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Attached to the truck. I fused the last few sections instead of using filler.
Old August 8th, 2015, 05:00 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Looking good - would like to see your full exhaust routing. Specifically how you worked around the front shaft
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old August 8th, 2015, 05:40 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
It's a little tight in one spot but overall just used to 90* pipes. I can try and get some pics of the exhaust routing from underneath.
Old August 8th, 2015, 05:47 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Maybe I missed it, but did you buy pre-bent sections and piece it together?
Old August 8th, 2015, 08:02 PM
Nice work. One of my favorite builds too!
Old August 8th, 2015, 10:25 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Yes - not sure if I mentioned it - tubes were mandrel bent sections most of them from Vibrant. Pretty good product for the price - most of it was bought at Summit. My local PepBoys carry it too but more expensive. Then cut to fit and prepped the edges for the particular bend.
------ Follow up post added August 8th, 2015 10:28 PM ------
Are you going to run a chrome tip? Hello Kitty Die Cut Car Exhaust Pipe New RARE | eBay -Jeff
Haha - it could add to the rarity of my build.
------ Follow up post added August 8th, 2015 10:29 PM ------
Thanks Charles - hope to finish this thing up and wheel with you and the boys again - it's been way to damn long!
Old August 10th, 2015, 09:15 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Started doing some work on the tub. This thing needs some work! Pulled the floor over the weekend. The lip that attaches to the floor is corroded where all the steel cross pieces attached. There also a vertical support that attached but there is no way to rebuild them. So I am cutting those to clean metal and then welding them to the sides. Also making drain holes in then bottoms of the vertical supports.
I took a before pic but must have deleted it. So here is the after - I have 7 more of these to do
Also filling in all the holes from the old seats and galvy strips.
Red or Blue 5 door 110 1of40 Wanted 0 May 24th, 2013 04:59 PM
1986 Defender 110. 5dr (2.5 diesel) - $8000 CDN90 The Flea Market 3 May 31st, 2010 05:08 PM
1986 Land Rover 110 Soft-Top Tdi Lurker For Sale - Vehicles 3 June 7th, 2006 11:03 AM
1986 110 Sation Wagon thewap For Sale - Vehicles 32 June 1st, 2006 11:05 PM
110 3dr military Land Rover forsale headdamage For Sale - Vehicles 7 February 22nd, 2005 01:47 AM
