Blue Mule - 1986 110 3dr Build - Page 11 - Defender Source
Join the Defender Source Community Today
Old May 18th, 2015, 05:29 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
SDO :drooool:
Old May 18th, 2015, 05:34 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Moar SDO nrop
Old May 20th, 2015, 09:01 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I have been pulling my hair out (what little I have left) trying to get the glow plugs to work with the harness. First thing was the harness and I really wanted to keep the stock glowplug connector. I got the Mercedes relay to work with the Rover connector with some half ass connectors. The big problem was the glow plug light in the dash wasn't working correctly.
After a bunch of messing around I said eff it I will just wire the Mercedes GP light to the light itself. That didn't work either. WTF?
So after reading the electrical PDF file I had, I finally figured out that the glow plug light has power at ignition position II from the main white wire and the glow plug relay harness turns on and off the negative feed to it.
I had a positive feed from the Mercedes relay that turns on when the glow plug is engaged. I also found out that you can use a relay to "swap" polarity. Got the parts, did some re-wiring and it works.
As far as the Rover GP connector - I ended up just cutting it off and using covered spade connectors.
Relay harness I bought and attached some ends to it:
Old May 20th, 2015, 09:03 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Relay and wires
Old May 20th, 2015, 09:06 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Relay schematic:
Old May 20th, 2015, 09:24 PM
Originally Posted by don View Post
SDO :drooool:
Attachment 121101
Moar SDO nrop
Attachment 121103
DAMN those look GOOD !
Old May 20th, 2015, 09:30 PM
Nothing like an unbiased opinion. But I concur
Originally Posted by pendy
I'm here for the D's
Old May 22nd, 2015, 10:26 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I know right!
I am a sucker for small details that are trick. Was like that when I was a kid racing BMX and would droll over items like Bullseye and Phil Wood hubs and Red Line pinch bolt cranks and chain wheels. So seeing these aluminum pieces right in front of my eyes will make me smile every time I drive the D.
Old May 24th, 2015, 06:09 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Loving your attention to detail Don.
Legend in My Own Mind.
Old May 24th, 2015, 09:42 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks Randy! I feel like I am rounding the last turn on this build - mostly body part work now.
Old May 24th, 2015, 09:44 AM
sounds great don....almost there...
Old May 24th, 2015, 10:14 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
thanks Ed!
Old June 5th, 2015, 12:16 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Made a bracket for the sedimenter. I had some stainless sheet laying around so made it out of that so things didn't get corroded. Since the sedimenter is aluminum I used steel bolts and some washers to keep it off the stainless. I used existing holes in the chassis so I didn't have to drill.
Old June 5th, 2015, 12:17 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Backing but plate I made
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Installed
Old June 5th, 2015, 12:20 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Fuel hoses are getting organized. Using some M5 nutserts and plastics clips to hold them on. Clip one would have been much easier but I couldn't find ones that fit the rubber line I am using.
Old June 5th, 2015, 12:21 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Fuel pump - tucks in under floor board and on top of chassis rail.
Old June 5th, 2015, 09:18 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Don doesn't the om617 have a built in filter and fuel lift pump?
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old June 5th, 2015, 09:45 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
It does - but the sedimenter should grab a lot more containments and the electric fuel pump makes it easier to prime and is a level of redundancy. Robert Davis has a lot more insight on this setup.
Old June 6th, 2015, 12:51 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Got the return line sorted today.
Red or Blue 5 door 110 1of40 Wanted 0 May 24th, 2013 03:59 PM
1986 Defender 110. 5dr (2.5 diesel) - $8000 CDN90 The Flea Market 3 May 31st, 2010 04:08 PM
1986 Land Rover 110 Soft-Top Tdi Lurker For Sale - Vehicles 3 June 7th, 2006 10:03 AM
1986 110 Sation Wagon thewap For Sale - Vehicles 32 June 1st, 2006 10:05 PM
110 3dr military Land Rover forsale headdamage For Sale - Vehicles 7 February 22nd, 2005 12:47 AM
