Andrew's Defender 90 3.0i Project - Page 10 - Defender Source
Old January 18th, 2015, 10:36 PM
Chip's Avatar
Chip
Andrew
1994 NAS Defender 90
For my 1999+ speedometer, I found I could order the connectors from TME (Transfer Multisort Elektronik). It takes 2 10-pin ISO radio connectors, part # 331440 and the pins are part # 341432.
Old January 20th, 2015, 07:45 PM
Chip's Avatar
Chip
Andrew
Well, this made my day. Here is the official Defender 2.8i electrical troubleshooting manual from BMW South Africa, courtesy of Jaguar Land Rover.
Old February 3rd, 2015, 08:40 PM
Chip's Avatar
Chip
Andrew
I got a rear seat.
Old February 7th, 2015, 12:08 PM
Chip's Avatar
Chip
Andrew
There we go. Complete new instrument cluster ready to go in the truck.
Old February 7th, 2015, 02:28 PM
couga861900's Avatar
couga861900
Cougar, WM of Hiram 72
Land Rover Defender 90 2.5td
Very good looking cluster. Is that the RPM gauge on the far left?
Old February 7th, 2015, 02:43 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Looking good! Will the truck be a 0.0 mile build?
Old February 7th, 2015, 02:56 PM
Chip's Avatar
Chip
Andrew
Yeah, that's the special Defender 2.8i tachometer on the left. The new speedo has 63k on it according to the seller. That's pretty close to the engine, which has 58k. I'll just take a picture of it next to the old speedo to put in my records.
Old February 7th, 2015, 03:03 PM
D90Overkill
David Frank
1995 ST #2615
That's cool. The cluster looks great and I thought it could be brand new, not just new to you. I thought that maybe you found a new old stock cluster. Probably unicorn impossible, but then again, you are proving to be very resourceful and I wouldn't have been surprised! Jealous? Yeah. Surprised? No.
Old February 7th, 2015, 03:09 PM
Chip's Avatar
Chip
Andrew
Only the tachometer is brand new. Everything new would have cost an ungodly fortune.
Old February 7th, 2015, 03:28 PM
D90Overkill
David Frank
1995 ST #2615
True! But you would have been godly! ;-)
Old February 7th, 2015, 04:34 PM
Chip's Avatar
Chip
Andrew
I think it takes more godly abilities to sniff out bargains.
Old February 8th, 2015, 07:53 PM
Chip's Avatar
Chip
Andrew
This is a follow-up post about this previous post I made.
So I have a genuine dash harness here and the actual speedo connectors are made by AMP (TE Connectivity). They're part # 962190. Of course the standard ISO radio connectors will work just fine, but they're not the actual connectors Land Rover used. I just wanted to clarify that to help anyone upgrading to the digital speedo. Or of course just buy the correct harness, but then you'll need the 14-pin connector for the end of the harness, which unfortunately is made by Sumitomo so it's not as readily available. I just got a male + female 14-pin connector made by Delphi to replace it.
You know what's funny is that the analog clock connector on the Td5 dash loom says BMW on it.
Old February 9th, 2015, 07:55 PM
Chip's Avatar
Chip
Andrew
I noticed NAPA sells the replaceable bulb version of the 93 & 94 NAS front turn signal by Truck-Lite. It's part # 60302Y. They only had 1 at my local store, but they ordered me another.
Old February 10th, 2015, 12:17 PM
Chip's Avatar
Chip
Andrew
I found some new old stock D90 rear seat belts.
Does anyone know where to get the swivel spacers for the upper mount? Of course I'll need all the brackets too. I guess we'll need to make some.
Old February 10th, 2015, 12:37 PM
Chip's Avatar
Chip
Andrew
These little guys. I wonder if my local hardware store will have something similar. Hmm...
------ Follow up post added February 10th, 2015 10:37 AM ------
Check with John Gadd (roverdude) He has parted many RRC's and Disco's and I beleive those spacers etc are the same.
-Jeff
Okay, awesome. Thanks!
Old February 10th, 2015, 01:17 PM
Chip's Avatar
Chip
Andrew
Maybe I'll need to have them machined like jefhuf in this post: http://www.defendersource.com/forum/...ad.php?t=27164.
Old February 14th, 2015, 11:11 AM
Chip's Avatar
Chip
Andrew
I got a RR P38 steering box so I can use the M54's original power steering pump and keep that and the alternator in their original positions. Special thanks to Robert Davis for helping me with this decision.
Old February 14th, 2015, 11:56 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Very cool. Can't wait to see this installed.
Robert Davis = Wizard
Old February 19th, 2015, 05:35 PM
Chip's Avatar
Chip
Andrew
Uh oh, Andrew caught the galvanize bug. Now my Defender 2.8i engine mounts are better than new.
Old February 20th, 2015, 12:35 AM
Chip's Avatar
Chip
Andrew
This picture is better.
90, defender, defender 90
Andrew Howton chrisvonc Defender Owners 0 February 24th, 2004 10:52 PM
Andrew Lees chrisvonc Defender Owners 0 February 24th, 2004 10:44 PM
Andrew Krna chrisvonc Defender Owners 0 February 24th, 2004 10:40 PM
Andrew & Jean Ward chrisvonc Defender Owners 0 February 5th, 2004 09:54 PM
Andrew Silcock chrisvonc Defender Owners 0 February 1st, 2004 10:55 PM
