Blue Mule - 1986 110 3dr Build - Page 10 - Defender Source
Old May 2nd, 2015, 06:07 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Worked on the wiring - made a few small looms for the items by the transmission:
1 Diff Lock, Reverse, and Handbrake switch signals
2 pos & neg for fuel pump
3 pos, neg and sender for speed tranducer
The will follow the tran and x-fer case breathers to the engine compartment.
Attachment 119802
Old May 2nd, 2015, 06:12 AM
Fenders and front should be done after doors and body. Much easier (ask me how I know) as the bulkhead needs to be adjusted to get the doors right in most cases.
Old May 2nd, 2015, 07:43 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Pic doesn't seem to come up on my phone
Old May 2nd, 2015, 07:44 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Speed transducer
Old May 2nd, 2015, 07:55 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Looks like a rats nest of wiring but pretty much know where things have to go. Hoping to wrap this up this week.
Old May 2nd, 2015, 08:05 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I searched for tutorials on how to fit the body as I had some questions about attaching the fenders but couldn't find. Makes sense but can't get the tub off quite yet. I've had the one fender off and on a few times so will just set them loosely.
Old May 2nd, 2015, 08:57 AM
Originally Posted by don View Post
Speed transducer
Attachment 119808
Looking good. That's 3 wires so a YBE100540? Any chance you have the part numbers for the connector and the gear drive with the larger hole to match this? I really need to do this for both my 90 and the 109 project.
Originally Posted by pendy
I'm here for the D's
Old May 2nd, 2015, 09:36 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Yes - 3 wire - I bought a connector from 3way in the UK. But I also have a pigtail connector that will fit if you want it - (I just wanted the correct color wires from the connector). I should have your address and can throw it in the mail for you if you want it.
Iirc I just used a normal gear drive (blue maybe) - bought the parts from RovahFarm. I can look up exactly what I have when I get home.
Old May 2nd, 2015, 08:49 PM
Awesome, I don't care about the wire colors. I'll send you a PM, thanks.
Old May 11th, 2015, 03:34 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I used the old chassis wires and redid the front and backs with new connectors. Retaped the thing as well.
Here are some pic of the back wires - fuel gauge works, reverse, blinkers, marker/brake lights and the fog and interior tested well. I capped off the wires that go to a SW door.
Thinking of running 2 UK/ROW clears on both sides of the tub for reverse and getting a Hella LED work light to be switched with the fog light switch.
Old May 11th, 2015, 03:37 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Fuel gauge wiring - I also did the left side ground to use a threaded nut-sert nearby
Old May 11th, 2015, 03:38 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
The NAS style connectors
Old May 11th, 2015, 06:29 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
The wiring harness I had didn't have a main/engine fuse box and the wires were cut so the correct part fuse box I ordered from RN couldn't be used. I ended up going with a Blue Sea that had the 60A per bus capabilities I needed for the main line and glow plugs.
Ran 10G Anchor wiring to lengthen the stock wires so the new fuse box can be placed on the driver's side fender when it gets installed. I will make a plate with welded nuts to hold the Blue Sea and Merc glow plug module.
Old May 11th, 2015, 06:30 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Cover on - I used duct tape and silver Sharpie to label the 4 main lines. 4th one is AC or rear door which I am not using.
Old May 14th, 2015, 09:47 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Looking great don. Will have to come see t sometime before its all put back together and on the road!
Old May 14th, 2015, 10:45 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks Adrian - stop by any time!
Old May 14th, 2015, 06:33 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Got the OM617 to fire the other day from the key which felt pretty good. It had been sitting for months and started right up. This is a vid of the second video moments later.
Old May 17th, 2015, 07:36 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
grats! Don. Keep pluggin.
Old May 18th, 2015, 06:25 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks Clay - little by little
Old May 18th, 2015, 06:27 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I had these headlight surrounds laying on the shelf for years - got them from a Lucky8 group by. Was good to install them this weekend along with one of the LED headlights and Wipac/RN smaller LED's.
Red or Blue 5 door 110 1of40 Wanted 0 May 24th, 2013 04:59 PM
1986 Defender 110. 5dr (2.5 diesel) - $8000 CDN90 The Flea Market 3 May 31st, 2010 05:08 PM
1986 Land Rover 110 Soft-Top Tdi Lurker For Sale - Vehicles 3 June 7th, 2006 11:03 AM
1986 110 Sation Wagon thewap For Sale - Vehicles 32 June 1st, 2006 11:05 PM
110 3dr military Land Rover forsale headdamage For Sale - Vehicles 7 February 22nd, 2005 01:47 AM
