Andrew's Defender 90 3.0i Project - Page 13 - Defender Source
Old April 20th, 2015, 08:35 PM
Originally Posted by Chip View Post
Thanks for the tip. Although I think I'll have the stripper dip them when I take the chassis in to prep for galv.
Wow so it's no longer just an engine swap? Progress pics?
Oh, those panels are aluminum so I doubt you want dip them in the same stuff the frame is going into!
Originally Posted by pendy
I'm here for the D's
Old April 21st, 2015, 03:40 PM
Chip's Avatar
Chip
Andrew Harvey
1994 NAS Defender 90
No, I decided the frame should be renewed if I'm going through all this work.
Oh really? I know the rear panels are aluminum, but I thought the corner finishers/cappings are steel. At least they appear to be on my 94 since one is rusting away... Are the 95/97 versions aluminum? I thought people galvanize the cappings to help prevent galvanic corrosion of the aluminum panels.
Old April 21st, 2015, 09:09 PM
Oops, from the pics I thought you meant the aluminum end panels. Yes the capping are all steel. Galvy away!
Good luck with your project, but I'll throw the gauntlet down now and challenge you to be first to completion between the two of us
Old April 22nd, 2015, 01:33 AM
Chip's Avatar
Chip
Andrew Harvey
Haha okay! The race is on!
Old April 22nd, 2015, 03:36 AM
Joos
Joos
97 Defender 110tdi Hicap
Yes, I think you're right, although I've never seen a NAS truck with a rear fog light. Rovers North does list them on their website for NAS trucks though. I think it'll add a bit of safety if I install a second back-up light there because the one on the left could be difficult to see from the right of the vehicle with the spare wheel blocking it.
Hi Andrew
That's a good option if you look at how many times you will be backing up rather to driving in the fog with a soft top.
Regards
Joos
Old April 22nd, 2015, 01:17 PM
Chip's Avatar
Chip
Andrew Harvey
Hi Andrew
Regards
Joos
Yeah, for sure. You're right. It would be good to have a backup light on that side. That's what I'll do.
Old April 26th, 2015, 11:25 PM
Chip's Avatar
Chip
Andrew Harvey
One of my friends just outfitted his Jeep with a complete new sound system, so it got me thinking about mine. I already have a pretty good head unit (Alpine CDA-117), but the speakers are garbage. I was thinking about installing a good set of components, but I'm not sure really where I'd mount the crossovers and I don't want to cut holes in my new dash top for tweeters, although I could probably install them in a pod/enclosure mounted on top of the dash like they are on a 2010 or older Jeep JK. So I decided I just want to keep it simple and put in some high quality coaxials. I've been spending some time researching which ones to get and I'm considering the Hertz Hi-Energy series (HCX 165), the Hybrid Audio Imagine series, or possibly some speakers by CDT. Apparently a company in Idaho called Biketronics sells the HAT Imagine 6.5's for $199 under their own name, which is a good deal. For the amp I'm considering the Zed Audio Mikro IV. It's small, made in the USA, and reviewers say it's well built. What audio setup do you guys have?
Old April 27th, 2015, 12:30 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
I say regardless of which coaxials you go with, you should consider adding a small sub. Our trucks are loud, no matter how much insulation one would install.
The box can be custom built for under the rear seat placement, and a good 8" sub would provide plenty of bass.
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old April 27th, 2015, 03:42 AM
Chip's Avatar
Chip
Andrew Harvey
Yeah, for sure. I'll see if the new speakers give enough kick by themselves though. I don't think a sub would work out well under the fold-up rear seat in the ST, but maybe I could mount one on the back of the cubby, such as the Alpine SWE-1200 which looks similar to the factory unit in the new Defenders.
Old April 27th, 2015, 03:55 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
The aspect of durability is always paramount with me when it comes to the audio system in a defender. Especially a soft top like yours and mine. I'm a big fan of marine grade speakers and amplifiers, just in case. Although JL makes great marine coaxial speakers, have you considered the full range DC golds? Also JL MHT class D amplifiers are peerless. They are compact, run cool, and easy on the batteries. Ironically, I have a sub that I bought to fit the center seat box opening, but I have yet to install it. I just like things hidden and clean. It's rectangular, if you can believe it, and a British company to boot.
"Barry is correct!"
Old April 27th, 2015, 04:41 AM
Chip's Avatar
Chip
Andrew Harvey
For sure. I agree. I haven't heard of the DC golds. They look good. But I found a coupon code (HDForum) for the Biketronics branded HAT Imagine I61-2V2 speakers so I ordered them. It took $40 off 2 sets! They are waterproof and they have a lifetime warranty.
I'll have to check out that amp and that sounds like a good solution for the sub.
Follow up:
Oh, just noticed the coupon code "2015TAXES" is on their homepage. That works too.
Old April 27th, 2015, 01:57 PM
Roverenvy's Avatar
Roverenvy
Michael
1994 Defender 90
I like my alpine sub. It was a little hard to source as alpine was only selling it in the UK last year when I bought it. Had a custom mount made so it attaches nicely...and in front of the bulkhead bar. So I can still use my badger drop curtain.
Old April 27th, 2015, 01:58 PM
Roverenvy's Avatar
Roverenvy
Michael
1994 Defender 90
Here's another.
Old April 27th, 2015, 03:38 PM
Goo gone works best on stickers IME.
That and a razor blade got all the carpet adhesive stickers off my NAS tub without any damage to the paint.
Old April 28th, 2015, 02:25 AM
Chip's Avatar
Chip
Andrew Harvey
Originally Posted by Roverenvy View Post
Here's another.
Awesome! It looks great. It's nice how it fits in there.
Old April 29th, 2015, 08:33 PM
Chip's Avatar
Chip
Andrew Harvey
Speakers just got here. I asked for grills so they included those too. Isn't that nice?
Old May 7th, 2015, 07:42 AM
atakan's Avatar
atakan
atakan
defender 90 1988
Hey,
Andrew. really following keenly on your rebuild. rebuilding my first defender ('85 V8 3,5 90) and i am basically waiting to hear what happens with the M54 as i desperately want to go the BMW way, i was satisfied with the M52 but then i stumbled upon this thread
I haven't heard about the engine swap lately on your thread? any updates on that?
regards,
Ak
Old May 7th, 2015, 08:52 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
That is small. Looks like a CD changer. What is the part number and how does it thump? I am looking for something small and clean as well.
Old May 7th, 2015, 01:12 PM
Chip's Avatar
Chip
Andrew Harvey
Originally Posted by atakan View Post
Hey,
regards,
Ak
Hey Ak,
Welcome to the forum! I have been so busy trying to finish up work here I haven't had time to get back to work on my truck yet. I am planning on going over today. Hopefully by next month I will have it running. I'll be posting updates soon. When I get to the wiring I'll post info on that as well.
Best regards,
Andrew
Old May 7th, 2015, 01:27 PM
Chip's Avatar
Chip
Andrew Harvey
Look at this. 1 day shipping from Great Britain! Under seat tool and battery boxes. They're for the Puma and have the updated battery mounting. Rather than using a J hook the battery sits on it's own little tray and mounts with a clamp just like on a BMW (they appear to be the same parts actually). Here's the part numbers below in case anyone else needs to order them. I ordered from lrdirect.com. I ordered the clamp and bolt from BMW since they were a little cheaper.
Under seat tool box: AWH710020
Under seat battery box: LR012214 or LR066517
-battery tray: YJC500060
-battery clamp: LR009109 or BMW 61217631587
-bolt for clamp: YJH500020 or BMW 61217577620, or 07147211160 (I ordered this last one, which is the new short style)
-venting tube: LR031919
It appears the correct battery size the Puma trucks use is 49 (H8) (Euro size 019), just like many BMW's.
90, defender, defender 90
Andrew Howton chrisvonc Defender Owners 0 February 24th, 2004 11:52 PM
Andrew Lees chrisvonc Defender Owners 0 February 24th, 2004 11:44 PM
Andrew Krna chrisvonc Defender Owners 0 February 24th, 2004 11:40 PM
Andrew & Jean Ward chrisvonc Defender Owners 0 February 5th, 2004 10:54 PM
Andrew Silcock chrisvonc Defender Owners 0 February 1st, 2004 11:55 PM
