Andrew's Defender 90 3.0i Project - Page 14 - Defender Source
Old May 20th, 2015, 06:34 PM
Chip's Avatar
Chip
Andrew Harvey
1994 NAS Defender 90
Making some progress. Got the body off of the chassis.
Those bolts were sure rusty. Most of them broke off. We had to use a grinder to cut off the lower bulkhead bolts and one of the rear roll cage support bracket bolts.
Old May 20th, 2015, 06:36 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Originally Posted by Chip View Post
Making some progress. Got the body off of the chassis. Those bolts were sure rusty. Most of them broke off. We had to use a grinder to cut off the lower bulkhead bolts and one of the rear roll cage support bracket bolts.
your grin shows how happy you are!
Old May 20th, 2015, 07:33 PM
Hey, that's cheating!
Originally Posted by pendy
I'm here for the D's
Old May 20th, 2015, 09:07 PM
RBBailey
RBBailey
1965 IIa
LOL! That's awesome!
Project:
1965 IIa SWB
Old May 20th, 2015, 10:04 PM
Roverenvy's Avatar
Roverenvy
Michael
1994 Defender 90
Andrew, sorry for the delayed response. I don't have the part number, but if you don't have it by now....just google defender alpine sub UK it'll come up. It was a pain in the ass to order, but it gives good range....but not a huge thump like my old kenwood dual 12" old box! But given its low profile, easy of install behind the center console I love it. I didn't want anything on the rear door as it'd be more exposed to the elements and take away from cargo. I've also seen a replacement frame that swaps out the battery seat box panel for a spot to mount a small sub under the seat. Also not a bad option
Old May 20th, 2015, 11:02 PM
When you reinstall the bulkhead bolts, slather the shafts in anti-seize. Actually I slather everything in anti-seize. I prefer wurth copper but the silver permetex works well too.
Old May 20th, 2015, 11:34 PM
Chip's Avatar
Chip
Andrew Harvey
OMG! For sure! Every bolt will be slathered in anti-seize compound!
Old May 23rd, 2015, 09:03 PM
Ron, any specific reason you prefer Wurths? I did a search and it seems you have to go to a fair amount of effort to sign up on their site or pay about $45 for a can of it.
Old May 24th, 2015, 04:03 PM
Chip's Avatar
Chip
Andrew Harvey
Nickel anti-seize looks like it might be even better. Link: Amazon.com: CRC SL35911 Nickel Anti-Seize Lubricating Compound - 8 wt. oz.: Automotive
Old May 24th, 2015, 04:37 PM
Isn't the name of the game to reduce galvanic corrosion between dissimilar metals at the points where the fasteners contact the thing being fastened? According to this you'd have a greater difference between iron/steel and nickel than with copper.
Galvanic and Corrosion Compatibility Dissimilar Metal Corrosion - Engineers Edge
Although this chart doesn't really make a strong case for galvy and anything else. Unless I am missing something, according to this chart, aluminum, lead or tin would all be better.
Old May 24th, 2015, 05:00 PM
Chip's Avatar
Chip
Andrew Harvey
Ah ha. I was just considering the anti-seize ability of the paste. Good point.
Old May 24th, 2015, 05:31 PM
Chip's Avatar
Chip
Andrew Harvey
Let’s see if I’m understanding this correctly. There’s only 0.05-0.10 V difference in the "Anodic Index” between aluminum and iron, so typically galvanic corrosion would not occur when they are in contact with each other, but in an environment where iron rusts such as in the presence of water (which enables movement of electrons), there’s galvanic corrosion of the aluminum because iron is more cathodic (higher standard reduction potential). And when the steel that is in contact with aluminum is coated with zinc it prevents galvanic corrosion of the aluminum because it’s more anodic (higher standard oxidation potential). But then wouldn’t the aluminum eventually cause the zinc coating to corrode away especially since there’s 0.30-0.35 V difference between them? So would it then be best to try to prevent contact between aluminum and galvanized steel? And now I can see why using stainless steel fasteners is a bad idea since it’s more cathodic than regular steel.
Old May 24th, 2015, 05:54 PM
Chip's Avatar
Chip
Andrew Harvey
Ah, here's my answer.
"Problems can also occur where the metallic combination is galvanised steel and aluminium. The zinc coating of the galvanised steel will, at first, prevent the aluminium being attacked. However, this protection disappears when the steel surface is exposed after the consumption of the zinc.
As it has a thicker zinc coating than electroplated material, hot dip galvanised material gives longer protection. Thus, in combination with aluminium in aggressive environments, hot dip galvanised material should be used." From: Aluminium Corrosion Resistance - Aluminium Design
So that's interesting. In a harsh environment like the NE where they salt the roads I could see that eventually galvanized parts on a Rover would need to be re-galvanized. In Oregon though where things don't rust much I probably won't have to worry about that.
Old May 24th, 2015, 11:40 PM
I just like wurth Charles. It seems nicer, but there is no principled reason other than I think copper is better. There is usually a dealer somewhere. The HS2000 (or whatever they call it now) is the best spray lubricant I have found.
Old May 25th, 2015, 02:37 PM
Thanks Ron
Andrew, I am still totally unsure what's best for this, other than physical separation of the steel and aluminum with plastic or rubber where possible. I guess for the ant-seize we are mainly talking steel on steel right?
Old May 25th, 2015, 03:12 PM
Mendicant
I use anti-seize for anything stainless to keep the threads from galling, but I don't rely on it exclusively to separate metals. I like to cut my favorite pond liner washers for lots of things and also make washers out of heavier plastic as well. I always have trouble getting the washers I want so that's why I cut my own.
Old May 25th, 2015, 09:36 PM
Chip's Avatar
Chip
Andrew Harvey
Originally Posted by cgalpin View Post
Thanks Ron
Yeah, I'll just use my regular Permatex stuff. I'm sure it'll be fine. I don't plan on ever taking out those bolts again anyways.
------ Follow up post added May 25th, 2015 07:37 PM ------
Thanks for the tip.
Old May 25th, 2015, 09:46 PM
Grover's Avatar
Grover
Thumbs up
I have made plenty of washers and gaskets from shower/hot tub liner as well. It's held up for 10 years with no problem...
Cheers...
Old June 13th, 2015, 01:28 PM
Chip's Avatar
Chip
Andrew Harvey
As Jackie Treehorn pointed out, the M54 sometimes suffers from PCV/CCV problems. It can clog up and fill the engine with "mayonnaise" in cold weather. That's how the engine failed in our E46. To prevent that from happening to this engine, and to also lower evaporative emissions, I got a M56 valve cover that has the integrated CCV. The M56 is the "Super Ultra Low Emission" version of the M54 sold in California, New York, Massachusetts (2003 to 2006), and Vermont (2004 to 2006). It has a different plastic engine cover as well, which isn't quite as attractive in my opinion, but hey we're going for functionality here.
Old June 13th, 2015, 05:27 PM
At least you won't have to remove the whole cabin filter assembly to get the less pretty cover on/off!
90, defender, defender 90
Andrew Howton chrisvonc Defender Owners 0 February 24th, 2004 10:52 PM
Andrew Lees chrisvonc Defender Owners 0 February 24th, 2004 10:44 PM
Andrew Krna chrisvonc Defender Owners 0 February 24th, 2004 10:40 PM
Andrew & Jean Ward chrisvonc Defender Owners 0 February 5th, 2004 09:54 PM
Andrew Silcock chrisvonc Defender Owners 0 February 1st, 2004 10:55 PM
» Defender Registry
Domino
Tripod
Camel
Camel 422
Add your Defender
