Big Red's Resurrection - Defender Source
Old January 4th, 2016, 10:19 PM
Mikeproc
1985 Defender 110
Hey guys, I'm Mike. I recently bought Kent's (85red110) truck and have started a little rebuild. Initially I had planed on replacing the seats and fixing some of the rust in the frame and bulkhead then just start driving and enjoying the awesome truck Kent had setup. Once I got the truck home and started digging into the bulkhead and foot box I realized the rot was a little worse then I expected. After a few days of thinking about it and discussing my eventual plans for the truck with Mike and Chris from North America Overland, I was convinced I needed to dig deeper into Big Red and just go ground up. I decided to strip all the spray in bedliner, swap to lhd, go with a galvanized frame, and fix a lot of the wiring to say the least. Enough talking lets see some pictures I will continue to update everything as I progress but it wont be super fast as I am doing all the work after work and still need to figure out my part list and everything else.
------ Follow up post added January 4th, 2016 10:21 PM ------
------ Follow up post added January 4th, 2016 10:23 PM ------
Old January 4th, 2016, 10:24 PM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
Very nice. Good work so far.
Old January 4th, 2016, 10:30 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Dang getting after it! Nice pics, thanks for posting! Looking forward to watching the build.
Old January 4th, 2016, 10:32 PM
Great to finally see a post on this truck. Nice progress and looking forward to the build!!! Wish I had time to do anything on the truck.
Old January 4th, 2016, 10:47 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Why the change from Rhd to Lhd?
Old January 4th, 2016, 11:05 PM
Mikeproc
1985 Defender 110
Since I've gotten so far into it I decided to just make it for me, I prefer to drive lhd and it will make everyday driving needs easier (Drive thrus at banks and food, toll booths since I don't do easy pass.) Another positive is my girlfriend will feel more comfortable driving on whatever trips we go on since she only drives once in a while. Plus it makes for a fun project!
Old January 5th, 2016, 08:56 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Plus the resale valve. RHD is a fun/cool experience but you can see why vehicles are LHD here in the US pretty quickly.
And great work on the truck!
Old January 5th, 2016, 09:08 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Are you going to keep it Big Red or Big Some Other Color?
Old January 5th, 2016, 09:09 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Am I missing something? That chassis looks pretty good from the photos. Is it really worth it to replace?
Either way, nice work!
Old January 5th, 2016, 09:14 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Good point - chassis doesn't look bad from the pics. Maybe strip and galvy if doing a full rebuild of the axles and suspension or just clean and coat with something like POR-15 or Eastwood chassis paint.
Old January 5th, 2016, 09:21 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Great that your g/f is participating in the build. She is a keeper.
Old January 5th, 2016, 11:01 PM
Mikeproc
1985 Defender 110
Thanks guys! To answer some questions, the plan for paint is Arles Blue. The Chassis isn't too bad but it needs a rear crossmember and has a good size hole on the RH side behind the front wheel and a couple little holes by the front bumper mounts. I'd rather just start fresh with a perfect chassis that will last a while until its time to redo the rest again. The axles are getting rebuilt I have some 24 spline axles ill be dropping in the new frame with a true trac up front and I will probably get a Detroit for the rear. All depends how Mike likes that setup in his 110. My gf is helping with the project although the picture is my sister. She helped out 1 day while she was home and had a great time at the CT Happy hour. This week I'm still working on the tub prep, trying to get as much of that done as I can to save some body shop hours. I am waiting on a heater box so I can mount that up and make my final cuts to the bulkhead before I take it off the frame and start fixing all the holes in that.
Old January 5th, 2016, 11:03 PM
It lives! Thanks for sharing your buildup!
Old January 6th, 2016, 08:17 AM
Willh's Avatar
Willh
Will Hedrick
Use to own NAS #96, #1778, & #1008
This was a great way to start off my morning! Mike, thanks for sharing your progress and good luck with Big Red's rebuild!
Please feel free to visit my website at:
Willh is the F'n man! Defender of the Defenders! - Overlander
Old February 21st, 2016, 10:45 PM
Mikeproc
1985 Defender 110
Its been a while so I figured its time for an update. Progress has been going well, lots of little things getting done. A LOT of sandblasting for one. Every piece I take off that is being reused has been sandblasted and primed and dropped off at the body shop. I'm finished up with the old frame and will try to get some good photos of that soon if anyone is interested in that. I converted the heater box to lhd and just started converting the rhd dash to lhd. Sal sent me a link to a leather dash cover so I ordered one up to see how it would work and it looks great! I can't wait to cover the finished dash and get a good look at it. It makes the swap much more affordable. My father and I spent the weekend cutting and bending to repair the bulkhead and lower dash swap. My Gf and I tore the wiring harness for the rear apart and checked for any problems and added some wires for the new rear door and trailer wiring ect... I brought the body back in to pull the capping and finish up the sanding before bringing to the body shop. I'm sure theres more but time for pictures.
Old February 21st, 2016, 11:19 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Great progress!
Old February 22nd, 2016, 07:00 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Wow! Looking great - top work!
Old February 22nd, 2016, 07:29 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Great Job.. Girlfriend is a keeper!
~ Semper Fidelis ~
Old February 22nd, 2016, 08:05 AM
cjbenway's Avatar
cjbenway
Chris Benway
1984 LR 90 ( Hedrick Rover )
Nice!
Are you going to turn it into a 5 door?
....how labor intensive would it be?
Old February 22nd, 2016, 08:38 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Originally Posted by cjbenway View Post
Nice! Are you going to turn it into a 5 door? ....how labor intensive would it be?
Less labor more $. Unobtainium 2nd row doors and misc parts. If you want a 5 door best to start with one imo
Big Red is now for sale 85Red110 For Sale - Vehicles 46 November 20th, 2015 12:52 PM
Big Red :: 1997 Land Rover Defender jec Defender & Series Truck Registry 0 July 13th, 2015 11:07 AM
LA Happy Hour Resurrection bjf Trips, Trails and Events 26 November 29th, 2014 03:41 PM
Sam's 110 resurrection One Ten Truck Build-up's & Restores 119 April 8th, 2012 02:07 AM
Resurrection of SG? Overlander Misc. Chit-Chat 46 February 27th, 2009 02:18 PM
