Andrew's Defender 90 3.0i Project - Page 29 - Defender Source
Old June 2nd, 2016, 01:37 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Indeed! Fun to follow. Almost time to get out the buffer ;-)
"Barry is correct!"
Old June 2nd, 2016, 01:48 AM
Chip's Avatar
Chip
Andrew Harvey
1994 NAS Defender 90
Yeah for sure. I need to wash all the pollen off of it. I think it's from the fir trees.
Old June 2nd, 2016, 08:35 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
That BMW mill looks quite nice in there!
Jealous of that lift.
Old June 2nd, 2016, 02:37 PM
Chip's Avatar
Chip
Andrew Harvey
It's nice having a lift to work with.
This might be the only Defender with a secondary air injection system. I selected this newer pump (for X3 and Z4) that outputs a higher volume (45 kg/hour). It'll significantly reduce cold start emissions and it'll be convenient when I go in for emissions testing because I won't have to drive around as long waiting of the catalysts to heat up to operating temperature.
Old June 2nd, 2016, 04:24 PM
Willh's Avatar
Willh
Will Hedrick
Use to own NAS #96, #1778, & #1008
Originally Posted by Chip View Post
It's starting to look like a truck again.
Andrew,
Looks great sir! Think she'll see the road this summer?
Please feel free to visit my website at:
Willh is the F'n man! Defender of the Defenders! - Overlander
Old June 2nd, 2016, 04:36 PM
Chip's Avatar
Chip
Andrew Harvey
Thanks. Yes, lots to do still, but I can do it.
Old June 2nd, 2016, 09:50 PM
Awesome
But damn you are making me look bad.
Originally Posted by pendy
I'm here for the D's
Old June 8th, 2016, 05:44 PM
Chip's Avatar
Chip
Andrew Harvey
New muffler.
Old June 14th, 2016, 10:13 PM
Chip's Avatar
Chip
Andrew Harvey
I got a Bearmach aluminium centre panel to fit the round analogue clock (part BA 2706) and it has a spot for the cigarette lighter and a rear window wiper switch, but of course I want to install a hazard switch there instead of the wiper switch. So I looked around for a nice round one I could modify the hole to fit. I found this Hella one that's OEM for the Porsche 911 on Amazon Spain. It looks like I would wire it the same as the Carling switch some people install.
Old June 24th, 2016, 12:20 AM
Chip's Avatar
Chip
Andrew Harvey
I tested 4 throttle pedals using a 12v power supply with a 5v converter. Here are the results I got. Figures shown in volts, from rest to full throttle.
Pedal #1: BMW E53 X5 3.0i (auto)
-Hall sensor 1 (request) = 0.737 to 4.333 (4.925 with kick-down switch pushed down)
-Hall sensor 2 (plausibility) = 0.368 to 2.178 (2.461 with kick-down switch pushed down)
Pedal #2: Freelander 1
-Hall sensor 1 (request) = 0.630 to 3.222
-Hall sensor 2 (plausibility) = 0.328 to 1.574
Pedal #3: Porsche 996
-Hall sensor 1 (request) = 0.639 to 2.807
-Hall sensor 2 (plausibility) = 0.316 to 1.376
Pedal #4: Defender Puma
-Hall sensor 1 (request) = 0.576 to 2.615
-Hall sensor 2 (plausibility) = 0.289 to 1.068
The X5 pedal was a little worn out. I had it leftover from when I replaced it with a new one in mom’s car. You had to press it down a little before it engaged. But it seems to return acceptable values when tested.
The Freelander 1 pedal has the same Bosch potentiometer used in the Z3 with M54. The Porsche 996 pedal has a similar Bosch potentiometer and oddly enough the connector on it says BMW. Those two were used also. Only the Defender Puma pedal was new. To be really scientific I should have used all new pedals, but that would have cost a lot of money (the older Bosch potentiometers are $400).
I selected the Porsche 996 pedal for the potentiometer because it’s activated by a cable so if I were to mount it somewhere on the truck I could use my truck’s original pedal with it. The Freelander pedal would need modification to fit properly.
I would prefer to use the Puma pedal for simplicity. From the results I think it’ll work out fine. It makes two positive slopes like the others. I’m pretty sure the ECU will adapt to the different values.
Old June 24th, 2016, 11:58 PM
Very interesting. If you recall the td5 pedal has slopes with one increasing and one decreasing with values that sum to 5v.
Old July 23rd, 2016, 06:58 PM
Chip's Avatar
Chip
Andrew Harvey
Yeah, it would be interesting to test one of those.
It's been a while since I posted an update. I've been really busy with working and other things so I haven't been able to work on the truck much. It's looking like it'll be autumn before it's rolling down the road (or off road). But that's okay.
I've done a few things lately. I took off the rear panels on the tub, which wasn't very difficult. I just needed to drill out the spot rivets. And I took off all the cappings; on the tub, doors, and tailgate. I'll take those and a bunch of other steel parts to get galvanized this week. It was very difficult to get the door tops off the door bottoms. I was able to get one side off by just beating the studs up with a hammer, but the other side wouldn't budge. Then we finally realized heating them up with a torch made them slide out easy.
I got a few body parts shipped over from the UK. A bonnet. The latest Td5 type with an aluminum frame. I think it'll be a shame to paint it because the Tonga Green Metallic is really nice, especially when the sun hits it, turns shimmery gold/bronze.
A front centre radiator panel. This one came off a Puma, non-A/C. It looks exactly the same as the 97 NAS. Perhaps the holes on the bottom will allow more air to flow over the radiator.
And a brand new seat base assembly.
I have all the parts I want to paint now.
Old July 25th, 2016, 01:36 PM
Chip's Avatar
Chip
Andrew Harvey
I also got new genuine Land Rover doors and front outer wings. I noticed the aftermarket outer wings were missing the spot welds along the rear edge. I decided since the truck is a NAS it needs to have original construction, so no aftermarket body parts. Eventually I'll need to get a new tub too (along with a bulkhead).
Here are the parts I rounded up to galvanize.
Old August 4th, 2016, 01:34 PM
Chip's Avatar
Chip
Andrew Harvey
I got my parts back from the galvanizer.
Old August 4th, 2016, 01:56 PM
looking good!
Old August 12th, 2016, 02:14 PM
Chip's Avatar
Chip
Andrew Harvey
I've been trying to decide what to do about the footwell trim. At first I found some that covered them nicely (BTR5235 & BTR5236), but I preferred them to have a texture rather than smooth, so then I decided I would just use the NAS ones that cover the kick panel area only. I don't care much for the hokey cardboard trim for the driver's footwell though and I would still need to get the center section to cover fuse box area, which is quite expensive. So then I found these footwell trims from a Td5. They extend over the center fuse box area so I don't need that piece and they have the texture that matches the tunnel cover and Puma seat box cover I got. I think it'll give the interior a nice finished look. One thing a bit odd is that LR doesn't seem to list the part numbers for these footwell trims and on the various forums no one has been able to find them from what I can tell, so we assume these are NLA, but I can't confirm that. Another option I think would work would be to buy the footwell trims for the Puma (part # LR013013 for LHD, 1 piece) and also the V8 center section (ETD103270) and cut them to fit the center section since the tunnel is different. The RH Td5 trim has the place for the bonnet release, so I suppose I'll install that one.
Old August 12th, 2016, 02:17 PM
bjf's Avatar
bjf
barry f
94 ST #395
I've been trying to decide what to do about the footwell trim. At first I found some that covered them nicely (BTR5235 & BTR5236), but I preferred them to have a texture rather than smooth, so then I decided I would just use the NAS ones that cover the kick panel area only. I don't care much for the hokey cardboard trim for the driver's footwell though and I would still need to get the center section to cover fuse box area, which is quite expensive. So then I found these footwell trims from a Td5. They extend over the center fuse box area so I don't need that piece and they have the texture that matches the tunnel cover and Puma seat box cover I got. I think it'll give the interior a nice finished look. One thing a bit odd is that LR doesn't seem to list the part numbers for these footwell trims and on the various forums no one has been able to find them from what I can tell, so we assume these are NLA, but I can't confirm that. Another option I think would work would be to buy the footwell trims for the Puma (part # LR013013 for LHD, 1 piece) and also the V8 center section (ETD103270) and cut them to fit the center section since the tunnel is different. The Td5 trim on the RH side has the place for the bonnet release, so I suppose I'll install that one.
I have these new still in package with part numbers. They are long NLA.
The puma ones wont really fit.
Old August 12th, 2016, 02:22 PM
Chip's Avatar
Chip
Andrew Harvey
Okay, good to know.
------ Follow up post added August 12th, 2016 11:29 AM ------
Since they're NLA maybe I shouldn't make a cut out for the VIN sticker then. I could just remove the trim when I need to go in for emissions testing so they can read it.
Old August 13th, 2016, 09:06 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Are you selling a se of these? I'm looking for a pair myself
Legend in My Own Mind.
Old August 13th, 2016, 11:55 PM
bjf's Avatar
bjf
barry f
94 ST #395
What are they worth?
90, defender, defender 90
Andrew Howton chrisvonc Defender Owners 0 February 24th, 2004 11:52 PM
Andrew Lees chrisvonc Defender Owners 0 February 24th, 2004 11:44 PM
Andrew Krna chrisvonc Defender Owners 0 February 24th, 2004 11:40 PM
Andrew & Jean Ward chrisvonc Defender Owners 0 February 5th, 2004 10:54 PM
Andrew Silcock chrisvonc Defender Owners 0 February 1st, 2004 11:55 PM
