Blue Mule - 1986 110 3dr Build - Page 12 - Defender Source
Old June 6th, 2015, 01:51 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Another shot
Old June 7th, 2015, 10:44 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Put some pieces of the grille support together.
I used the stock pieces but had them powder coated and galvanized. Still need some fine tuning but good to put some things on.
Old June 7th, 2015, 11:08 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
The stock grille had it's bottom cut out. I bought a replacement here on D-90 and thought it would be an easy swap. But I have found that there have been different grille surrounds over the years and the better one doesn't match up with the top radiator support.
So I am just going to fix the original grille.
Old June 8th, 2015, 11:44 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Finished up the grille surround.
Nothing fancy but should hold the plastic grille fine. It was some work but I am glad I ended up using the stock piece - it has a cut out for the hood lock and has the original Land Rover 110 sticker. I was feeling bad cutting up a good NAS one.
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Back view
Old June 8th, 2015, 11:45 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Lower corner detail
Old June 12th, 2015, 11:27 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Did a little bit on the seatbox today. Temps in the garage were 85 so why not weld some aluminum.
Once again the YRM panels worked a treat. Lined up and fit great. I was happy with how the aluminum came out so tried to fit the NAS storage bin to the box and it doesn't quite fit. Just like the grille it is close but not right. Bummed as I got the boxes galvy'd a while ago and was excited to put them on soon without an issue.
I might just patch the original storage bin and get those galvy'd as well.
Old June 12th, 2015, 11:51 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Originally Posted by don View Post
Lav's gauge holder looks trick as hell with the leather.
Attachment 116137
Hey Don where did you pick this up? Love it
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old June 13th, 2015, 08:24 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
@nathanwind - Jason Lav
And/or SeriesDefenders.com
I've been really happy with his products.
Old June 13th, 2015, 06:13 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Eff it - I decided to patch the RH seat box. A little bit of work but happy with how it came out. Once it gets galvy'd stuff should be dialed.
Going to fix the LH aluminum this week and see how bad the original LH seatbox is.
One thing I SMH about is how some parts of the Rover just trap moisture and there fore rust. I understand the fold and spot welds are quick and easy but where I have seen them on the bulkhead and these seat boxes its like Rover wanted them to corrode even quicker.
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Pix
Old June 13th, 2015, 06:14 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
No mud/water catching corner anymore:
Old June 15th, 2015, 01:32 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Finished the aluminum part of the seatbox today - going to drop it off at GSD to get line-X'd.
Before:
don's Avatar
don
Don Bunnell
'86 110 3dr ST
After:
Old June 16th, 2015, 07:27 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Battery box is in rough shape but I will give it a go to save it.
First corner - before
Old June 16th, 2015, 07:28 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I still have some welding to do but just about done.
The next patch is straight forward but the other corner makes this one look easy. I might just cut the old panel and make a new one.
Old June 18th, 2015, 08:44 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Even the small stuff seems to take a ton of time.
Had to reconfigure the washer tank bracket from RHD to LHD. Then went to powder. Rattle canned the nut clips.
Old June 18th, 2015, 08:49 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Then had to clean the plastic washer bottle best I could, used stainless M6 nuts on the bracket but regular steel ones where it attaches to the fender. Copper grease everything.
Then made a new mini harness to go from main to the washer pump. Attached the new tubing that has been hanging off the front of the bulkhead for months.
Fill with some Rain-X fluid I had in the bin and it everything works.
Next part is the finish the radiator / electric fan that I am dreading.
Old June 19th, 2015, 09:40 PM
Nice progress!
Originally Posted by pendy
I'm here for the D's
Old June 19th, 2015, 09:54 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by cgalpin View Post
Nice progress!
Thanks Charles!
Btw - meant to tell you I got those plugs. Very nice! Still need to install but they look great.
Red or Blue 5 door 110 1of40 Wanted 0 May 24th, 2013 04:59 PM
1986 Defender 110. 5dr (2.5 diesel) - $8000 CDN90 The Flea Market 3 May 31st, 2010 05:08 PM
1986 Land Rover 110 Soft-Top Tdi Lurker For Sale - Vehicles 3 June 7th, 2006 11:03 AM
1986 110 Sation Wagon thewap For Sale - Vehicles 32 June 1st, 2006 11:05 PM
110 3dr military Land Rover forsale headdamage For Sale - Vehicles 7 February 22nd, 2005 01:47 AM
